[参考译文] 电源管理论坛
Guru**** 2465890 points
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1516238/power-management-forum
器件型号:bq20z45
敬啟者 μ s、
請問這個電池為何充電開始後一段時間才開始累計Remaining capacity容量?
電池為2s1p 7.4V 5100mA、ID 0128
日志文件 及DF gg file如附。
e2e.ti.com/.../0128.log
[标题]
BQ EVSW 版本= 0.9.92
DeviceName = bq20z45R1R1 v1.07
Time = 2025/5/19下午05:35:22
[电压(一级安全)]
LT COV 阈值= 0
LT COV Recovery = 0
ST COV 阈值= 0
ST COV 恢复= 0
HT COV 阈值= 0
HT COV 恢复= 0
CUV 阈值= 0
CUV 时间= 0
CUV Recovery = 0
[当前(一级安全)]
OC (第1层) Chg = 0
OC (第1层) DSG = 0
OC (第1层) DSG Time = 0
电流恢复时间= 0
AFE OC DSG = 00
AFE OC DSG Time = 00
AFE SC Chg Cfg = 00
AFE SC DSG Cfg = 00
[温度(一级安全)]
OT1 Chg 阈值= 0.0
OT1 Chg Time = 0
OT1 Chg Recovery = 0.0
OT2 Chg 阈值= 0.0
OT2 Chg Time = 0
OT2 Chg Recovery = 0.0
OT1 DSG 阈值= 0.0
OT1 DSG 时间= 0
OT1 DSG Recovery = 0.0
OT2 DSG 阈值= 0.0
OT2 DSG Time = 0
OT2 DSG Recovery = 0.0
HI Dsg Start Temp = 0.0
[电压(二级安全)]
LT SOV 阈值= 0
ST SOV 阈值= 0
HT SOV 阈值= 0
SOV 时间= 0
PF SOV 保险丝熔断延迟= 0
SUV 阈值= 0
SUV Time = 0
其余 CIM 电流= 0
REST CIM 故障电压= 0
REST CIM 时间= 0
CIM 电池休息时间= 0
REST CIM 检查电压= 0
有效 CIM 故障电压= 0
活动 CIM 时间= 0
有效 CIM 检查电压= 0
PFIN 检测时间= 0
PF 最小保险丝熔断电压= 0
[当前(二级安全)]
SOC Chg = 0
SOC Chg Time = 0
SOC DSG = 0
SOC DSG Time = 0
[温度(二级安全)]
SOT1 Chg 阈值= 0.0
SOT1 Chg Time = 0
SOT2 Chg 阈值= 0.0
SOT2 Chg Time = 0
SOT1 DSG Threshold = 0.0
SOT1 DSG Time = 0
SOT2 DSG 阈值= 0.0
SOT2 DSG 时间= 0
[ FET 验证(二级安全)]
FET 失效时间= 0
[ AFE 验证(二级安全)]
AFE Check Time = 0
AFE 失败限制= 0
AFE FAIL Recovery Time (AFE 失败恢复时间)= 0
[充电温度配置(充电控制)]
JT1 = 0.0
JT2 = 0.0
JT2a = 0.0
JT3 = 0.0
JT4 = 0.0
温度 HYS = 0.0
[预充电配置(充电控制)]
PRE-CHG 电压阈值= 0
CHG 前恢复电压= 0
预 CHG 电流= 0
[充电配置(充电控制)]
LT Chg Voltage = 0
LT Chg Current1 = 0
LT Chg Current2 = 0
LT Chg Current3 = 0
ST1 Chg Voltage = 0
ST1 Chg Current1 = 0
ST1 Chg Current2 = 0
ST1 Chg Current3 = 0
ST2 Chg Voltage = 0
ST2 Chg Current1 = 0
ST2 Chg Current2 = 0
ST2 Chg Current3 = 0
HT Chg 电压= 0
HT Chg Current1 = 0
HT Chg Current2 = 0
HT Chg Current3 = 0
电芯电压阈值1 = 0
电芯电压阈值2 = 0
电芯电压阈值 HYS = 0
[终止配置(充电控制)]
收尾电流= 0
收尾电压= 0
TCA 清除百分比= 0
FC 清除%= 0
[电芯均衡配置(充电控制)]
最小电芯偏差= 0
[充电故障(充电控制)]
过度充电容量= 0
充电故障配置= 00
[数据(SBS 配置)]
REM 电容警报= 0
REM 能量警报= 0
REM 时间警报= 0
初始化电池模式= 0000
Design Voltage = 0
规格信息= 0000
提前感谢您的支持。
JHT/Alan
    您好、JHT/Alan、
    您能否在要点格式上写下您面临的问题?
    谢谢您、
    Alan
    张先生、
    我无法帮助你,直到我了解你所面临的问题,它似乎你给我你的.gg 文件副本和粘贴,但这并不告诉我你所面临的问题. 请以要点格式列出您所面临的问题。
    谢谢您、
    Alan
    您好 Alan、
    還是謝謝您 μ s。
    我們會將問題整理後另外再行提問 μ s。
    B/R
    Alan
