[参考译文] BQ24045:BQ24045 TS 问题
Guru**** 2504535 points
Other Parts Discussed in Thread: BQ24045
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/812985/bq24045-bq24045-ts-question
器件型号:BQ24045
  BQ24045的 TS 引脚上是否有内部(位于器件内部)上拉电阻器? 如果是、精度是多少?
