LAUNCHXL-CC1310: 在GPIO中断函数中调用SPI函数会跑飞
Part Number: LAUNCHXL-CC1310
你好,我现在在GPIO的中断函数中,调用SPI,运行到函数SPI_transfer时,程序会跑飞。在中断函数中不能调用SPI吗?
  • 在SPI_MODE_BLOCKING中,SPI_transfer()将阻止任务执行,直到完成或发生超时
    中断中不能有任何形式的阻塞,尝试使用SPI_MODE_CALLBACK模式
  • 把模式改为CALLBACK,还是会在SPI_transfer跑飞。
    主函数:
          UART_init();
          SPI_init();  // Initialize the SPI driver
          GPIO_init();
          GPIO_setConfig(Board_SPI_SLAVE_READY, GPIO_CFG_IN_PD | GPIO_CFG_IN_INT_RISING);
          /* install Button callback */
          GPIO_setCallback(Board_SPI_SLAVE_READY, gpioButtonFxn0);
          /* Enable interrupts */
          GPIO_enableInt(Board_SPI_SLAVE_READY);
          SPI_Params_init(&spiParams);  // Initialize SPI parameters
          spiParams.transferMode = SPI_MODE_CALLBACK;  //
          spiParams.dataSize = 8;       // 8-bit data size
          spiParams.mode = SPI_MASTER;  //SPI MASTER
          spiParams.frameFormat = SPI_POL0_PHA1;  //SPI POL0 PHA0
          spiParams.bitRate = 4000000;  //4MHZ
                // Fill in transmitBuffer
          spiTransaction.count = MASSAGE;
          spiTransaction.txBuf = (void *)transmitBuffer;
          spiTransaction.rxBuf = (void *)receiveBuffer;
          UART_Params_init(&uartParams);
          uartParams.writeDataMode = UART_DATA_BINARY;
          uartParams.readDataMode = UART_DATA_BINARY;
          uartParams.readReturnMode = UART_RETURN_FULL;
          uartParams.readEcho = UART_ECHO_OFF;
          uartParams.baudRate = 115200;
          uart = UART_open(Board_UART0, &uartParams);
          if (uart == NULL) {
               // UART_open() failed
              while (1);
                spi = SPI_open(Board_SPI0, &spiParams);
          if (spi == NULL) {
              while (1);  // SPI_open() failed
               while(1)
    中断函数:
    void gpioButtonFxn0(uint_least8_t index)
     spiTransaction.txBuf = (void *)transmitBuffer1;
     SPI_transfer(spi,&spiTransaction);
     UART_write(uart,receiveBuffer,MASSAGE);
  • UART_write依然是阻塞的,先将UART_write去掉试试
