[参考译文] TLV62568A:开关电流限制响应时间
Guru**** 2511985 points
Other Parts Discussed in Thread: TLV62568A
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/920666/tlv62568a-switch-current-limit-response-time
器件型号:TLV62568A
您好、先生、
触发 TLV62568A 的"开关电流限制"的响应时间有多短?
    您好、FuGang、
    电流限制的传播延迟通常 仅为几纳秒。
    Excel
