My English is not very good and my expression may not be accurate. I hope you can understand. Sorry.
Hardware: TDA4VM
SDK: 0806
My current needs are as follows:
The encoding thread runs at 10fps
The display thread runs at 60fps
The results of my test are as follows:
The encoding thread runs at 10fps, but the display thread cannot run at 60fps. The reasons I found are as follows:
When the encoding thread is opened, the time consumption of the display thread will increase.
The main code for encoding threads:
static vx_status autox_codec_encode(AppCMS_Codec *obj, vx_int32 frame_id) { vx_status status = VX_SUCCESS; AppGraphParamRefPool *enc_pool = &obj->enc_pool; if (frame_id >= APP_BUFFER_Q_DEPTH) { if (frame_id >= enc_pool->bufq_depth) { if (status == VX_SUCCESS && obj->encode == 1) { status = appCodecDeqAppSrc(obj->fifo_id_output); if (status != VX_SUCCESS) { printf("# ERROR: func:%s Error appCodecDeqAppSrc return err. obj->fifo_id_output [%d]\n", __func__,obj->fifo_id_output); } } if (status == VX_SUCCESS) { status = unmap_vx_object_arr(enc_pool->arr[obj->fifo_id_output], enc_pool->map_id[obj->fifo_id_output], obj->sensorObj_num_cameras_enabled); if (status != VX_SUCCESS) { printf("# ERROR: func:%s Error unmap_vx_object_arr[=][=] status:obj->fifo_id_output [%d] obj->appsrc_push_id [%d]\n", __func__,obj->fifo_id_output,obj->appsrc_push_id); } status = VX_SUCCESS; } } if (status == VX_SUCCESS) { status = map_vx_object_arr(enc_pool->arr[obj->appsrc_push_id], enc_pool->data_ptr[obj->appsrc_push_id], enc_pool->map_id[obj->appsrc_push_id], obj->sensorObj_num_cameras_enabled); if (status != VX_SUCCESS) { printf("# ERROR: func:%s Error map_vx_object_arr[*][*] status:obj->fifo_id_output [%d]\n", __func__,obj->fifo_id_output); } status = VX_SUCCESS; } if (status == VX_SUCCESS && obj->encode == 1) { status = appCodecEnqAppSrc(obj->appsrc_push_id); } if (status == VX_SUCCESS) { obj->appsrc_push_id++; obj->appsrc_push_id = (obj->appsrc_push_id >= enc_pool->bufq_depth) ? 0 : obj->appsrc_push_id; } } }
The main code for Display thread:
if (DD_ENABLE_LEFT_Display) { uint32_t num_refs; static int display_node_wait_loops=3; static int msc_out_node_wait_loops=2; if (status == VX_SUCCESS) { if(msc_out_node_wait_loops==0) { status = vxGraphParameterDequeueDoneRef(obj->graph_left, obj->imgMosaicObj_left.output_graph_parameter_index, (vx_reference*)&output_image, 1, &num_refs); if (status != VX_SUCCESS) { printf("vxGraphParameterDequeueDoneRef L q Out error\n"); } status = vxGraphParameterDequeueDoneRef(obj->graph_left, obj->imgMosaicObj_left.inputs[0].graph_parameter_index, (vx_reference*)&output_image, 1, &num_refs); if (status != VX_SUCCESS) { printf("vxGraphParameterDequeueDoneRef L q In error\n"); } } else { msc_out_node_wait_loops--; } } if (status == VX_SUCCESS) { if(display_node_wait_loops==0) { status = vxGraphParameterDequeueDoneRef(obj->graph_left, obj->displayObj_csi_tx_vc0_left.output_graph_parameter_index, (vx_reference*)&output_image, 1, &num_refs); if (status != VX_SUCCESS) { printf("vxGraphParameterDequeueDoneRef L q error\n"); } } else { display_node_wait_loops--; } } ... }
The parts I tested that influence each other are as follows:
If I comment the following code in the coding thread
Then the following code in the display thread takes 6~8ms, and the display thread can run to 60fps
If I enable this part of the code
Then the following code in the display thread will take 10~14ms to compile, then the display thread will not run 60fps
My questions:
Why does this operation of the encoding thread
This will increase the time consumption of this function
