RFQueue_defineQueue(dataQueue_t *dataQueue, uint8_t *buf, uint16_t buf_len, uint8_t numEntries, uint16_t length) { if (buf_len < (numEntries * (length + RF_QUEUE_DATA_ENTRY_HEADER_SIZE + RF_QUEUE_QUEUE_ALIGN_PADDING(length)))) { /* queue does not fit into buffer */ return (1); } /* Padding needed for 4-byte alignment? */ uint8_t pad = 4-((length + RF_QUEUE_DATA_ENTRY_HEADER_SIZE)%4); /* Set the Data Entries common configuration */ uint8_t *first_entry = buf; int i; for (i = 0; i < numEntries; i++) { buf = first_entry + i * (RF_QUEUE_DATA_ENTRY_HEADER_SIZE + length + pad); ((rfc_dataEntry_t*)buf)->status = DATA_ENTRY_PENDING; // Pending - starting state ((rfc_dataEntry_t*)buf)->config.type = DATA_ENTRY_TYPE_GEN; // General Data Entry ((rfc_dataEntry_t*)buf)->config.lenSz = 0; // No length indicator byte in data ((rfc_dataEntry_t*)buf)->length = length; // Total length of data field ((rfc_dataEntryGeneral_t*)buf)->pNextEntry = &(((rfc_dataEntryGeneral_t*)buf)->data)+length+pad; } /* Make circular Last.Next -> First */ ((rfc_dataEntry_t*)buf)->pNextEntry = first_entry; /* Create Data Entry Queue and configure for circular buffer Data Entries */ dataQueue->pCurrEntry = first_entry; dataQueue->pLastEntry = NULL; /* Set read pointer to first entry */ readEntry = (rfc_dataEntryGeneral_t*)first_entry; return (0); }
想要实现高速模式,在rfpacketTx中修改了射频配置(RF_cmdRadioSetup_hsm_4mbps),4M模式可以跑通,想要修改传输队列长度,上面是用到的队列定义,定义中uint16_t length,但是实际传输发现最大长度只能达到256字节,下面是我用串口将其整个队列结构打印出来的内容。
查找手册,数据分别代表的是4字节的*pNextEntry、一个字节的status、一个字节的config和两个字节的length,理论上说队列长度可以达到0xFFFF,但是实际上最多只能0x255。
请问:如何实现队列长度大于0x255?
