[参考译文] UCC29002:与外部 PSI 共享电流
Guru**** 2504505 points
Other Parts Discussed in Thread: UCC29002, UCC39002
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1135469/ucc29002-current-sharing-with-external-psi
器件型号:UCC29002
主题中讨论的其他器件: UCC39002
在寻找 UCC29002、UCC39002和 UCC29002/1一个小时后、我们认为这是我们首先提出的要求。
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1135461/ucc29002-can-the-ucc29002-be-used-to-parallel-one-commercial-power-supply-and-one-power-supply-made-with-discrete-components
 我们需要有关此问题的帮助或更多信息。
提前感谢。
