使用CAP对超声波回响信号检测,并同时使用示波器进行观察,发现示波器波形良好,然而CAP采集的数值Period1会有明显的跳动而且伴有负数值出现
void InitECapture()
ECap1Regs.ECEINT.all = 0x0000; // Disable all capture interrupts
ECap1Regs.ECCLR.all = 0xFFFF; // Clear all CAP interrupt flags
ECap1Regs.ECCTL1.bit.CAPLDEN = 0; // Disable CAP1-CAP4 register loads
ECap1Regs.ECCTL2.bit.TSCTRSTOP = 0; // Make sure the counter is stopped
// Configure peripheral registers
ECap1Regs.ECCTL2.bit.CONT_ONESHT = 0; // 连续模式
ECap1Regs.ECCTL2.bit.STOP_WRAP = 3; // Stop at 4 events
ECap1Regs.ECCTL1.bit.CAP1POL = 0; // Rising edge
ECap1Regs.ECCTL1.bit.CAP2POL = 1; // edge Falling
ECap1Regs.ECCTL1.bit.CTRRST1 = 0; // Difference operation
ECap1Regs.ECCTL1.bit.CTRRST2 = 0; // Difference operation
ECap1Regs.ECCTL2.bit.SYNCI_EN = 0; // disable sync in
ECap1Regs.ECCTL2.bit.SYNCO_SEL = 2; // Pass through
ECap1Regs.ECCTL1.bit.CAPLDEN = 1; // Enable capture units
ECap1Regs.ECCTL2.bit.CAP_APWM=0;
ECap1Regs.ECCTL2.bit.TSCTRSTOP = 1; // Start Counter
ECap1Regs.ECEINT.bit.CEVT4 = 1; // 4 events = interrupt
__interrupt void ecap1_isr(void)
Tst1=ECap1Regs.CAP1;
Tst2=ECap1Regs.CAP2;
Period1=Tst2-Tst1;
ECap1Regs.ECCLR.bit.CEVT4 = 1;
ECap1Regs.ECCLR.bit.INT = 1;
// Acknowledge this interrupt to receive more interrupts from group 4
PieCtrlRegs.PIEACK.all = PIEACK_GROUP4;
