CC2652R: 想用CC2530+z-stack 3.0.2作终端,CC26X2R1+simplelink_cc13x2_26x2_sdk_3_40_00_02中的zc_light做协调器,不知道行不行。TC_LINKKEY_JOIN去掉了。
Part Number: CC2652R
Other Parts Discussed in Thread: Z-STACK, CC2530,
  • CC2530+z-stack 3.0.2作终端,CC26X2R1+simplelink_cc13x2_26x2_sdk_3_40_00_02中的zc_light做协调器如果不去掉TC_LINKKEY_JOIN是可以的
  • TC_LINKKEY_JOIN加上了。CC2530+z-stack 3.0.2作终端,CC2530+z-stack 3.0.2作协调器调试通过了。CC26X2R1+simplelink_cc13x2_26x2_sdk_3_40_00_02中的zc_light做协调器,抓包如图。zc_light例程信道用的11,PANID 3FFF.
    初始化函数中加入:
    zstack_bdbStartCommissioningReq.commissioning_mode |= BDB_COMMISSIONING_MODE_NWK_FORMATION;
    zstack_bdbStartCommissioningReq.commissioning_mode |= BDB_COMMISSIONING_MODE_FINDING_BINDING;
    Zstackapi_bdbStartCommissioningReq(appServiceTaskId,&zstack_bdbStartCommissioningReq);
    NLME_PermitJoiningRequest(255);
    去掉现象也是一样的。zclSampleLight_ProcessCommissioningStatus函数中加入重新入网的代码
    也是一样。
    能否指导一下,问题大约出在哪了?
  • 麻煩附上原始的抓包檔才能分析問題
  • 谢谢,麻烦您了。
    666.txt
    No.     Time           Source                Destination           Protocol Length Info
          1 0.000000       0x0000                Broadcast             ZigBee   107    Command, Dst: Broadcast, Src: 0x0000
    Frame 1: 107 bytes on wire (856 bits), 107 bytes captured (856 bits) on interface 0
        Interface id: 0 (\\.\pipe\tiwspc_data)
        Encapsulation type: Raw IPv4 (129)
        Arrival Time: Jan  1, 1970 08:00:16.734448000 中国标准时间
        [Time shift for this packet: 0.000000000 seconds]
        Epoch Time: 16.734448000 seconds
        [Time delta from previous captured frame: 0.000000000 seconds]
        [Time delta from previous displayed frame: 0.000000000 seconds]
        [Time since reference or first frame: 0.000000000 seconds]
        Frame Number: 1
        Frame Length: 107 bytes (856 bits)
        Capture Length: 107 bytes (856 bits)
        [Frame is marked: False]
        [Frame is ignored: False]
        [Protocols in frame: ip:udp:zep:wpan:zbee_nwk:data]
        [Coloring Rule Name: UDP]
        [Coloring Rule String: udp]
    Internet Protocol Version 4, Src: 192.168.1.3, Dst: 192.168.1.3
        0100 .... = Version: 4
        .... 0101 = Header Length: 20 bytes (5)
        Differentiated Services Field: 0x00 (DSCP: CS0, ECN: Not-ECT)
        Total Length: 107
        Identification: 0x0000 (0)
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Header checksum: 0xb72b [validation disabled]
        [Header checksum status: Unverified]
        Source: 192.168.1.3
        Destination: 192.168.1.3
        [Source GeoIP: Unknown]
        [Destination GeoIP: Unknown]
    User Datagram Protocol, Src Port: 17754, Dst Port: 17754
        Source Port: 17754
        Destination Port: 17754
        Length: 87
        Checksum: 0xbbcd [unverified]
        [Checksum Status: Unverified]
        [Stream index: 0]
    ZigBee Encapsulation Protocol, Channel: 11, Length: 47
        Protocol ID String: EX
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Link Quality Indication: 127
        Timestamp: Jan  1, 1970 08:00:00.000000000 中国标准时间 (0.000000000s)
        Sequence Number: 2
        Length: 47 Bytes
    IEEE 802.15.4 Data, Dst: Broadcast, Src: 0x0000
        Frame Control Field: 0x8841, Frame Type: Data, PAN ID Compression, Destination Addressing Mode: Short/16-bit, Frame Version: IEEE Std 802.15.4-2003, Source Addressing Mode: Short/16-bit
        Sequence Number: 33
        Destination PAN: 0xfba7
        Destination: 0xffff
        Source: 0x0000
        [Extended Source: TexasIns_00:25:b7:02:4f (00:12:4b:00:25:b7:02:4f)]
        [Origin: 1]
        Frame Check Sequence (TI CC24xx format): FCS OK
    ZigBee Network Layer Command, Dst: Broadcast, Src: 0x0000
          2 7.523587                             Broadcast             IEEE 802.15.4 70     Beacon Request
    Frame 2: 70 bytes on wire (560 bits), 70 bytes captured (560 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:00:24.258035000 中国标准时间
        Epoch Time: 24.258035000 seconds
        [Time delta from previous captured frame: 7.523587000 seconds]
        [Time delta from previous displayed frame: 7.523587000 seconds]
        [Time since reference or first frame: 7.523587000 seconds]
        Frame Number: 2
        Frame Length: 70 bytes (560 bits)
        Capture Length: 70 bytes (560 bits)
        [Protocols in frame: ip:udp:zep:wpan]
        Total Length: 70
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Header checksum: 0xb750 [validation disabled]
        Source: 192.168.1.3
        Source Port: 17754
        Length: 50
        Checksum: 0x32b6 [unverified]
        [Stream index: 0]
    ZigBee Encapsulation Protocol, Channel: 11, Length: 10
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 3
        Length: 10 Bytes
    IEEE 802.15.4 Command, Dst: Broadcast
        Frame Control Field: 0x0803, Frame Type: Command, Destination Addressing Mode: Short/16-bit, Frame Version: IEEE Std 802.15.4-2003, Source Addressing Mode: None
        Sequence Number: 88
        Destination PAN: 0xffff
        Destination: 0xffff
        Command Identifier: Beacon Request (0x07)
          3 7.525295       0x0000                                      ZigBee   88     Beacon, Src: 0x0000, EPID: TexasIns_00:25:b7:02:4f
    Frame 3: 88 bytes on wire (704 bits), 88 bytes captured (704 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:00:24.259743000 中国标准时间
        Epoch Time: 24.259743000 seconds
        [Time delta from previous captured frame: 0.001708000 seconds]
        [Time delta from previous displayed frame: 0.001708000 seconds]
        [Time since reference or first frame: 7.525295000 seconds]
        Frame Number: 3
        Frame Length: 88 bytes (704 bits)
        Capture Length: 88 bytes (704 bits)
        [Protocols in frame: ip:udp:zep:wpan:zbee_beacon]
        Total Length: 88
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Header checksum: 0xb73e [validation disabled]
        Source: 192.168.1.3
        Source Port: 17754
        Length: 68
        Checksum: 0x136f [unverified]
        [Stream index: 0]
    ZigBee Encapsulation Protocol, Channel: 11, Length: 28
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 4
        Length: 28 Bytes
    IEEE 802.15.4 Beacon, Src: 0x0000
        Frame Control Field: 0x8000, Frame Type: Beacon, Destination Addressing Mode: None, Frame Version: IEEE Std 802.15.4-2003, Source Addressing Mode: Short/16-bit
        Sequence Number: 118
        Source PAN: 0xfba7
        Source: 0x0000
        Superframe Specification: PAN Coordinator, Association Permit
        GTS
        Pending Addresses: 0 Short and 0 Long
    ZigBee Beacon, ZigBee PRO, EPID: TexasIns_00:25:b7:02:4f
          4 15.021497      0x0000                Broadcast             ZigBee   107    Command, Dst: Broadcast, Src: 0x0000
    Frame 4: 107 bytes on wire (856 bits), 107 bytes captured (856 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:00:31.755945000 中国标准时间
        Epoch Time: 31.755945000 seconds
        [Time delta from previous captured frame: 7.496202000 seconds]
        [Time delta from previous displayed frame: 7.496202000 seconds]
        [Time since reference or first frame: 15.021497000 seconds]
        Frame Number: 4
        Total Length: 107
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 87
        Checksum: 0xedca [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 5
        Length: 47 Bytes
        Sequence Number: 34
        Destination: 0xffff
        Source: 0x0000
        [Origin: 1]
          5 17.886125                            Broadcast             IEEE 802.15.4 70     Beacon Request
    Frame 5: 70 bytes on wire (560 bits), 70 bytes captured (560 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:00:34.620573000 中国标准时间
        Epoch Time: 34.620573000 seconds
        [Time delta from previous captured frame: 2.864628000 seconds]
        [Time delta from previous displayed frame: 2.864628000 seconds]
        [Time since reference or first frame: 17.886125000 seconds]
        Frame Number: 5
        Total Length: 70
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 50
        Checksum: 0x31b6 [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 6
        Length: 10 Bytes
        Sequence Number: 89
        Destination: 0xffff
          6 17.889431      0x0000                                      ZigBee   88     Beacon, Src: 0x0000, EPID: TexasIns_00:25:b7:02:4f
    Frame 6: 88 bytes on wire (704 bits), 88 bytes captured (704 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:00:34.623879000 中国标准时间
        Epoch Time: 34.623879000 seconds
        [Time delta from previous captured frame: 0.003306000 seconds]
        [Time delta from previous displayed frame: 0.003306000 seconds]
        [Time since reference or first frame: 17.889431000 seconds]
        Frame Number: 6
        Total Length: 88
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 68
        Checksum: 0x0e6f [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 7
        Length: 28 Bytes
        Sequence Number: 119
        Source PAN: 0xfba7
        Source: 0x0000
        GTS
          7 28.249208                            Broadcast             IEEE 802.15.4 70     Beacon Request
    Frame 7: 70 bytes on wire (560 bits), 70 bytes captured (560 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:00:44.983656000 中国标准时间
        Epoch Time: 44.983656000 seconds
        [Time delta from previous captured frame: 10.359777000 seconds]
        [Time delta from previous displayed frame: 10.359777000 seconds]
        [Time since reference or first frame: 28.249208000 seconds]
        Frame Number: 7
        Total Length: 70
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 50
        Checksum: 0x2bb6 [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 8
        Length: 10 Bytes
        Sequence Number: 90
        Destination: 0xffff
          8 28.252193      0x0000                                      ZigBee   88     Beacon, Src: 0x0000, EPID: TexasIns_00:25:b7:02:4f
    Frame 8: 88 bytes on wire (704 bits), 88 bytes captured (704 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:00:44.986641000 中国标准时间
        Epoch Time: 44.986641000 seconds
        [Time delta from previous captured frame: 0.002985000 seconds]
        [Time delta from previous displayed frame: 0.002985000 seconds]
        [Time since reference or first frame: 28.252193000 seconds]
        Frame Number: 8
        Total Length: 88
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 68
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 9
        Length: 28 Bytes
        Sequence Number: 120
        Source PAN: 0xfba7
        Source: 0x0000
        GTS
          9 30.041399      0x0000                Broadcast             ZigBee   107    Command, Dst: Broadcast, Src: 0x0000
    Frame 9: 107 bytes on wire (856 bits), 107 bytes captured (856 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:00:46.775847000 中国标准时间
        Epoch Time: 46.775847000 seconds
        [Time delta from previous captured frame: 1.789206000 seconds]
        [Time delta from previous displayed frame: 1.789206000 seconds]
        [Time since reference or first frame: 30.041399000 seconds]
        Frame Number: 9
        Total Length: 107
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 87
        Checksum: 0x9029 [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 10
        Length: 47 Bytes
        Sequence Number: 35
        Destination: 0xffff
        Source: 0x0000
        [Origin: 1]
         10 38.610865                            Broadcast             IEEE 802.15.4 70     Beacon Request
    Frame 10: 70 bytes on wire (560 bits), 70 bytes captured (560 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:00:55.345313000 中国标准时间
        Epoch Time: 55.345313000 seconds
        [Time delta from previous captured frame: 8.569466000 seconds]
        [Time delta from previous displayed frame: 8.569466000 seconds]
        [Time since reference or first frame: 38.610865000 seconds]
        Frame Number: 10
        Total Length: 70
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 50
        Checksum: 0x2ab6 [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 11
        Length: 10 Bytes
        Sequence Number: 91
        Destination: 0xffff
         11 38.614174      0x0000                                      ZigBee   88     Beacon, Src: 0x0000, EPID: TexasIns_00:25:b7:02:4f
    Frame 11: 88 bytes on wire (704 bits), 88 bytes captured (704 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:00:55.348622000 中国标准时间
        Epoch Time: 55.348622000 seconds
        [Time delta from previous captured frame: 0.003309000 seconds]
        [Time delta from previous displayed frame: 0.003309000 seconds]
        [Time since reference or first frame: 38.614174000 seconds]
        Frame Number: 11
        Total Length: 88
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 68
        Checksum: 0x086f [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 12
        Length: 28 Bytes
        Sequence Number: 121
        Source PAN: 0xfba7
        Source: 0x0000
        GTS
         12 45.063515      0x0000                Broadcast             ZigBee   107    Command, Dst: Broadcast, Src: 0x0000
    Frame 12: 107 bytes on wire (856 bits), 107 bytes captured (856 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:01:01.797963000 中国标准时间
        Epoch Time: 61.797963000 seconds
        [Time delta from previous captured frame: 6.449341000 seconds]
        [Time delta from previous displayed frame: 6.449341000 seconds]
        [Time since reference or first frame: 45.063515000 seconds]
        Frame Number: 12
        Total Length: 107
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 87
        Checksum: 0x953c [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 13
        Length: 47 Bytes
        Sequence Number: 36
        Destination: 0xffff
        Source: 0x0000
        [Origin: 1]
         13 48.973478                            Broadcast             IEEE 802.15.4 70     Beacon Request
    Frame 13: 70 bytes on wire (560 bits), 70 bytes captured (560 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:01:05.707926000 中国标准时间
        Epoch Time: 65.707926000 seconds
        [Time delta from previous captured frame: 3.909963000 seconds]
        [Time delta from previous displayed frame: 3.909963000 seconds]
        [Time since reference or first frame: 48.973478000 seconds]
        Frame Number: 13
        Total Length: 70
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 50
        Checksum: 0x26b6 [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 14
        Length: 10 Bytes
        Sequence Number: 92
        Destination: 0xffff
         14 48.975183      0x0000                                      ZigBee   88     Beacon, Src: 0x0000, EPID: TexasIns_00:25:b7:02:4f
    Frame 14: 88 bytes on wire (704 bits), 88 bytes captured (704 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:01:05.709631000 中国标准时间
        Epoch Time: 65.709631000 seconds
        [Time delta from previous captured frame: 0.001705000 seconds]
        [Time delta from previous displayed frame: 0.001705000 seconds]
        [Time since reference or first frame: 48.975183000 seconds]
        Frame Number: 14
        Total Length: 88
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 68
        Checksum: 0x066f [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 15
        Length: 28 Bytes
        Sequence Number: 122
        Source PAN: 0xfba7
        Source: 0x0000
        GTS
         15 59.337836                            Broadcast             IEEE 802.15.4 70     Beacon Request
    Frame 15: 70 bytes on wire (560 bits), 70 bytes captured (560 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:01:16.072284000 中国标准时间
        Epoch Time: 76.072284000 seconds
        [Time delta from previous captured frame: 10.362653000 seconds]
        [Time delta from previous displayed frame: 10.362653000 seconds]
        [Time since reference or first frame: 59.337836000 seconds]
        Frame Number: 15
        Total Length: 70
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 50
        Checksum: 0x1fb6 [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 16
        Length: 10 Bytes
        Sequence Number: 93
        Destination: 0xffff
         16 59.339862      0x0000                                      ZigBee   88     Beacon, Src: 0x0000, EPID: TexasIns_00:25:b7:02:4f
    Frame 16: 88 bytes on wire (704 bits), 88 bytes captured (704 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:01:16.074310000 中国标准时间
        Epoch Time: 76.074310000 seconds
        [Time delta from previous captured frame: 0.002026000 seconds]
        [Time delta from previous displayed frame: 0.002026000 seconds]
        [Time since reference or first frame: 59.339862000 seconds]
        Frame Number: 16
        Total Length: 88
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 68
        Checksum: 0x076f [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 17
        Length: 28 Bytes
        Sequence Number: 123
        Source PAN: 0xfba7
        Source: 0x0000
        GTS
         17 60.082797      0x0000                Broadcast             ZigBee   107    Command, Dst: Broadcast, Src: 0x0000
    Frame 17: 107 bytes on wire (856 bits), 107 bytes captured (856 bits) on interface 0
        Arrival Time: Jan  1, 1970 08:01:16.817245000 中国标准时间
        Epoch Time: 76.817245000 seconds
        [Time delta from previous captured frame: 0.742935000 seconds]
        [Time delta from previous displayed frame: 0.742935000 seconds]
        [Time since reference or first frame: 60.082797000 seconds]
        Frame Number: 17
        Total Length: 107
        Flags: 0x00
        Fragment offset: 0
        Time to live: 128
        Protocol: UDP (17)
        Source: 192.168.1.3
        Source Port: 17754
        Length: 87
        Checksum: 0xf6be [unverified]
        [Stream index: 0]
        Protocol Version: 2
        Type: 1 (Data)
        Channel ID: 11
        Device ID: 26995
        LQI/CRC Mode: LQI
        Sequence Number: 18
        Length: 47 Bytes
        Sequence Number: 37
        Destination: 0xffff
        Source: 0x0000
        [Origin: 1]
    0407.zcl_samplelight.c
  • 可以附上你wireshark 的原始檔案?
  • 谢谢!文件不能上传。链接: pan.baidu.com/.../18DKdrcJlesXoUJL4Uf6Kww 提取码: 1111。您试试这个。
  • 用zip壓縮後再上传
  • Try to erase your CC2530 and CC2652R and download firmware to test from scratch again.
  • 按您的方法做了,问题解决了,谢谢!如果有时间可否讲一下为什么,忙就算了。
  • 有時候之前網絡的資訊沒有清除乾淨,磨出新片的動作可以把網絡資訊清除掉
