您好、TI!
在将 target_platform 构建为 PC 的同时、我们可以在 ti_dl/test/文件夹中看到 PC_DSP_TEST_dl_algo.out 二进制文件。
当我们为 target_platform 构建为 TI_device 时、我们遇到了错误。
======== MAKING IMPORT TOOL PROTOS LIB ================= make -C ./ti_dl/utils/tidlModelImport -f makefile_lib make[1]: Entering directory '/home/feo1kor/sdk_8_6/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/tidl_j784s4_08_06_00_10/ti_dl/utils/tidlModelImport' compiling ../tfImport/proto_cc/tensorflow/core/framework/device_attributes.pb.cc error: Case insensitivity of options has been deprecated; w must be written as W in future releases error: Option -W is not valid without --use_llvm make[1]: *** [/home/feo1kor/sdk_8_6/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/tidl_j784s4_08_06_00_10/makerules/rules.mk:570: /home/feo1kor/sdk_8_6/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/tidl_j784s4_08_06_00_10/out/j784s4/dsp/algo/release/ti_dl/utils/tidlModelImport/../tfImport/proto_cc/tensorflow/core/framework/device_attributes.pb.obj] Error 1 make[1]: Leaving directory '/home/feo1kor/sdk_8_6/ti-processor-sdk-rtos-j784s4-evm-08_06_01_03/tidl_j784s4_08_06_00_10/ti_dl/utils/tidlModelImport' make: *** [makefile:329: protos] Error 2
SDK 版本:ti-processor-sdk-rtos-j784s4-evm-08_06_01_03
TIDL 版本: tidl_j784s4_08_06_00_10
Build env : Linux
