MSP430F437 程序flash空间不足
Other Parts Discussed in Thread: MSP430F437, MSP430F449
MSP430F437总共应该有32Kflash,但是在程序代码为27K时IAR for 430编译器提示错误:
Error[e104]: Failed to fit all segments into specified ranges. Problem discovered in segment CODE. Unable to place 178 block(s) (0x6c44 byte(s) total) in 0x6a10 byte(s) of memory. The problem occurred while processing the segment placement command "-P(CODE)CODE=8000-FFDF", where at the moment of placement the available memory ranges were "CODE:81d0-e9ff,CODE:fe00-ffdf"
请问如何解决此类问题
