主题中讨论的其他部件:UNIFLAASH, MSP-FET
您好,Champs:
安装并启动uniflash工具7.1 后,
Ubuntu会告诉我这些错误。
如何解决?
BR Rio
(设置:9915):iBus-warning **:23:00: 04.576 :/home/Rio/.config/iBus/bus的所有者不是root!
根@ubuntu:/opt/#[1.0146万:10169:0228/UNIX:error:bus.cc(397)]无法1.0169万无法连接0228连接到总线:无法解析服务器地址:未知地址类型(有效类型的示例为"TCP"和23.0254万.338721</xmt-block>33.8721万 "UNIX")
[1.0146万:10169:0228/UNIX:ERROR:bus.cc(397)]无法1.0169万无法连接0228连接到总线:无法解析服务器地址:未知地址类型(有效类型的示例为"TCP"和23.0254万.338845</xmt-block>33.8845万 "UNIX")
[1.0146万:10169:0228/UNIX:ERROR:bus.cc(397)]无法1.0169万无法连接0228连接到总线:无法解析服务器地址:未知地址类型(有效类型的示例为"TCP"和23.0254万.471959</xmt-block>47.1959万 "UNIX")
[1.0146万:10169:0228/UNIX:ERROR:bus.cc(397)]无法1.0169万无法连接0228连接到总线:无法解析服务器地址:未知地址类型(有效类型的示例为"TCP"和23.0254万.474622</xmt-block>47.4622万 "UNIX")
[1.0194万:10194:0228/REAL:nw_content_render_hooks.cc(53)]<xmt-block0>1.0194万 230254.7778810228 230254.777881</xmt-block>23.0254万 无法77.7881万 无法加载节点库(错误:libatomicon.so.1:无法打开共享目标文件:无此类文件或目录)
#0 0x7fa1803ce463 (/opt/ti/uniflash 7.1 .0/node-webkit/lib/libnw.so+0x57b5462)
#1 0x7fa1803e1a8e (/opt/ti/uniflase_webkit/lib/libnw.so+0x57c8a8d 7.1)
#2 0x7fa18.5317万ec5 (/opt/ti/uniflase_webkit/lib/libnw.so+0xa6feec4 7.1)
#3 0x7fa1.8537万e1c2 (/opt/ti/uniflase_webkit/lib/libnw.so+0xa7651c1 7.1)
#4 0x7fa17ff397f6 (/opt/ti/uniflash 7.1 .0/node-webkit/lib/libnw.so+0x5.3207万f5)
#5 0x7fa17ff36f26 (/opt/ti/uniflash 7.1 .0/node-webkit/lib/libnw.so+0x531df25)
#6 0x7fa17ff37a9b (/opt/ti/uniflase_webkit/lib/libnw.so+0x531ea9a 7.1)
#7 0x7fa17cc6f866 ChromeMain
#8 0x7fa17a8.0109万b __libc_start_main
碰撞键:
"SWITCH-19"="--user-data-dir=/home/Rio/.config/Uniflash "
"SWITCH-18"="--enable-crashpad"
"switch-17"="--shared-files=v8_context_snapshot_data:100"
"SWITCH-16"="--launch-Time-ticks=1124384130"
"SWITCH-15"="--render-client-id=5"
"switch-14"="--num-raster-threads=1
"switch-13"="--lang=en-US"
"SWITCH-12"="--field-trial手柄=11.7342万78632836316258,15781706659671034314.1"</s>78.6328万 36.3162万5.8157万81.7066万59.671万3.4314万
"SWITCH-11"="--no-zygote"
"SWITCH-10 ="--NO-SANDBOX "
"switch-9"="--change-stack-guard-on-fork =启用"
"SWITCH-8"="--display-capture权限-police-allowed"
"SWITCH-7"="--EXTENSION -PROCESS "
"SWITCH-6"="--nwjs"
"SWITCH-5"="--nwapp-path=/opt/ti/unifliflash 7.1 .0"
"SWITCH-4"="--user-data-dir=/home/Rio/.config/Uniflash "
"switch-3"="--enable-crash-reReporter =,"
"switch-2"="--crashpad-handler-pid=1.0152万"
"SWITCH-1"="--enable-crashpad"
"num-switchs"="20"
"osarch"="x86_64
"PID"="1.0194万"
"ptype ="渲染器"
[0228/POST:ERROR:FILE_IO_POSIX.cc(144)] 23.0254万.789769</xmt-block>78.9769万 OPEN /sys/devices/system/CPU0/cpufreq/scaling_cur_freq:无此类文件或目录(2)
[0228/POST:ERROR:FILE_IO_POSIX.cc(144)] 23.0254万.789858</xmt-block>78.9858万 OPEN /sys/devices/system/cpu0/cpufreq/scaling_max_freq:没有这样的文件或目录(2)
接收到信号6.
#1 0x7fa1.80464321亿 (/opt/ti/unifliflash 7.1 .0/node-webkit/lib/libnw.so+0x584b320)
#2 0x7fa17abf1dd0 (/lib/x86_64-linux-gnu/libpthread-2.28 .so+0x12dcf)
#3 0x7fa1803e1f17 (/opt/ti/uniflash 7.1 .0/node-webkit/lib/libnw.so+0x57c8f16)
#4 0x7fa18.5317万ec5 (/opt/ti/uniflase_webkit/lib/libnw.so+0xa6feec4 7.1)
#5 0x7fa1.8537万e1c2 (/opt/ti/uniflase_webkit/lib/libnw.so+0xa7651c1 7.1)
#6 0x7fa17ff397f6 (/opt/ti/uniflash 7.1 .0/node-webkit/lib/libnw.so+0x5.3207万f5)
#7 0x7fa17ff36f26 (/opt/ti/unifliflash 7.1 .0/node-webkit/lib/libnw.so+0x531df25)
#8 0x7fa17ff37a9b (/opt/ti/uniflase_webkit/lib/libnw.so+0x531ea9a 7.1)
#9 0x7fa17cc6f866 ChromeMain
#10 0x7fa17a8.0109万b __libc_start_main
R8:0万00000000 R90万 R9:0.0007万ffc17a35ae0 R10:0万00000008 r110.0008万 r11:0万00000246</s>0.0246万
r12:0000000000b6 r13:0.0007万ffc17a36e00 r14:0.0007万ffc17a36e10 r15:0.0007万ffc17a36e18
DI:0万00000002 si0.0002万 si:0.0007万ffc17a35ae0 bp:0.0007万ffc17a35d30 bx:0.0007万ffc17a35d41
dX: 0万00000000 ax:0万 ax: 00000000000000000000 cx: 00007fa17a81e077 sp: 00007ffc17a35ae0
IP:0.0007万fa17a81e077 EFL:0万00000246 CGF0.0246万 CGF:002b0万000033 erf0.0033万 erf:0万000000000000000000</s>0万 0万0万
TRP:0万00000000 MSK0万 MSK:0万00000000 cr20万 cr2:00000000000000000000
[堆栈跟踪结束]
[1.0195万:10195:0228/REAL:nw_content_render_hooks.cc(53)]<xmt-block0>1.0195万 230254.8321030228 230254.832103</xmt-block>23.0254万 无法83.2103万 无法加载节点库(错误:libatomicon.so.1:无法打开共享目标文件:无此类文件或目录)
#0 0x7f42fa1d7463 (/opt/ti/uniflash 7.1 .0/node-webkit/lib/libnw.so+0x57b5462)
#1 0x7f42fa1ea8e (/opt/ti/uniflase_webkit/lib/libnw.so+0x57c8a8d 7.1)
2 0x7f42ff120ec5 (/opt/ti/uniflase_webkit/lib/libnw.so+0xa6feec4 7.1)
#3 0x7f42ff1871c2 (/opt/ti/uniflase_webkit/lib/libnw.so+0xa7651c1 7.1)
#4 0x7f42f9d427f6 (/opt/ti/uniflash 7.1 .0/node-webkit/lib/libnw.so+0x5.3207万f5)
#5 0x7f42f9d3ff26 (/opt/ti/uniflash 7.1 .0/node-webkit/lib/libnw.so+0x531df25)
#6 0x7f42f9d40a9b (/opt/ti/uniflase_webkit/lib/libnw.so+0x531ea9a 7.1)
#7 0x7f42f6a7.8866万 ChromeMain
#8 0x7f42f460a09b __libc_start_main
碰撞键:
"SWITCH-16"="--launch-Time-ticks=1124417890"
"SWITCH-15"="--render-client-id=6"
"SWITCH-6"="--nwjs"
"num-switchs"="20"
"osarch"="x86_64
"PID"="1.0195万"
"ptype ="渲染器"
[0228/POST:ERROR:FILE_IO_POSIX.cc(144)] 23.0254万.917153</xmt-block>91.7153万 OPEN /sys/devices/system/CPU0/cpufreq/scaling_cur_freq:无此类文件或目录(2)
[0228/POST:ERROR:FILE_IO_POSIX.cc(144)] 23.0254万.919601</xmt-block>91.9601万 OPEN /sys/devices/system/cpu0/cpufreq/scaling_max_freq:没有这样的文件或目录(2)
接收到信号6.
#1 0x7f42fa26d321 (/opt/ti/uniflash 7.1 .0/node-webkit/lib/libnw.so+0x584b320)
#2 0x7f42f49fadd0 (/lib/x86_64-linux-gnu/libpthread-2.28 .so+0x12dcf)
#3 0x7f42fa1eaf17 (/opt/ti/uniflash 7.1 .0/node-webkit/lib/libnw.so+0x57c8f16)
#4 0x7f42ff120ec5 (/opt/ti/uniflase_webkit/lib/libnw.so+0xa6feec4 7.1)
#5 0x7f42ff1871c2 (/opt/ti/uniflase_webkit/lib/libnw.so+0xa7651c1 7.1)
#6 0x7f42f9d427f6 (/opt/ti/uniflash 7.1 .0/node-webkit/lib/libnw.so+0x5.3207万f5)
#7 0x7f42f9d3ff26 (/opt/ti/uniflash 7.1 .0/node-webkit/lib/libnw.so+0x531df25)
#8 0x7f42f9d40a9b (/opt/ti/uniflase_webkit/lib/libnw.so+0x531ea9a 7.1)
#9 0x7f42f6a7.8866万 ChromeMain
#10 0x7f42f460a09b __libc_start_main
R8:0万00000000 R90万 R9:0.0007万ffe99941b20 R109.9941万 R10:00000000000000000008 r11:0万00000246</s>0.0246万
r12:0亿b6 r13:00007ffe99942e40 r149.9942万 r14:0.0007万ffe99942e50 r159.9942万 r15:0.0007万ffe99942e58</s>9.9942万
DI:0万00000002 si0.0002万 si:00007ffe99941b20 bp9.9941万 bp:0.0007万ffe99941d70 bx9.9941万 bx:0.0007万ffe99941d81</s>9.9941万
dX: 0万00000000 ax:0万 ax: 00000000000000000000 cx: 00007f42f4627077 sp:4627077 sp: 00007ffe99941b20</s>99941
IP:0.0007万f42f4627077 EFL4627077 EFL:0万00000246 CGF0.0246万 CGF:002b0万000033 erf0.0033万 erf:0万000000000000000000</s>0万 0万0万
[堆栈跟踪结束]
[1.0146万:10172:0228/Bluetooth:error:chrome<xmt-block0>1.0172万 230259.0133830228 230259.013383</xmt-block>23.0259万 browser_main_exa_parts_metrics.cc(227)]1.3383万 browser_main_exa_parts_metrics.cc(227)] start: ReportBluetoothAvailability()。 如果没有看到“End:(结束:)”消息,则这是crbug.com/121.6328万。
[1.0146万:10172:0228/Bluetooth:error:chrome<xmt-block0>1.0172万 230259.0135770228 230259.013577</xmt-block>23.0259万 browser_main_exa_parts_metrics.cc(230)]1.3577万 browser_main_exa_parts_metrics.cc(230)]结束:ReportBluetoothAvailability()
[1.0183万:10189:0228/AIA:error:cert_verify_proc_builtin.cc(600)]没有1.0189万没有用于0228用于执行23.0356万.547030</xmt-block>54.703万 追踪的net_fetcher。
^C
root@ubuntu:/o
