Part Number: MMWCAS-DSP-EVM
下面是串口打印的信息
[IPU1-0] 12.845116 s: ***** IPU1_0 Firmware build time 11:57:12 Mar 24 2023 [IPU1-0] 12.845330 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz> [IPU1-0] 12.847068 s: SYSTEM: System Common Init in progress !!! [IPU1-0] 12.855853 s: SYSTEM: IPC init in progress !!! [IPU1-0] 12.855944 s: SYSTEM: IPCLIB init in progress !!! [IPU1-0] 12.856310 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15... [IPU1-0] 12.856402 s: SYSTEM: IPCLIB: register to [DSP1] event 15... [IPU1-0] 12.856493 s: SYSTEM: IPCLIB: register to [EVE1] event 15... [IPU1-0] 12.856554 s: SYSTEM: IPCLIB: register to [EVE2] event 15... [IPU1-0] 12.856646 s: SYSTEM: IPCLIB: register to [EVE3] event 15... [IPU1-0] 12.856737 s: SYSTEM: IPCLIB: register to [EVE4] event 15... [IPU1-0] 12.856798 s: SYSTEM: IPCLIB init DONE !!! [IPU1-0] 12.856859 s: SYSTEM: Notify init done !!! [IPU1-0] 12.858537 s: SYSTEM: MsgQ init done !!! [IPU1-0] 12.859238 s: SYSTEM: Work Queue init done !!! [IPU1-0] 12.859299 s: SYSTEM: IPC init DONE !!! [IPU1-0] 12.862837 s: SYSTEM: System Common Init Done !!! [IPU1-0] 12.862929 s: SYSTEM: System Init in progress !!! [IPU1-0] 12.862990 s: SYSTEM: BSP Common Init in progress !!! [IPU1-0] 12.863112 s: SYSTEM: BSP Common Init Done !!! [IPU1-0] 12.863173 s: SYSTEM: BSP Platform Init in progress !!! [IPU1-0] 12.863295 s: SYSTEM: BSP Platform Init Done !!! [IPU1-0] 12.863356 s: SYSTEM: FVID2 Init in progress !!! [IPU1-0] 12.863478 s: SYSTEM: FVID2 Init Done !!! [IPU1-0] 12.863569 s: SYSTEM: VPS Init in progress !!! [IPU1-0] 12.863630 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0xa0000000 -> 0x80000000] [IPU1-0] 12.866467 s: *** VPDMA Firmware Loading... *** [IPU1-0] 12.866558 s: VPDMA Firmware Address = 0x9fc8a500 [IPU1-0] 12.866650 s: VPDMA Load Address = 0x4897d004 [IPU1-0] 12.866741 s: VPDMA Firmware Version = 0x4d0001b8 [IPU1-0] 12.866833 s: VPDMA List Busy Status = 0x00000000 [IPU1-0] 12.866894 s: *** VPDMA Firmware Load Success *** [IPU1-0] 12.867260 s: *** VPDMA Firmware Loading... *** [IPU1-0] 12.867321 s: VPDMA Firmware Address = 0x9fc8a500 [IPU1-0] 12.867412 s: VPDMA Load Address = 0x4899d004 [IPU1-0] 12.867504 s: VPDMA Firmware Version = 0x4d0001b8 [IPU1-0] 12.867595 s: VPDMA List Busy Status = 0x00000000 [IPU1-0] 12.867656 s: *** VPDMA Firmware Load Success *** [IPU1-0] 12.867961 s: *** VPDMA Firmware Loading... *** [IPU1-0] 12.868053 s: VPDMA Firmware Address = 0x9fc8a500 [IPU1-0] 12.868144 s: VPDMA Load Address = 0x489bd004 [IPU1-0] 12.868236 s: VPDMA Firmware Version = 0x4d0001b8 [IPU1-0] 12.868327 s: VPDMA List Busy Status = 0x00000000 [IPU1-0] 12.868388 s: *** VPDMA Firmware Load Success *** [IPU1-0] 12.924540 s: SYSTEM: VPS Init Done !!! [IPU1-0] 12.925394 s: UTILS: DMA: HWI Create for INT34 !!! [IPU1-0] 12.925547 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [IPU1-0] 12.925669 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261576 B (255 KB) [IPU1-0] 12.925821 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [IPU1-0] 12.925944 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x8a783000, Total size = 355979264 B (339 MB), Free size = 355979264 B (339 MB) [IPU1-0] 12.926157 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0x00000000, Total size = 0 B (0 MB), Free size = 0 B (0 MB) [IPU1-0] 12.926279 s: SYSTEM: Initializing Links !!! [IPU1-0] 13.075703 s: SYSTEM: Initializing Links ... DONE !!! [IPU1-0] 24.031995 s: BOARD: Board Init in progress !!! [IPU1-0] 24.032544 s: BOARD: Board Init Done !!! [IPU1-0] 24.042274 s: EEPROM Base Board Name: [DRA74CAS] [IPU1-0] 24.042609 s: [IPU1-0] 24.042640 s: Vision SDK Version : [REL_VISION_SDK_03_08_00_00] [IPU1-0] 24.042731 s: FVID2 Version : [FVID_02_01_00_01] [IPU1-0] 24.042792 s: BSP Version : [PDK_01_10_04__xx] [IPU1-0] 24.042884 s: Platform : [EVM] [IPU1-0] 24.042945 s: SOC : [TDA2XX] [IPU1-0] 24.043006 s: SOC Revision : [ES2.0] [IPU1-0] 24.043097 s: Board Detected : [TDA2XX CASCADE RADAR] [IPU1-0] 24.043158 s: Base Board Revision : [REV E] [IPU1-0] 24.043219 s: Daughter Card Revision: [REV A] [IPU1-0] 24.043280 s: [IPU1-1] 13.810742 s: ***** IPU1_1 Firmware build time 11:55:54 Mar 24 2023 [IPU1-1] 13.810925 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz> [IPU1-1] 13.814005 s: UTILS: DMA: HWI Create for INT25 !!! [IPU1-1] 14.853992 s: SYSTEM: System Common Init in progress !!! [IPU1-1] 14.854297 s: SYSTEM: IPC init in progress !!! [IPU1-1] 14.854389 s: SYSTEM: IPCLIB init in progress !!! [IPU1-1] 14.854694 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15... [IPU1-1] 14.854785 s: SYSTEM: IPCLIB: register to [DSP1] event 15... [IPU1-1] 14.854938 s: SYSTEM: IPCLIB: register to [EVE1] event 15... [IPU1-1] 14.855029 s: SYSTEM: IPCLIB: register to [EVE2] event 15... [IPU1-1] 14.855121 s: SYSTEM: IPCLIB: register to [EVE3] event 15... [IPU1-1] 14.855182 s: SYSTEM: IPCLIB: register to [EVE4] event 15... [IPU1-1] 14.855273 s: SYSTEM: IPCLIB init DONE !!! [IPU1-1] 14.855334 s: SYSTEM: Notify init done !!! [IPU1-1] 14.857012 s: SYSTEM: MsgQ init done !!! [IPU1-1] 14.857683 s: SYSTEM: Work Queue init done !!! [IPU1-1] 14.857744 s: SYSTEM: IPC init DONE !!! [IPU1-1] 14.861373 s: SYSTEM: System Common Init Done !!! [IPU1-1] 14.861495 s: SYSTEM: System IPU1_1 Init in progress !!! [IPU1-1] 14.861556 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [IPU1-1] 14.861648 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 655360 B (640 KB), Free size = 639688 B (624 KB) [IPU1-1] 14.861831 s: SYSTEM: Initializing Links !!! [IPU1-1] 14.960379 s: UTILS: PRF: ##### Cannot allocate Object for SYNC1 #### [IPU1-1] 14.963063 s: UTILS: PRF: ##### Cannot allocate Object for SYNC2 #### [IPU1-1] 14.965747 s: UTILS: PRF: ##### Cannot allocate Object for SYNC3 #### [IPU1-1] 14.968370 s: UTILS: PRF: ##### Cannot allocate Object for TFDTPRX #### [IPU1-1] 14.971146 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 #### [IPU1-1] 14.974013 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 #### [IPU1-1] 14.976880 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 #### [IPU1-1] 14.979747 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 #### [IPU1-1] 14.982675 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 #### [IPU1-1] 14.985634 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 #### [IPU1-1] 14.988470 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 #### [IPU1-1] 14.991337 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 #### [IPU1-1] 14.991490 s: SYSTEM: Initializing Links ... DONE !!! [IPU1-1] 14.992557 s: SYSTEM: System IPU1_1 Init Done !!! [IPU1-1] 19.991947 s: NETWORK_CTRL: Starting Server (port=5000) !!! [IPU1-1] 19.992222 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!! [IPU1-1] 25.621393 s: NSP GMAC: PHY 2 Found on MAC Port 0 [DSP1 ] 16.102574 s: ***** DSP1 Firmware build time 11:54:53 Mar 24 2023 [DSP1 ] 16.102635 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 600000000 Hz> [DSP1 ] 16.102818 s: SYSTEM: System Common Init in progress !!! [DSP1 ] 16.102940 s: SYSTEM: IPC init in progress !!! [DSP1 ] 16.102970 s: SYSTEM: IPCLIB init in progress !!! [DSP1 ] 16.103031 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15... [DSP1 ] 16.103062 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15... [DSP1 ] 16.103092 s: SYSTEM: IPCLIB: register to [EVE1] event 15... [DSP1 ] 16.103123 s: SYSTEM: IPCLIB: register to [EVE2] event 15... [DSP1 ] 16.103123 s: SYSTEM: IPCLIB: register to [EVE3] event 15... [DSP1 ] 16.103153 s: SYSTEM: IPCLIB: register to [EVE4] event 15... [DSP1 ] 16.103184 s: SYSTEM: IPCLIB init DONE !!! [DSP1 ] 16.103184 s: SYSTEM: Notify init done !!! [DSP1 ] 16.103306 s: SYSTEM: MsgQ init done !!! [DSP1 ] 16.103397 s: SYSTEM: Work Queue init done !!! [DSP1 ] 16.103428 s: SYSTEM: IPC init DONE !!! [DSP1 ] 16.104068 s: SYSTEM: System Common Init Done !!! [DSP1 ] 16.104099 s: SYSTEM: System DSP Init in progress !!! [DSP1 ] 16.104282 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [DSP1 ] 16.104312 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [DSP1 ] 16.104343 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 524128 B (511 KB) [DSP1 ] 16.104373 s: SYSTEM: Initializing Links !!! [DSP1 ] 16.112029 s: SYSTEM: Initializing Links ... DONE !!! [DSP1 ] 16.112060 s: SYSTEM: System DSP Init Done !!! [DSP1 ] 23.956017 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!! [DSP1 ] 23.956048 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!! [EVE1 ] 18.321753 s: ***** EVE Firmware build time 11:51:36 Mar 24 2023 [EVE1 ] 18.323369 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz> [EVE1 ] 18.325687 s: SYSTEM: System Common Init in progress !!! [EVE1 ] 18.326846 s: SYSTEM: IPC init in progress !!! [EVE1 ] 18.327761 s: SYSTEM: IPCLIB init in progress !!! [EVE1 ] 18.329225 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15... [EVE1 ] 18.330323 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15... [EVE1 ] 18.331421 s: SYSTEM: IPCLIB: register to [DSP1] event 15... [EVE1 ] 18.332519 s: SYSTEM: IPCLIB: register to [EVE2] event 15... [EVE1 ] 18.333648 s: SYSTEM: IPCLIB: register to [EVE3] event 15... [EVE1 ] 18.334746 s: SYSTEM: IPCLIB: register to [EVE4] event 15... [EVE1 ] 18.335905 s: SYSTEM: IPCLIB init DONE !!! [EVE1 ] 18.336759 s: SYSTEM: Notify init done !!! [EVE1 ] 18.338315 s: SYSTEM: MsgQ init done !!! [EVE1 ] 18.339565 s: SYSTEM: Work Queue init done !!! [EVE1 ] 18.340480 s: SYSTEM: IPC init DONE !!! [EVE1 ] 18.352772 s: SYSTEM: System Common Init Done !!! [EVE1 ] 18.353687 s: SYSTEM: System EVE Init in progress !!! [EVE1 ] 18.355029 s: UTILS: DMA: HWI Create for INT8 !!! [EVE1 ] 18.356188 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [EVE1 ] 18.357378 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [EVE1 ] 18.359482 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB) [EVE1 ] 18.361465 s: SYSTEM: Initializing Links !!! [EVE1 ] 18.442292 s: SYSTEM: Initializing Links ... DONE !!! [EVE1 ] 18.443237 s: SYSTEM: System EVE Init Done !!! [EVE2 ] 20.566918 s: ***** EVE Firmware build time 11:52:21 Mar 24 2023 [EVE2 ] 20.568535 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz> [EVE2 ] 20.570853 s: SYSTEM: System Common Init in progress !!! [EVE2 ] 20.572042 s: SYSTEM: IPC init in progress !!! [EVE2 ] 20.572927 s: SYSTEM: IPCLIB init in progress !!! [EVE2 ] 20.574422 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15... [EVE2 ] 20.575550 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15... [EVE2 ] 20.576648 s: SYSTEM: IPCLIB: register to [DSP1] event 15... [EVE2 ] 20.577746 s: SYSTEM: IPCLIB: register to [EVE1] event 15... [EVE2 ] 20.578844 s: SYSTEM: IPCLIB: register to [EVE3] event 15... [EVE2 ] 20.579942 s: SYSTEM: IPCLIB: register to [EVE4] event 15... [EVE2 ] 20.581132 s: SYSTEM: IPCLIB init DONE !!! [EVE2 ] 20.582016 s: SYSTEM: Notify init done !!! [EVE2 ] 20.583511 s: SYSTEM: MsgQ init done !!! [EVE2 ] 20.584792 s: SYSTEM: Work Queue init done !!! [EVE2 ] 20.585676 s: SYSTEM: IPC init DONE !!! [EVE2 ] 20.598029 s: SYSTEM: System Common Init Done !!! [EVE2 ] 20.598944 s: SYSTEM: System EVE Init in progress !!! [EVE2 ] 20.600286 s: UTILS: DMA: HWI Create for INT8 !!! [EVE2 ] 20.601476 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [EVE2 ] 20.602665 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [EVE2 ] 20.604800 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB) [EVE2 ] 20.606813 s: SYSTEM: Initializing Links !!! [EVE2 ] 20.687885 s: SYSTEM: Initializing Links ... DONE !!! [EVE2 ] 20.688830 s: SYSTEM: System EVE Init Done !!! [EVE3 ] 22.290764 s: ***** EVE Firmware build time 11:53:05 Mar 24 2023 [EVE3 ] 22.292380 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz> [EVE3 ] 22.294668 s: SYSTEM: System Common Init in progress !!! [EVE3 ] 22.295827 s: SYSTEM: IPC init in progress !!! [EVE3 ] 22.296712 s: SYSTEM: IPCLIB init in progress !!! [EVE3 ] 22.298176 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15... [EVE3 ] 22.299274 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15... [EVE3 ] 22.300372 s: SYSTEM: IPCLIB: register to [DSP1] event 15... [EVE3 ] 22.301439 s: SYSTEM: IPCLIB: register to [EVE1] event 15... [EVE3 ] 22.302537 s: SYSTEM: IPCLIB: register to [EVE2] event 15... [EVE3 ] 22.303635 s: SYSTEM: IPCLIB: register to [EVE4] event 15... [EVE3 ] 22.304825 s: SYSTEM: IPCLIB init DONE !!! [EVE3 ] 22.305709 s: SYSTEM: Notify init done !!! [EVE3 ] 22.307234 s: SYSTEM: MsgQ init done !!! [EVE3 ] 22.308485 s: SYSTEM: Work Queue init done !!! [EVE3 ] 22.309369 s: SYSTEM: IPC init DONE !!! [EVE3 ] 22.321631 s: SYSTEM: System Common Init Done !!! [EVE3 ] 22.322576 s: SYSTEM: System EVE Init in progress !!! [EVE3 ] 22.323888 s: UTILS: DMA: HWI Create for INT8 !!! [EVE3 ] 22.325077 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [EVE3 ] 22.326267 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [EVE3 ] 22.328371 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB) [EVE3 ] 22.330354 s: SYSTEM: Initializing Links !!! [EVE3 ] 22.411181 s: SYSTEM: Initializing Links ... DONE !!! [EVE3 ] 22.412157 s: SYSTEM: System EVE Init Done !!! [EVE4 ] 23.827975 s: ***** EVE Firmware build time 11:53:49 Mar 24 2023 [EVE4 ] 23.829591 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz> [EVE4 ] 23.831909 s: SYSTEM: System Common Init in progress !!! [EVE4 ] 23.833068 s: SYSTEM: IPC init in progress !!! [EVE4 ] 23.833984 s: SYSTEM: IPCLIB init in progress !!! [EVE4 ] 23.835448 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15... [EVE4 ] 23.836546 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15... [EVE4 ] 23.837674 s: SYSTEM: IPCLIB: register to [DSP1] event 15... [EVE4 ] 23.838772 s: SYSTEM: IPCLIB: register to [EVE1] event 15... [EVE4 ] 23.839870 s: SYSTEM: IPCLIB: register to [EVE2] event 15... [EVE4 ] 23.840968 s: SYSTEM: IPCLIB: register to [EVE3] event 15... [EVE4 ] 23.842158 s: SYSTEM: IPCLIB init DONE !!! [EVE4 ] 23.843042 s: SYSTEM: Notify init done !!! [EVE4 ] 23.844567 s: SYSTEM: MsgQ init done !!! [EVE4 ] 23.845818 s: SYSTEM: Work Queue init done !!! [EVE4 ] 23.846733 s: SYSTEM: IPC init DONE !!! [EVE4 ] 23.859025 s: SYSTEM: System Common Init Done !!! [EVE4 ] 23.859940 s: SYSTEM: System EVE Init in progress !!! [EVE4 ] 23.861282 s: UTILS: DMA: HWI Create for INT8 !!! [EVE4 ] 23.862471 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [EVE4 ] 23.863661 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [EVE4 ] 23.865765 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB) [EVE4 ] 23.867748 s: SYSTEM: Initializing Links !!! [EVE4 ] 23.948697 s: SYSTEM: Initializing Links ... DONE !!! [EVE4 ] 23.949673 s: SYSTEM: System EVE Init Done !!! [IPU1-0] 26.172817 s: QSPI Init Started [IPU1-0] 26.173031 s: MID - 20 [IPU1-0] 26.173061 s: DID - 21 [IPU1-0] 26.173153 s: QSPI Init Completed Sucessfully [IPU1-0] 26.178826 s: [IPU1-0] 26.178887 s: Current System Settings, [IPU1-0] 26.178948 s: ======================== [IPU1-0] 26.179009 s: Display Type : HDMI 1920x1080 @ 60fps [IPU1-0] 26.179070 s: My IP address for interface 1 : 192.168.1.200 [IPU1-0] 26.179161 s: My IP address for interface 2 : 0.0.0.0 [IPU1-0] 26.179253 s: [IPU1-0] 26.179283 s: ============ [IPU1-0] 26.179314 s: Usecase Menu [IPU1-0] 26.179375 s: ============ [IPU1-0] 26.179405 s: [IPU1-0] [IPU1-0] Vision SDK Usecases, [IPU1-0] -------------------- [IPU1-0] [IPU1-0] 1: RADAR Usecases [IPU1-0] 2: MISC Tests [IPU1-0] [IPU1-0] s: System Settings [IPU1-0] [IPU1-0] x: Exit [IPU1-0] [IPU1-0] Enter Choice: [IPU1-0] [IPU1-1] 29.221771 s: NDK: Link Status: 1000Mb/s Full Duplex on PHY 2 [IPU1-0] 62.294363 s: [IPU1-0] 62.294485 s:
已经设置为静态IP了,网线已经连上,本机ip设置在同一个网段,在ping的时候显示“连接超时”,请求解答!
