Z-Stack Linux Gateway BeagleBone 搭配的BBB Debian版本問題.
HI YK
這幾天試了一下Z-Stack Linux Gateway
再去爬了一下文. 發現你有提到只在Debian 7.8版本( IN BeagleBone Black ) 正常
我現在試了Debian 10.3版( IN BeagleBone Black )執行:
(BeagleBoard.org Debian Buster IoT Image 2020-04-06)
"sudo ./zigbeeHAgw beaglebone"
也是一樣一堆錯( BeagleBone Black 有上網)
"connect: Connection refused
[ZSTACKZNP_SRVR/MAIN] ERROR: ERROR: signal 11 was trigerred:
[ZSTACKZNP_SRVR/MAIN] ERROR:   Fault address: (nil)
[ZSTACKZNP_SRVR/MAIN] ERROR:   Fault reason: address not mapped to object
[ZSTACKZNP_SRVR/MAIN] ERROR: Stack trace unavailable
[ZSTACKZNP_SRVR/MAIN] ERROR: Executing original handler...
./zigbeeHAgw: line 351: 29620 Segmentation fault      $ZLSZNP_CMD
ZLSZNP started (pid 29620) at Mon 07 Sep 2020 02:05:37 PM UTC
[NWK_MGR/MAIN] :  there are 2 args
[NWK_MGR/MAIN] :  argv[0] = ./NWKMGR_SRVR_arm
[NWK_MGR/MAIN] :  argv[1] = 127.0.0.1:2536
[NWK_MGR/MAIN] ERROR: ERROR: signal 11 was trigerred:
[NWK_MGR/MAIN] ERROR:   Fault address: (nil)
[NWK_MGR/MAIN] ERROR:   Fault reason: address not mapped to object
[NWK_MGR/MAIN] ERROR: Stack trace unavailable
[NWK_MGR/MAIN] ERROR: Executing original handler...
./zigbeeHAgw: line 407: 29623 Segmentation fault      $NWKMGR_CMD $NWKMGR_RESTART_FLAG
NETWORK MANAGER started (pid 29623) at Mon 07 Sep 2020 02:05:38 PM UTC
[GATEWAY/MAIN] ERROR: ERROR: signal 11 was trigerred:
[GATEWAY/MAIN] ERROR:   Fault address: (nil)
[GATEWAY/MAIN] ERROR:   Fault reason: address not mapped to object
[GATEWAY/MAIN] ERROR: Stack trace unavailable
[GATEWAY/MAIN] ERROR: Executing original handler...
./zigbeeHAgw: line 378: 29626 Segmentation fault      $GATEWAY_SERVER_CMD
GATEWAY SERVER started (pid 29626) at Mon 07 Sep 2020 02:05:40 PM UTC
[OTASRVR/MAIN] ERROR: ERROR: signal 11 was trigerred:
[OTASRVR/MAIN] ERROR:   Fault address: (nil)
[OTASRVR/MAIN] ERROR:   Fault reason: address not mapped to object
[OTASRVR/MAIN] ERROR: Stack trace unavailable
[OTASRVR/MAIN] ERROR: Executing original handler...
./zigbeeHAgw: line 438: 29629 Segmentation fault      $OTA_SERVER_CMD
OTA SERVER started (pid 29629) at Mon 07 Sep 2020 02:05:42 PM UTC
starting tracker with our pid ./zigbeeHAgw and pid list 29615 29620 29626 29629
只能用Debian 7.8版本或是官網的am335x-evm-linux-06.03.00.106.img
( IN BeagleBone Black )了嗎??
謝謝.
  • 好像7.8是OK的,以下是Debian 7.8版本執行
    出來的訊息:
    running zigbeegw.scr on an ARM
    resetting beaglebone black
    sleeping 6 seconds after reset... Using serial port: /dev/ttyACM0
    zbSocProcessRpc: CMD0:41, CMD1:80, not handled
    Received System version.
    Transport Protocol Version: 2
    Product ID: 0
    Software Release: 2.6.1
    Software Revision: 38724
    done
    Starting the ZigBee gateway subsystem
    deviceKey = 0 (0 )
    devPath = '/dev/ttyACM0'
    logPath = './NpiLnxLog.txt'
    ... freeing memory (ret 0)
    Port: 2533
    Following IP addresses are available:
    IPv4: interface: lo IP Address 127.0.0.1
    IPv4: interface: usb0 IP Address 192.168.7.2
    IPv6: interface: lo IP Address ::1
    IPv6: interface: eth0 IP Address 2001:b400:e2d3:4c40:6a3:16ff:feba:7b39
    IPv6: interface: eth0 IP Address 2001:b400:e254:68d4:6a3:16ff:feba:7b39
    IPv6: interface: eth0 IP Address fe80::6a3:16ff:feba:7b39
    IPv6: interface: usb0 IP Address fe80::7811:8aff:feae:488a
    The socket will listen on the following IP addresses:
    IPv4: 0.0.0.0
    IPv6: ::
    0.0.0.0 means it will listen to all available IP address
    waiting for first connection on #3...
    NPI started (pid 2074) at Sun Mar 1 21:12:27 UTC 2015
    Connected to #5.(127.0.0.1 / ::b8b3:cbbe:b4:cbbe)
    ZLSZNP started (pid 2080) at Sun Mar 1 21:12:31 UTC 2015
    [NWK_MGR/MAIN] : ************************************************
    [NWK_MGR/MAIN] : * Network Manager Server v1.0.1 *
    [NWK_MGR/MAIN] : * The following are the avaible key commands: *
    [NWK_MGR/MAIN] : * Exit Program. - q *
    NETWORK MANAGER started (pid 2086) at Sun Mar 1 21:12:32 UTC 2015
    [GATEWAY/MAIN] :
    [GATEWAY/MAIN] : ************************************************
    [GATEWAY/MAIN] : * Gateway Server v1.0.1 *
    [GATEWAY/MAIN] : * The following are the avaible key commands: *
    [GATEWAY/MAIN] : * Exit Program. - q *
    GATEWAY SERVER started (pid 2093) at Sun Mar 1 21:12:34 UTC 2015
    [OTASRVR/MAIN] :
    [OTASRVR/MAIN] : ************************************************
    [OTASRVR/MAIN] : * OTA Upgrade Server 1.0.1 *
    [OTASRVR/MAIN] : * The following are the avaible key commands: *
    [OTASRVR/MAIN] : * Exit Program. - q *
    OTA SERVER started (pid 2101) at Sun Mar 1 21:12:36 UTC 2015
    starting tracker with our pid ./zigbeeHAgw and pid list 2074 2080 2093 2101
    tracking 4 pids, 2074 2080 2093 2101
    when we see something missing we will send a SIGUSR2 to pid 2009
  • 我沒有在Debian 10.3版上測試過、建議還是用7.8
    YK Chen
    如果回复解决了问题,请帮忙点击确认此为答案,谢谢
  • 回复 Hunter Wang:
    建议按照这里的版本,其他没有验证过:dev.ti.com/.../node
    若该回复解决了您的问题,请点击“确认此为答案”,谢谢。
  • 回复 Hunter Wang:
    请参考Z-Stack Linux Gateway BeagleBone QuickStart Guide.pdf
  • 回复 YiKai Chen:
    HI YK
    這是我測LINUX GATEWAY按了大O要嘗試OTA的LOG
    好像前面都對,後面出現了一個什麼未註冊的狀態機器??這個是錯誤嗎??
    (ZED用的是2652R開發板加SDK 的 zed_sw_ota_client 專案)
    謝謝
  • 回复 Hunter Wang:
    沒遇過這樣的問題,你有照使用手冊的步驟測試嗎?你的Zigbee GW是自己build的還是預編譯好的?
    YK Chen
  • 回复 YiKai Chen:
    HI YK
    LINUX GW 都是用原來的,沒有再BUILD過.
    用BBB+CC2531做LINUX GW
    就照說明把PC上SDK解出來的 z-stack_linux_gateway_arm_binaries_<version>.tar SCP到BBB裡
    解壓縮.
    做了cp protobuf/libprotobuf-c.so.0 /usr/lib/
    再把sample_app_ota.cfg放到/root/下
    執行./zigbeeHAgw beaglebone
    和 ./start_application
    再照說明選擇剛加入 zed_sw_ota_client 裝置的按下大O做OTA
    就變這樣子.
    謝謝.
  • 回复 Hunter Wang:
    你sample_app_ota.cfg的內容有沒有設置好?
    YK Chen
  • 回复 YiKai Chen:
    HI YK
    有啊,sample_app_ota.cfg裡面
    第一個是要OTA的.ZIGBEE檔案的路徑嘛
    第二個是要更新的個數就照原來寫1
    第三個是要更新的裝置的IEEE ADDRESS.
    都有改好.
    手冊是這樣寫的.
    另外有參考別人的錯誤,有COPY一份丟到/BOOT下面.
    謝謝.
  • 回复 YiKai Chen:
    但是user guide 有提到說
    "To initiate an “OTA Upgrade” you will need to do the following:
    Program up a SmartRF + CC2530 as an example OTA client."
    所以一定要SmartRF + CC2530 , cc2652r + zed_sw_ota_client不行??
