F28027 连接1.27mm 10p 双排 出现问题
connect能正常连接  下载代码也可以下载  当运行的时候出现以下问题:
Error connecting to the target: Error 0x00001200/-1145 Error during: OCS, Target, Unrecoverable emulation error Sequence ID: 0 Error Code: -1145 Error Class: 0x00001200
Error connecting to the target: Error 0x00001200/-1031 Error during: OCS, Target, Device driver: Problem with the Emulation Controller. It is recommended to RESET EMULATOR. This will disconnect each target from the emulator. The targets should then be power cycled or hard reset followed by an emureset and reconnect to each target. Sequence ID: 0 Error Code: -1031 Error Class: 0x00001200
Error connecting to the target: Error 0x80000200/-1037 Fatal Error during: OCS, PTI_ERR_EMU_CLOSE Error Occured at 0x00000000 Sequence ID: 0 Error Code: -1037 Error Class: 0x80000200
Power Failure on Target CPU: Error 0x80000020/-1037 Fatal Error during: Execution, PTI_ERR_EMU_CLOSE Error Occured at 0x00000000 Sequence ID: 16 Error Code: -1037 Error Class: 0x80000020
Failed to remove the debug state from the target before disconnecting. There may still be breakpoint opcodes embedded in program memory. It is recommended that you reset the emulator before you connect and reload your program before you continue debugging.
Error connecting to the target: Error 0x80000240/-151 Fatal Error during: Initialization, OCS, This error was generated by TI's USCIF driver. SC_ERR_POD_OPEN <-151> This utility failed to open the adapter for a custom emulator. The adapter returned an error. Sequence ID: 0 Error Code: -151 Error Class: 0x80000240
A fatal error occured while attempting to remove the remaining debug state that could not be removed at disconnect. This might have occured because a breakpoint was set at an address that is no longer valid. This behaviour may be turned off in the "Debug Properties" tab in the Customize dialog under the Option menu.
Power Failure on Target CPU: Error 0x00001020/-1145 Error during: Execution, Target, Unrecoverable emulation error Sequence ID: 16 Error Code: -1145 Error Class: 0x00001020
Error connecting to the target: Error 0x80000200/-1031 Fatal Error during: OCS, Device driver: Problem with the Emulation Controller. It is recommended to RESET EMULATOR. This will disconnect each target from the emulator. The targets should then be power cycled or hard reset followed by an emureset and reconnect to each target. Sequence ID: 0 Error Code: -1031 Error Class: 0x80000200
