[FAQ] [参考译文] [常见问题解答] TI-API:v2备货出货前通知(ASN) API 错误代码和含义(第1部分、共2部分)
Guru**** 536590 points
https://e2e.ti.com/support/enterprise-automation-integration-group/enterprise-automation-integration/f/enterprise-automation-integration-forum/1216644/faq-ti-api-v2-backlog-advanced-ship-notice-asn-api-error-codes-and-meanings-part-1-of-2
器件型号:TI-API
v2 ASN API 错误代码意味着什么?
    场景 错误详细信息 补救步骤
    缺少标识符
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0010",
    			"type": "ERROR",
    			"reason": "Missing Identifier",
    			"message": "The identifier customerPurchaseOrderNumber, wayBillNumber, or orderNumber cannot be null or empty.  Enter a valid Identifier and resubmit request."
    标识符不能为空或空。 输入一个有效的 customerPurchaseOrderNumber、wayBillNumber 或 OrderNumber、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持(api-portal.ti.com/support)。
    只需要一个标识符
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0011",
    			"type": "ERROR",
    			"reason": "Only One Identifier Required",
    			"message": " Only one of the identifiers customerPurchaseOrderNumber, wayBillNumber, or orderNumber is required. Enter only one of the valid Identifiers and resubmit request."
    只需要一个标识符。 输入以下有效标识符之一:customerPurchaseOrderNumber 或 wayBillNumber 或 OrderNumber、然后重新提交请求。 如果需要更多帮助、请联系 TI API 支持(api-portal.ti.com/support)。
    无效的 requestCommercialInvoicePDF 或 requestWaybillPDF
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0040",
    			"type": "ERROR",
    			"reason": "Invalid requestCommercialInvoicePDF or requestWaybillPDF",
    			"message": " requestCommercialInvoicePDF or requestWaybillPDF – X must have value of either true or false. Field will default to false."
    如果需要 PDF、则 requestCommercialInvoicePDF 或 requestWaybillPDF 值必须为 true 或 false。 输入 X 以接收 PDF;否则该字段将默认为 false。 如果需要更多帮助、请联系 TI API 支持(api-portal.ti.com/support)。
    TI API 不可用于计划的系统维护
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0500",
    			"type": "ERROR",
    			"reason": "TI API unavailable for scheduled system maintenance",
    			"message": " This TI API is currently unavailable due to system maintenance. Please resubmit the request after maintenance is completed or contact TI API Support (https://api-portal.ti.com/support) for more information."
    TI 服务器维护正在进行中、目前不可用。 尝试稍后重新提交申请。 如果问题仍然存在、请联系 TI 客户支持(提交请求)。
    找不到 customerPurchaseOrderNumber 的货件数据
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-020",
    			"type": "ERROR",
    			"reason": "No shipment data found with customerPurchaseOrderNumber",
    			"message": "Verify and correct the customerPurchaseOrderNumber or use the orderNumber or wayBillNumber and resubmit request."
    未找到发货数据。 输入有效的 customerPurchaseOrderNumber、或使用 OrderNumber 或 wayBillNumber。 只有完成的订单才具有可用的发货数据。 如果需要更多帮助、请联系 TI API 支持(api-portal.ti.com/support)。
    未找到订单号的发货数据
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0021",
    			"type": "ERROR",
    			"reason": "No shipment data found with orderNumber",
    			"message": "Verify and correct the orderNumber or use the customerPurchaseOrderNumber or wayBillNumber and resubmit request."
    未找到发货数据。 输入有效的 OrderNumber、或使用 customerPurchaseOrderNumber 或 wayBillNumber。 只有完成的订单才具有可用的发货数据。 如果需要更多帮助、请联系 TI API 支持(api-portal.ti.com/support)。
    未找到 BillwayNumber 的发货数据
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0022",
    			"type": "ERROR",
    			"reason": "No shipment data found with wayBillNumber",
    			"message": "Verify and correct the wayBillNumber or use the customerPurchaseOrderNumber or orderNumber and resubmit request."
    未找到发货数据。 输入有效的 wayBillNumber、或使用 customerPurchaseOrderNumber 或 OrderNumber。 只有完成的订单才具有可用的发货数据。 如果需要更多帮助、请联系 TI API 支持(api-portal.ti.com/support)。
    发货仍在进行中
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0023",
    			"type": "ERROR",
    			"reason": "Shipment in process, ASN information unavailable at this time",
    			"message": "Shipment information is unavailable at this time. Please try again at a later time."
    由于装运仍在进行中、未找到装运数据。 请稍后再试。 如果需要更多帮助、请联系 TI API 支持(api-portal.ti.com/support)。
    发货已完成、ASN 目前不可用
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0024",
    			"type": "ERROR",
    			"reason": "Shipment complete, ASN information unavailable",
    ASN 信息尚未就绪。 请稍后再试。 如果需要更多帮助、请联系 TI API 支持(api-portal.ti.com/support)。
    soldToAccountNumber 无效
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0030",
    			"type": "ERROR",
    			"reason": "Invalid soldToAccountNumber",
    			"message": " soldToAccountNumber is incorrect.  Verify and correct the soldToAccountNumber and resubmit request."
    soldToAccountNumber 无效。 输入有效的 soldToAccountNumber。 如果需要更多帮助、请联系 TI API 支持(api-portal.ti.com/support)。
    缺少 soldToAccountNumber
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0031",
    			"type": "ERROR",
    			"reason": "Missing soldToAccountNumber",
    			"message": "The soldToAccountNumber cannot be null or empty. Enter a valid soldToAccountNumber and resubmit request."
    缺少 soldToAccountNumber、不能为空或空。 输入有效的 soldToAccountNumber、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持(api-portal.ti.com/support)。
    缺少业务合作伙伴的 soldToAccountNumber
    	"errors": [
    			"errorCode": "ERR-BKG-ASNR-API-0032",
    			"type": "ERROR",
    			"reason": "Missing business partner's soldToAccountNumber",
    			"message": "The Business Partner's soldToAccountNumber cannot be null or empty.  Enter a valid soldToAccountNumber and resubmit request."
    业务合作伙伴的 soldToAccountNumber 缺失、不能为空或空。 输入有效的业务合作伙伴的 soldToAccountNumber、然后重新提交申请。 如果需要更多帮助、请联系 TI API 支持(api-portal.ti.com/support)。
    缺少业务合作伙伴
    	"errors": [
    			"type": "ERROR",
    			"reason": "Missing business partner",
    			"message": "Business Partner cannot be null or empty.  Enter a valid Business partner and resubmit request."
    业务合作伙伴缺失、不能为空或为空。 输入有效的业务合作伙伴并重新提交申请。 如果需要更多帮助、请联系 TI API 支持(api-portal.ti.com/support)。
    查看 v2备货出货前通知(ASN) API 错误代码和含义(第2部分、共2部分)
