zigbee教程中Zigbee Fundamental Project Development代码咨询,cc2652.
教程part1中task1中第4步。多了一个#endif(32行),导致编译不通过。删除之后,编程成功,但运行绑定之后,系统死机
      case zstackmsg_CmdIDs_ZDO_DEVICE_ANNOUNCE:
#if defined (Z_POWER_TEST)
#if defined (POWER_TEST_POLL_DATA)
        zstackmsg_zdoDeviceAnnounceInd_t *pInd;
        pInd = (zstackmsg_zdoDeviceAnnounceInd_t*)pMsg;
        // save the short address of the ZED to send ZCL test data
        powerTestZEDAddr = pInd->req.srcAddr;
        // start periodic timer for sending ZCL data to zed
        OsalPortTimers_startReloadTimer(appServiceTaskId, SAMPLEAPP_POWER_TEST_ZCL_DATA_EVT, Z_POWER_TEST_DATA_TX_INTERVAL);
#endif
#else
          zstack_zdoActiveEndpointReq_t pReq;
          pReq.dstAddr = pInd->req.srcAddr;
          pReq.nwkAddrOfInterest = pInd->req.devAddr;
          shortAddr = pInd->req.srcAddr;
          memcpy(bindAddr, &(pInd->req.devExtAddr), Z_EXTADDR_LEN);
          Zstackapi_ZdoActiveEndpointReq(appServiceTaskId, &pReq);
#endif
      break;
//此处多了endif!!!!!!!!!!!!!编译不通过。
#endif
      break;
      case zstackmsg_CmdIDs_ZDO_SIMPLE_DESC_RSP:
          zstackmsg_zdoSimpleDescRspInd_t *pInd;
          pInd = (zstackmsg_zdoSimpleDescRspInd_t*)pMsg;
          for (uint8_t i = 0; i < pInd->rsp.simpleDesc.n_outputClusters; i++)
              if (*(pInd->rsp.simpleDesc.pOutputClusters) == ZCL_CLUSTER_ID_GEN_ON_OFF)
                  zstack_sysNwkInfoReadRsp_t pRsp;
                  Zstackapi_sysNwkInfoReadReq(appServiceTaskId, &pRsp);
                  zstack_zdoBindReq_t pReq;
                  pReq.nwkAddr = pRsp.nwkAddr;
                  pReq.bindInfo.clusterID = ZCL_CLUSTER_ID_GEN_ON_OFF;
                  pReq.bindInfo.srcEndpoint = SAMPLELIGHT_ENDPOINT;
                  pReq.bindInfo.dstAddr.addrMode = (zstack_AFAddrMode)Addr64Bit;
                  pReq.bindInfo.dstAddr.endpoint = pInd->rsp.simpleDesc.endpoint;
                  EP = pInd->rsp.simpleDesc.endpoint;
                  memcpy(pReq.bindInfo.dstAddr.addr.extAddr, &bindAddr, Z_EXTADDR_LEN);
                  memcpy(pReq.bindInfo.srcAddr, &(pRsp.ieeeAddr), Z_EXTADDR_LEN);
                  Zstackapi_ZdoBindReq(appServiceTaskId, &pReq);
              pInd->rsp.simpleDesc.pOutputClusters++;
      break;
      case zstackmsg_CmdIDs_ZDO_ACTIVE_EP_RSP:
          zstackmsg_zdoActiveEndpointsRspInd_t *pInd;
          pInd = (zstackmsg_zdoActiveEndpointsRspInd_t*)pMsg;
          zstack_zdoSimpleDescReq_t pReq;
          pReq.dstAddr = pInd->rsp.srcAddr;
          pReq.nwkAddrOfInterest = pInd->rsp.nwkAddrOfInterest;
          for (uint8_t i = 0; i < pInd->rsp.n_activeEPList; i++)
              pReq.endpoint = pInd->rsp.pActiveEPList[i];
              Zstackapi_ZdoSimpleDescReq(appServiceTaskId, &pReq);
      break;
  • 哪个教程可以明示吗?链接或文档麻烦贴一下
  • 我把第四步改了一下,可以通过编译了。详情如下:
    1、
    #endif
    #else
    //#endif
          break;
    #endif
    尾部第一个endif屏蔽掉
    2、
    //  break;
          break;
          break;
    上面这段代码替换zcl_samplelight.c里的
    两行,你试一下,注意第一行的break屏蔽掉
  • 您好,可以编译成功,但下载之后进行bind时,这个设备就死机不能运行了。左右两边按钮都不起作用。您那边可以实现这个教程的结果吗?
  • 这是按教程Part1之后形成的代码,使用这个会出现死机问题
    zcl_samplelight.c
    zcl_samplelight_data.c
      Filename:       zcl_samplelight_data.c
      Revised:        $Date: 2014-05-12 13:14:02 -0700 (Mon, 12 May 2014) $
      Revision:       $Revision: 38502 $
      Description:    Zigbee Cluster Library - sample device application.
      Copyright 2006-2014 Texas Instruments Incorporated. All rights reserved.
      IMPORTANT: Your use of this Software is limited to those specific rights
      granted under the terms of a software license agreement between the user
      who downloaded the software, his/her employer (which must be your employer)
      and Texas Instruments Incorporated (the "License").  You may not use this
      Software unless you agree to abide by the terms of the License. The License
      limits your use, and you acknowledge, that the Software may not be modified,
      copied or distributed unless embedded on a Texas Instruments microcontroller
      or used solely and exclusively in conjunction with a Texas Instruments radio
      frequency transceiver, which is integrated into your product.  Other than for
      the foregoing purpose, you may not use, reproduce, copy, prepare derivative
      works of, modify, distribute, perform, display or sell this Software and/or
      its documentation for any purpose.
      YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE
      PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED,
      INCLUDING WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY, TITLE,
      NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE. IN NO EVENT SHALL
      TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
      NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER
      LEGAL EQUITABLE THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES
      INCLUDING BUT NOT LIMITED TO ANY INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE
      OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST DATA, COST OF PROCUREMENT
      OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY THIRD PARTIES
      (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
      Should you have any questions regarding your right to use this Software,
      contact Texas Instruments Incorporated at www.TI.com.
     * INCLUDES
    #include "zcomdef.h"
    #include "zcl.h"
    #include "zcl_general.h"
    #include "zcl_ha.h"
    #include "zcl_poll_control.h"
    #include "zcl_electrical_measurement.h"
    #include "zcl_meter_identification.h"
    #include "zcl_appliance_identification.h"
    #include "zcl_appliance_events_alerts.h"
    #include "zcl_power_profile.h"
    #include "zcl_appliance_control.h"
    #include "zcl_appliance_statistics.h"
    #include "zcl_hvac.h"
    #include "zcl_samplelight.h"
    #ifdef BDB_REPORTING
    #include "zstackapi.h"
    #endif
     * CONSTANTS
    #define SAMPLELIGHT_DEVICE_VERSION     1
    #define SAMPLELIGHT_FLAGS              0
    #define SAMPLELIGHT_HWVERSION          1
    #define SAMPLELIGHT_ZCLVERSION         BASIC_ZCL_VERSION
    #define DEFAULT_IDENTIFY_TIME 0
    #define DEFAULT_ON_OFF_TRANSITION_TIME 20
    #define DEFAULT_ON_LEVEL ATTR_LEVEL_ON_LEVEL_NO_EFFECT
    #define DEFAULT_ON_TRANSITION_TIME 20
    #define DEFAULT_OFF_TRANSITION_TIME 20
    #define DEFAULT_MOVE_RATE 0 // as fast as possible
    #define DEFAULT_ON_OFF_STATE LIGHT_OFF
    #define DEFAULT_LEVEL ATTR_LEVEL_MAX_LEVEL
     * TYPEDEFS
     * MACROS
     * EXTERNAL VARIABLES
    extern uint8_t  appServiceTaskId;
     * GLOBAL VARIABLES
    //global attributes
    const uint16_t zclSampleLight_basic_clusterRevision = 0x0002;
    const uint16_t zclSampleLight_identify_clusterRevision = 0x0001;
    const uint16_t zclSampleLight_groups_clusterRevision = 0x0001;
    const uint16_t zclSampleLight_scenes_clusterRevision = 0x0001;
    const uint16_t zclSampleLight_onoff_clusterRevision = 0x0001;
    const uint16_t zclSampleLight_level_clusterRevision = 0x0001;
    // Basic Cluster
    const uint8_t zclSampleLight_HWRevision = SAMPLELIGHT_HWVERSION;
    const uint8_t zclSampleLight_ZCLVersion = SAMPLELIGHT_ZCLVERSION;
    const uint8_t zclSampleLight_ManufacturerName[] = { 16, 'T','e','x','a','s','I','n','s','t','r','u','m','e','n','t','s' };
    const uint8_t zclSampleLight_PowerSource = POWER_SOURCE_MAINS_1_PHASE;
    uint8_t zclSampleLight_PhysicalEnvironment = PHY_UNSPECIFIED_ENV;
    // Identify Cluster
    uint16_t zclSampleLight_IdentifyTime;
    // Groups Cluster
    uint8_t zclSampleLight_GroupsNameSupport = 0;
    // On/Off Cluster
    static uint8_t  zclSampleLight_OnOff;
    // Level Control Cluster
    #ifdef ZCL_LEVEL_CTRL
    static uint8_t  zclSampleLight_LevelCurrentLevel;
    uint16_t zclSampleLight_LevelRemainingTime;
    uint16_t zclSampleLight_LevelOnOffTransitionTime;
    uint8_t  zclSampleLight_LevelOnLevel;
    uint16_t zclSampleLight_LevelOnTransitionTime;
    uint16_t zclSampleLight_LevelOffTransitionTime;
    uint8_t  zclSampleLight_LevelDefaultMoveRate;
    #endif
    uint8_t  zclSampleLight_ScenesCurrentScene = 0;
    uint16_t zclSampleLight_ScenesCurrentGroup = 0;
    uint8_t  zclSampleLight_ScenesValid = 0;
    uint8_t  zclSampleLight_ScenesNameSupport = 0;
    #if ZCL_DISCOVER
    CONST zclCommandRec_t zclSampleLight_Cmds[] =
        ZCL_CLUSTER_ID_GEN_BASIC,
        COMMAND_BASIC_RESET_FACT_DEFAULT,
        CMD_DIR_SERVER_RECEIVED
        ZCL_CLUSTER_ID_GEN_ON_OFF,
        COMMAND_OFF,
        COMMAND_ON,
        COMMAND_TOGGLE,
    #ifdef ZCL_LEVEL_CONTROL
        ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL,
        COMMAND_LEVEL_MOVE_TO_LEVEL,
        COMMAND_LEVEL_MOVE,
        COMMAND_LEVEL_STEP,
        COMMAND_LEVEL_STOP,
        COMMAND_LEVEL_MOVE_TO_LEVEL_WITH_ON_OFF,
        COMMAND_LEVEL_MOVE_WITH_ON_OFF,
        COMMAND_LEVEL_STEP_WITH_ON_OFF,
        COMMAND_LEVEL_STOP_WITH_ON_OFF,
    #endif // ZCL_LEVEL_CONTROL
    CONST uint8_t zclCmdsArraySize = ( sizeof(zclSampleLight_Cmds) / sizeof(zclSampleLight_Cmds[0]) );
    #endif // ZCL_DISCOVER
     * ATTRIBUTE DEFINITIONS - Uses REAL cluster IDs
    // NOTE: The attributes listed in the AttrRec must be in ascending order
    // per cluster to allow right function of the Foundation discovery commands
    CONST zclAttrRec_t zclSampleLight_Attrs[] =
      // *** General Basic Cluster Attributes ***
        { // Attribute record
          ATTRID_BASIC_ZCL_VERSION,
          ZCL_DATATYPE_UINT8,
          ACCESS_CONTROL_READ,
          (void *)&zclSampleLight_ZCLVersion
        ZCL_CLUSTER_ID_GEN_BASIC,             // Cluster IDs - defined in the foundation (ie. zcl.h)
          ATTRID_BASIC_HW_VERSION,            // Attribute ID - Found in Cluster Library header (ie. zcl_general.h)
          ZCL_DATATYPE_UINT8,                 // Data Type - found in zcl.h
          ACCESS_CONTROL_READ,                // Variable access control - found in zcl.h
          (void *)&zclSampleLight_HWRevision  // Pointer to attribute variable
          ATTRID_BASIC_MANUFACTURER_NAME,
          ZCL_DATATYPE_CHAR_STR,
          (void *)zclSampleLight_ManufacturerName
          ATTRID_BASIC_POWER_SOURCE,
          ZCL_DATATYPE_ENUM8,
          (void *)&zclSampleLight_PowerSource
          ATTRID_BASIC_PHYSICAL_ENV,
          ZCL_DATATYPE_ENUM8,
          (ACCESS_CONTROL_READ | ACCESS_CONTROL_WRITE),
          (void *)&zclSampleLight_PhysicalEnvironment
          ATTRID_CLUSTER_REVISION,
          ZCL_DATATYPE_UINT16,
          (void *)&zclSampleLight_basic_clusterRevision
    #ifdef ZCL_IDENTIFY
      // *** Identify Cluster Attribute ***
        ZCL_CLUSTER_ID_GEN_IDENTIFY,
          ATTRID_IDENTIFY_TIME,
          (void *)&zclSampleLight_IdentifyTime
          (void *)&zclSampleLight_identify_clusterRevision
    #endif
      // *** On/Off Cluster Attributes ***
          ATTRID_ON_OFF,
          ZCL_DATATYPE_BOOLEAN,
          ACCESS_CONTROL_READ | ACCESS_REPORTABLE,
          (void*)&zclSampleLight_OnOff
          (void *)&zclSampleLight_onoff_clusterRevision
          ATTRID_LEVEL_CURRENT_LEVEL,
          ZCL_DATATYPE_UINT8,
          (void*)&zclSampleLight_LevelCurrentLevel
          ATTRID_LEVEL_REMAINING_TIME,
          (void *)&zclSampleLight_LevelRemainingTime
          ATTRID_LEVEL_ON_OFF_TRANSITION_TIME,
          ACCESS_CONTROL_READ | ACCESS_CONTROL_WRITE,
          (void *)&zclSampleLight_LevelOnOffTransitionTime
          ATTRID_LEVEL_ON_LEVEL,
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight_LevelOnLevel
          ATTRID_LEVEL_ON_TRANSITION_TIME,
          (void *)&zclSampleLight_LevelOnTransitionTime
          ATTRID_LEVEL_OFF_TRANSITION_TIME,
          (void *)&zclSampleLight_LevelOffTransitionTime
          ATTRID_LEVEL_DEFAULT_MOVE_RATE,
          (void *)&zclSampleLight_LevelDefaultMoveRate
          (void *)&zclSampleLight_level_clusterRevision
    #endif
    #ifdef ZCL_GROUPS
        ZCL_CLUSTER_ID_GEN_GROUPS,
          ATTRID_GROUP_NAME_SUPPORT,
          ZCL_DATATYPE_BITMAP8,
          (void*)&zclSampleLight_GroupsNameSupport
          (void *)&zclSampleLight_groups_clusterRevision
    #endif
      // *** Scene Cluster Attributes ***
        ZCL_CLUSTER_ID_GEN_SCENES,
          ATTRID_SCENES_COUNT,
          ZCL_DATATYPE_UINT8,
          NULL // Use application's callback to Read this attribute
          ATTRID_SCENES_CURRENT_SCENE,
          ZCL_DATATYPE_UINT8,
          (void *)&zclSampleLight_ScenesCurrentScene
          ATTRID_SCENES_CURRENT_GROUP,
          (void *)&zclSampleLight_ScenesCurrentGroup
          ATTRID_SCENES_SCENE_VALID,
          (void *)&zclSampleLight_ScenesValid
          ATTRID_SCENES_NAME_SUPPORT,
          (void *)&zclSampleLight_ScenesNameSupport
          (void *)&zclSampleLight_scenes_clusterRevision
    uint8_t CONST zclSampleLight_NumAttributes = ( sizeof(zclSampleLight_Attrs) / sizeof(zclSampleLight_Attrs[0]) );
     * SIMPLE DESCRIPTOR
    // This is the Cluster ID List and should be filled with Application
    // specific cluster IDs.
    const cId_t zclSampleLight_InClusterList[] =
      , ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL
    #endif
    #define ZCLSAMPLELIGHT_MAX_INCLUSTERS   (sizeof(zclSampleLight_InClusterList) / sizeof(zclSampleLight_InClusterList[0]))
    SimpleDescriptionFormat_t zclSampleLight_SimpleDesc =
      SAMPLELIGHT_ENDPOINT,                  //  int Endpoint;
      ZCL_HA_PROFILE_ID,                     //  uint16_t AppProfId;
      ZCL_HA_DEVICEID_DIMMABLE_LIGHT,        //  uint16_t AppDeviceId;
    #else
      ZCL_HA_DEVICEID_ON_OFF_LIGHT,          //  uint16_t AppDeviceId;
    #endif
      SAMPLELIGHT_DEVICE_VERSION,            //  int   AppDevVer:4;
      SAMPLELIGHT_FLAGS,                     //  int   AppFlags:4;
      ZCLSAMPLELIGHT_MAX_INCLUSTERS,         //  byte  AppNumInClusters;
      (cId_t *)zclSampleLight_InClusterList, //  byte *pAppInClusterList;
      0,        //  byte  AppNumInClusters;
      NULL //  byte *pAppInClusterList;
    // Added to include Touchlink Target functionality
    #if defined ( BDB_TL_INITIATOR ) || defined ( BDB_TL_TARGET )
    bdbTLDeviceInfo_t tlSampleLight_DeviceInfo =
      SAMPLELIGHT_ENDPOINT,                  //uint8_t endpoint;
      ZCL_HA_PROFILE_ID,                        //uint16_t profileID;
    #else
    #endif
      SAMPLELIGHT_DEVICE_VERSION,                    //uint8_t version;
      SAMPLELIGHT_NUM_GRPS                   //uint8_t grpIdCnt;
    #endif
     * GLOBAL FUNCTIONS
     * @fn      zclSampleLight_updateOnOffAttribute
     * @brief   Function that updates the OnOff attribute, this will also update scene attribute.
     * @param   OnOff state
     * @return  none
    void zclSampleLight_updateOnOffAttribute(uint8_t OnOff)
        if(zclSampleLight_OnOff != OnOff)
            zclSampleLight_OnOff = OnOff;
            zclSampleLight_ScenesValid = FALSE;
            zstack_bdbRepChangedAttrValueReq_t Req;
            Req.attrID = ATTRID_ON_OFF;
            Req.cluster = ZCL_CLUSTER_ID_GEN_ON_OFF;
            Req.endpoint = SAMPLELIGHT_ENDPOINT;
          Zstackapi_bdbRepChangedAttrValueReq(appServiceTaskId,&Req);
    #endif
     * @fn      zclSampleLight_getOnOffAttribute
     * @brief   Function to get the state of the OnOff attribute.
     * @param   none
     * @return  OnOff attribute state (True if on, False if Off)
    uint8_t zclSampleLight_getOnOffAttribute(void)
        return zclSampleLight_OnOff;
     * @fn      zclSampleLight_updateCurrentLevelAttribute
     * @param   Current Level state
     * @return  none
    void zclSampleLight_updateCurrentLevelAttribute(uint8_t CurrentLevel)
        if(zclSampleLight_LevelCurrentLevel != CurrentLevel)
            zclSampleLight_LevelCurrentLevel = CurrentLevel;
            Req.attrID = ATTRID_LEVEL_CURRENT_LEVEL;
            Req.cluster = ZCL_CLUSTER_ID_GEN_LEVEL_CONTROL;
    #endif
     * @fn      zclSampleLight_getCurrentLevelAttribute
     * @param   none
     * @return  Current Level attribute state
    uint8_t zclSampleLight_getCurrentLevelAttribute(void)
        return zclSampleLight_LevelCurrentLevel;
    #endif
     * LOCAL FUNCTIONS
     * @fn      zclSampleLight_ResetAttributesToDefaultValues
     * @brief   Reset all writable attributes to their default values.
     * @param   none
     * @return  none
    void zclSampleLight_ResetAttributesToDefaultValues(void)
    #ifdef ZCL_IDENTIFY
      zclSampleLight_IdentifyTime = DEFAULT_IDENTIFY_TIME;
    #endif
      zclSampleLight_LevelRemainingTime = 0;
      zclSampleLight_LevelOnOffTransitionTime = DEFAULT_ON_OFF_TRANSITION_TIME;
      zclSampleLight_LevelOnLevel = DEFAULT_ON_LEVEL;
      zclSampleLight_LevelOnTransitionTime = DEFAULT_ON_TRANSITION_TIME;
      zclSampleLight_LevelOffTransitionTime = DEFAULT_OFF_TRANSITION_TIME;
      zclSampleLight_LevelDefaultMoveRate = DEFAULT_MOVE_RATE;
      zclSampleLight_updateCurrentLevelAttribute(DEFAULT_LEVEL);
    #endif
      zclSampleLight_updateOnOffAttribute(DEFAULT_ON_OFF_STATE);
      zclSampleLight_IdentifyTime = 0;
  • 目前无法实现,板子不在手边
  • 等您有空的时候能否帮忙看看呢?十分感谢
