LDC5072-Q1: Unequal output voltage difference of LDC5072 chip and subsequent processing issues
Part Number: LDC5072-Q1
The LDC5072 chip outputs a voltage difference of 200mv between OUT0P/N, but a voltage difference of 1.8V between OUT1P/N. Is this phenomenon normal? If not, what should we do and how to obtain position information by processing these two differential signals? The PCB schematic is provided in the attachment.
