[参考译文] LM5069:如果 LM5069 损坏、是否可能无法关断 MOSFET?
Guru**** 2507255 points
Other Parts Discussed in Thread: LM5069
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1551399/lm5069-if-the-lm5069-is-damaged-is-it-possible-that-it-cannot-turn-off-the-mosfet
器件型号:LM5069
您好的团队、
保护功能可能已损坏?
    是的、可能会发生这种情况。
