我按照 software-dl.ti.com/.../Release_Specific_Release_Notes.html上的指示操作
使用“~”/tisdk/configs/processor-sdk-linux/processor-sdk-linux-08_01_00.txt config和“machine=am64xx-EVM bitbake tisdk-base-image”可以提供以下输出:
警告:onnxruntime-url.0-r0_psdkla_3 do_fetch:无法获取1.7 git://github.com/onnx/onnx-tensorrt;protocol=https;branch=master;destsuffix=~/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/onnxruntime/1.7 url.0-r0_psdkla_3/git/cmake/external/onnx-tensorrt;name=cmake-external-onnx-tensorrt,正在尝试镜像(如果可用)
错误:onnxruntime-1.7 .0-r0_psdkla_3 do_fetch:fetcher故障:即使从上游,也无法在分支主机中找到修订版dc22bb323ece3c6541.9717万be8a0d3d0f318a61fa
错误:onnxruntime-1.7 url.0-r0_psdkla_3 do_fetch:Bitbake Fetcher错误:FetchError('无法从任何源获取url.','git://github.com/onnx/onnx-tensorrt;protocol=https;branch=master;destsuffix=~/tisdk/build/arago-tmp-external-arm-glibc/work/aarch64-linux/onnxruntime/1.7 url.0-r0_psdkla_3/git/cmake /external/onnx-tensorrt;name=nontrt -
错误:故障日志文件存储在以下位置:~/tisdk/build/arago-tmp-external_arm-glibc/work /Aarch64-linux/onnxruntime / 1.7 .0-r0_psdkla_3/temp/log.do_fetch.4551
错误:任务(~/tisdk/sources/meta-psdkla/fipes-core/packagegroups/onnxruntime.bb:do_fetch)失败,退出代码为'1'
注意:任务摘要:尝试执行2768个任务,其中2627个任务不需要重新运行,1个任务失败。
注意:正在编写buildhistory
注:写入buildhistory需要1秒
注意:正在编写buildhistory
摘要:1个任务失败:
~/tisdk/sources/meta-psdkla/fipmes-core/packagegroups/onnxruntime.bb:do_fetch
摘要:显示了7条警告消息。
摘要:显示了172条错误消息,返回非零退出代码。
尝试按照 https://e2e.ti.com/support/processors-group/processors/f/processors-forum/107.2575万/j7expcxevm-building-of-tisdk-fails-due-to-fetch-from-incorrect-git-repo-branch-name/3969162中396.9162万中的建议,通过 更改/tisdk/sources/meta-psdkla/fecus-core/packagegroups/onnxruntime.bb来选择commit,如下所示:
git diff onnxruntime.bb
diff --git a/cipese-core/packagegroups/onnxrunruntime.bb b/cipese-core/packagegroups/onnxruntime.bb
索引c8fef5f..bc36d2710.0644万
-- a/cipse-core/packagegroups/onnxruntime.bb
+++ b/pipnes-core/packagegroups/onnxruntime.bb
@@-52,7+52,7 @@ LIC_FILE_CHKSUM ="file://license;MD5=0f7e3b1308cb5c00b372a6e78835732d \7883.5732万 \
文件://cdm/external/FeaturesLibrary/src/3rdParty/RE2/license;md5=3b5c31eb512bdf3cb11ffd5713963760 \
-SRC_URI ="git://github.com/microsoft/onnxruntime;protocol=https;branch=master;name=base \
+SRC_URI ="git.ti.com/gitweb \
Git://github.com/gabime/spdlog;protocol=https;branch=v2.x;destsuffix=${S}/server/external/spdlog;name=server-external-spdlog \
Git://github.com/apple/coremltools;protocol=https;branch=main;destsuffix=${S}/cmake/external/coremltools;name=cmake-external-coremltools \
Git://github.com/microsoft/onnxruntime-tvm;protocol=https;branch=nuphar;destsuffix=${S}/cmake/external/tvm;name=cmake-external-tvm \
将生成以下输出:
警告:onnxruntime-url.0-r0_psdkla_3 do_fetch:无法获取1.7 git.ti.com/gitweb,正在尝试镜像(如果可用)
错误:onnxruntime-1.7 .0-r0_psdkla_3 do_fetch:URL为'git.ti.com/gitweb的提取器失败。 fetch命令返回URL git.ti.com/gitweb的成功, 但~ë/tisdk/downloads/meta-psdkla.git不存在?!
错误:onnxruntime-1.7 url.0-r0_psdkla_3 do_fetch:Bitbake Fetcher错误:FetchError('无法从任何源获取url.','git.ti.com/gitweb
错误:故障日志文件存储在以下位置:~/tisdk/build/arago-tmp-external_arm-glibc/work /Aarch64-linux/onnxruntime / 1.7 .0-r0_psdkla_3/temp/log.do_fetch.1.7693万
注意:任务摘要:尝试了2251项任务,其中2206项无需重新运行,1项失败。
注意:正在编写buildhistory
注意:正在编写buildhistory
摘要:1个任务失败:
摘要:显示了5条警告消息。
摘要:显示2条错误消息,返回非零退出代码。
索引c8fef5f..b0.9524万f 10.0644万
@@-52,7+52,9 @@ LIC_FILE_CHKSUM ="file://license;MD5=0f7e3b1308cb5c00b372a6e78835732d \7883.5732万 \
+ 文件://0001-DO-not-strip-pdata_tools-at-DO-install.patch \
+ 文件://use-sh-on路径.patch \
@@-224,7 + 226,7 @@ Extra _OECMAKE ="\
-Donnxruntime使用Tidl=on \
-DO安装(){
+DO安装(){
cmake操作安装
安装-d ${B}/docs/python
失败如下:
错误:故障日志文件存储在以下位置:~/tisdk/build/arago-tmp-external_arm-glibc/work /Aarch64-linux/onnxruntime / 1.7 .0-r0_psdkla_3/temp/log.do_fetch.1.7101万
注意:任务摘要:尝试执行2704项任务,其中2666项无需重新运行,1项失败。
注意:正在编写buildhistory
注意:正在编写buildhistory
摘要:1个任务失败:
摘要:显示了9条警告消息。
如何构建SDK? 是否有可用的修复程序?
