[参考译文] LMK04826:LMK04826正在设置值?
Guru**** 2505955 points
Other Parts Discussed in Thread: LMK04826
https://e2e.ti.com/support/clock-timing-group/clock-and-timing/f/clock-timing-forum/858483/lmk04826-lmk04826-setting-value
器件型号:LMK04826
戴尔
正在使用 LMK04826对开发进行测试。
设置如下图所示。
未输出9.6Mhz。
请查看设置有什么问题。
[我们的设置]
地址= 888
时钟= 8
数据= 4
LE=2
器件= LMK04826B
iface = SPI
ADDREST_I2C=0x0
[引脚]
PINNAME00=SYNC
LOCATION00=7
PINVALUE00=错误
PINNAME01=CLKin0_SEL
LOCATION01=0
PINVALUE01=错误
PINNAME02=复位
LOCATION02=3.
PINVALUE02=错误
[模式]
NAME00=R0 (初始化)
VALUE00=144
NAME01=R0
VALUE01=16
NAME02=R2
VALUE02=512
NAME03=R3
VALUE03=774
NAME04=R4
VALUE04=1232
NAME05=R5
VALUE05=1371
NAME06=R6.
VALUE06=1536
NAME07=R12
VALUE07=3153
NAME08=R13
VALUE08=3332
NAME09=R256
VALUE09=65552
NAME10=R257
VALUE10=65877
NAME11=R258
VALUE11=66133
NAME12=R259
VALUE12=66304
NAME13=R260
VALUE13=66594
NAME14=R261
VALUE14=66816
NAME15=R262
VALUE15=67184
name16=R263
VALUE16=67345
NAME17=R264
VALUE17=67584
NAME18=R265
VALUE18=67925
NAME19=R266
VALUE19=68181
NAME20=R267
VALUE20=68352
NAME21=R268
VALUE21=68642
NAME22=R269
VALUE22=68864
NAME23=R270
VALUE23=69232
NAME24=R271
VALUE24=69425
NAME25=R272
VALUE25=69640
NAME26=R273
VALUE26=69973
NAME27=R274
VALUE27=70229
NAME28=R275
VALUE28=70400
NAME29=R276
VALUE29=70690
NAME30=R277
VALUE30=70912
NAME31=R278
VALUE31=71408
NAME32=R279
VALUE32=71442
NAME33=R280
VALUE33=71682
NAME34=R281
VALUE34=72021
NAME35=R282
VALUE35=72277
NAME36=R283.
VALUE36=72448
NAME37=R284
VALUE37=72738
NAME38=R285
VALUE38=72960
NAME39=R286
VALUE39=73328
NAME40=R287
VALUE40=73491
NAME41=R288
VALUE41=73730
NAME42=R289
VALUE42=74069
NAME43=R290
VALUE43=74325
NAME44=R291
VALUE44=74496
NAME45=R292
VALUE45=74786
NAME46=R293
VALUE46=75008
NAME47=R294
VALUE47=75376
NAME48=R295
VALUE48=75539
NAME49=R296
VALUE49=75778
NAME50=R297
VALUE50=76117
NAME51=R298
VALUE51=76373
NAME52=R299
VALUE52=76544
NAME53=R300
VALUE53=76834
NAME54=R301
VALUE54=77056
NAME55=R302
VALUE55=77552
NAME56=R303
VALUE56=77585
NAME57=R304
VALUE57=77826
NAME58=R305
VALUE58=78165
NAME59=R306
VALUE59=78421
NAME60=R307
VALUE60=78592
NAME61=R308
VALUE61=78882
NAME62=R309
VALUE62=79104
NAME63=R310
VALUE63=79472
NAM64 = R311
VALUE64=79633
NAME65=R312
VALUE65=79909
NAME66=R313
VALUE66=80128
NAME67=R314
VALUE67=80385
NAME68=R315
VALUE68=80640
NAME69=R316
VALUE69=80896
NAME70=R317
VALUE70=89160
NAME71=R318
VALUE71=81411
NAME72=R319
VALUE72=81664
NAME73=R320
VALUE73=81925
NAME74=R321
VALUE74=82176
NAME75=R322
VALUE75=82432
NAME76=R323
VALUE76=82705
NAME77=R324
VALUE77=83069
NAME78=R325
VALUE78=83327
NAME79=R326
VALUE79=83465
NAME80=R327
VALUE80=83714
NAME81=R328
VALUE81=83973
NAME82=R329
VALUE82=84293
NAME83=R330
VALUE83=84482
NAME84=R331
VALUE84=84736
NAME85=R332
VALUE85=85092
NAME86=R333
VALUE86=85248
NAME87=R334
VALUE87=85696
NAME88=R335
VALUE88=85887
NAME89=R336
VALUE89=86016
NAME90=R337
VALUE90=86274
NAME91=R338
VALUE91=86528
NAME92=R339
VALUE92=86784
NAME93=R340
VALUE93=87072
NAME94=R341
VALUE94=87296
NAME95=R342
VALUE95=87672
NAME96=R343
VALUE96=87808
NAME97=R344
VALUE97=88214
NAME98=R345
VALUE98=88320
NAME99=R346
VALUE99=88640
NAME100=R347
VALUE100=89044
NAME101=R348
VALUE101=89120
NAME102=R349
VALUE102=89344
NAME103=R350
VALUE103=89600
NAME104=R351
VALUE104=89867
NAME105=R352
VALUE105=90112
NAME106=R353
VALUE106=90369
NAME107=R354
VALUE107=90692
NAME108=R355
VALUE108=90880
NAME109=R356
VALUE109=91136
NAME110=R357
VALUE110=91402
NAME111=R369
VALUE111=94634
NAME112=R370
VALUE112=94722
NAME113=R380
VALUE113=97304
NAME114=R381
VALUE114=97655
NAME115=R358
VALUE115=91648
NAME116=R359
VALUE116=91904
NAME117=R360
VALUE117=92200
NAME118=R361
VALUE118=92505
NAME119=R362
VALUE119=92704
NAME120=R363
VALUE120=92928
NAMES121=R364
VALUE121=93184
NAME122=R365
VALUE122=93440
NAME123=R366
VALUE123=93715
NAME124=R371
VALUE124=94976
NAME125=R8189
VALUE125=2096384
NAME126=R8190
VALUE126=2096640
NAME127=R8191
VALUE127=209979
[灵活]
bSetFeedback_CLKin1=CLKin1 (外部)
bSetFeedback_DCLKout6=DCLKout6
bSetFeedback_DCLKout8=DCLKout8
bSetFeedback_SYSREFDIV=SYSREF 分频器
bSetJESD204B_Continuous=连续
bSetJESD204B_NoJESD204B_withoutSYSREFDivider =无 JESD204B
bSetJESD204B_Pulser=脉冲发生器
bSetJESD204B_Reclocked=经过时钟恢复
bSetJESD204B_SYSREFREQ=SYSREF 请求
bSetMode_Distribution =设置分发
bSetMode_DualLoop =设置双环路
bSetMode_DualLoop0DelayCasced=设置双环路0延迟级联
bSetMode_DualLoop0DelayNined=Set 双环路0延迟嵌套
bSetMode_SingleLoop =设置单环路
bSetMode_SingleLoop0Delay=设置单环路0延迟
BSET_CLKin0toOff = CLKin0关闭
BSET_CLKin0toPLL1=CLKin0驱动 PLL1
BSET_CLKin0toSYSREF=CLKin0驱动 SYNC/SYSREF
BSET_CLKin0toSYSREF_DIRECT = CLKin0驱动 SYNC/SYSREF Direct
BSET_CLKin1_ExternalVCO=CLKin1驱动时钟分配(外部 VCO/分配模式)
BSET_CLKin1toOff = CLKin1关闭
BSET_CLKin1toPLL1=CLKin1驱动 PLL1
PLL1的 BSET_CLKin2_Input = CLKin2
CLKDIST_FREQ=2457.6.
CLKin0_FREQ=15.36
CLKin1_FREQ=122.88
CLKIN2_FREQ=153.6
CLKIN_SEL_AUTOPINSMODE=0
EXT_VCXO_FREQ=30.72
FB_MUX_FREQ=1228.8
FB_MUX_FREQ_MHz=
OSC_FREQ=30.72
OSCin_SOURCE=0
PLL1_PD_FREQ=0.48
PLL2_PD_FREQ=30.72
PLL_FBMUX_WARNING_TEXT =
pll_warning_text=
WARNING_TEXT_PLL1=
WARNING_TEXT_PLL2=
SYSREF_FREQ=9.6
bSYNC_DIS_AllOff =全部关闭
bSYNC_DIS_Allon =全部打开
bSYNC_DIS_CLKOFF = DC 关闭
bSYNC_DIS_CLKON=DC 打开
bSYNC_Dividers=同步分频器
bSendPulsesViaSPI=发送脉冲
bSetJESD204B_RX_CLKin0=CLKin0
bSetJESD204B_RX_CLKin0_Bypass = CLKin0旁路
bSetJESD204B_RX_Ignore =无
bSetJESD204B_RX_Reclocked=重新计时
bSetJESD204B_RX_SYNCPIN=SYNC 引脚
bSetSYNC_Normal=正常
stSYSREF_CLR_WARNing=
CLKout0_FREQ=153.6
CLKout10_FREQ=1228.8
CLKout11_FREQ=9.6
CLKout12_FREQ=1228.8
CLKout13_FREQ=9.6
CLKout1_FREQ=9.6
CLKout2_FREQ=76.8
CLKout3_FREQ=9.6
CLKout4_FREQ=307.2
CLKout5_FREQ=9.6
CLKout6_FREQ=1228.8
CLKout7_FREQ=9.6
CLKout8_FREQ=1228.8
CLKout9_FREQ=9.6
OSCout_FREQ=30.72
SDCLKout11_text=
SDCLKout13_text=
SDCLKout1_text=
SDCLKout3_text=
SDCLKout5_text=
SDCLKout7_text=
SDCLKout9_text=
SYSREF_FREQ=9.6
谢谢你。
    您好、Henry、
    为了获得 SYSREF 时钟输出、除了正确的寄存器设置外、还需要一个正确的编程序列。
    请查看 EVM 用户指南第2.2节以获取示例。
