如图:串口打印乱码,但是每次打印的乱码一样。这个可能的错误有哪些,在启动时bootme打印正常
代码如下:
#define UART_STDIO_INSTANCE (2)
#define UART_CONSOLE_BASE (SOC_UART_2_REGS)
int main()
// 串口终端初始化
UARTStdioInit();
// 启动信息
UARTPuts("\r\n\r\nTronlong DSP TMS320C6748 NDK Application ......\r\n", -2);
// 启动 SYS/BIOS 系统
BIOS_start();
void UARTStdioInit(void)
UARTConsoleInit();
void UARTConsoleInit(void)
#if (0 == UART_STDIO_INSTANCE)
PSCModuleControl(SOC_PSC_0_REGS,9, 0, PSC_MDCTL_NEXT_ENABLE);
UARTPinMuxSetup(0, FALSE);
#elif (1 == UART_STDIO_INSTANCE)
PSCModuleControl(SOC_PSC_1_REGS,12, 0, PSC_MDCTL_NEXT_ENABLE);
UARTPinMuxSetup(1, FALSE);
#else
PSCModuleControl(SOC_PSC_1_REGS,13, 0, PSC_MDCTL_NEXT_ENABLE);
UARTPinMuxSetup(2, FALSE);
#endif
UARTStdioInitExpClk(BAUD_115200, UART_RX_TRIG_LEVEL_1);
void UARTPinMuxSetup(unsigned int instanceNum, unsigned int modemCtrlChoice)
unsigned int svPinMuxRtsCts = 0;
unsigned int svPinMuxTxdRxd = 0;
if(0 == instanceNum)
if(TRUE == modemCtrlChoice)
svPinMuxRtsCts = (HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(3)) & \
~(SYSCFG_PINMUX3_PINMUX3_27_24 | \
SYSCFG_PINMUX3_PINMUX3_31_28));
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(3)) = \
(PINMUX3_UART0_CTS_ENABLE | \
PINMUX3_UART0_RTS_ENABLE | \
svPinMuxRtsCts);
svPinMuxTxdRxd = (HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(3)) & \
~(SYSCFG_PINMUX3_PINMUX3_23_20 | \
SYSCFG_PINMUX3_PINMUX3_19_16));
(PINMUX3_UART0_TXD_ENABLE | \
PINMUX3_UART0_RXD_ENABLE | \
svPinMuxTxdRxd);
else if(1 == instanceNum)
svPinMuxRtsCts = (HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(0)) & \
~(SYSCFG_PINMUX0_PINMUX0_23_20 | \
SYSCFG_PINMUX0_PINMUX0_19_16));
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(0)) = \
(PINMUX0_UART1_CTS_ENABLE | \
PINMUX0_UART1_RTS_ENABLE | \
svPinMuxRtsCts);
svPinMuxTxdRxd = (HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(4)) & \
~(SYSCFG_PINMUX4_PINMUX4_31_28 | \
SYSCFG_PINMUX4_PINMUX4_27_24));
HWREG(SOC_SYSCFG_0_REGS + SYSCFG0_PINMUX(4)) = \
(PINMUX4_UART1_TXD_ENABLE | \
PINMUX4_UART1_RXD_ENABLE | \
svPinMuxTxdRxd);
else if(2 == instanceNum)
~(SYSCFG_PINMUX0_PINMUX0_31_28 | \
SYSCFG_PINMUX0_PINMUX0_27_24));
(PINMUX0_UART2_CTS_ENABLE | \
PINMUX0_UART2_RTS_ENABLE | \
svPinMuxRtsCts);
~(SYSCFG_PINMUX4_PINMUX4_23_20 | \
SYSCFG_PINMUX4_PINMUX4_19_16));
(PINMUX4_UART2_TXD_ENABLE | \
PINMUX4_UART2_RXD_ENABLE | \
svPinMuxTxdRxd);
else
static void UARTStdioInitExpClk(unsigned int baudRate, unsigned int rxTrigLevel)
// 使能接收 / 发送
UARTEnable(UART_CONSOLE_BASE);
// 串口参数配置
// 8位数据位 1位停止位 无校验
UARTConfigSetExpClk(UART_CONSOLE_BASE,
SOC_UART_2_MODULE_FREQ,
baudRate,
UART_WORDL_8BITS,
UART_OVER_SAMP_RATE_16);
// 使能接收 / 发送 FIFO
UARTFIFOEnable(UART_CONSOLE_BASE);
// 设置接收 FIFO 级别
UARTFIFOLevelSet(UART_CONSOLE_BASE, rxTrigLevel);
void UARTEnable (unsigned int baseAdd)
/* Enable the Tx, Rx and the free running mode of operation. */
HWREG(baseAdd + UART_PWREMU_MGMT) = (UART_FREE_MODE | \
UART_RX_RST_ENABLE | \
UART_TX_RST_ENABLE);
void UARTConfigSetExpClk (unsigned int baseAdd, unsigned int uartClk,
unsigned int baudrate, unsigned int config,
unsigned int overSampRate)
unsigned int divisor = 0;
/* Calculating the divisor value */
switch (overSampRate)
case UART_OVER_SAMP_RATE_13:
divisor = uartClk/(baudrate * 13);
HWREG(baseAdd + UART_MDR) = UART_OVER_SAMP_RATE;
break;
case UART_OVER_SAMP_RATE_16:
default:
divisor = uartClk/(baudrate * 16);
HWREG(baseAdd + UART_MDR) &= ~UART_OVER_SAMP_RATE;
break;
** Writing the divisor value onto the Divisor Latch registers.
** Programming the divisor latch registers with an appropriate value sets
** the corresponding baud rate of communication for the device.
HWREG(baseAdd + UART_DLL) = ((divisor & 0xFF));
HWREG(baseAdd + UART_DLH) = ((divisor & 0xFF00) >> 8);
** Write only relevant values to the LCR. LCR controls the number of data
** bits and stop bits per frame, parity enable feature, type of parity
** (even of odd), stick parity enable feature, Break control and DLAB
** selection bits.
HWREG(baseAdd + UART_LCR) = (config & ( UART_STOP_BIT | UART_WORDL | \
UART_PARITY | UART_SET_PARITY_TYPE | \
UART_STICK_PARITY | UART_BREAK_CTRL | \
UART_DLAB));
void UARTFIFOEnable(unsigned int baseAdd)
HWREG(baseAdd + UART_FCR) = (UART_FIFO_MODE | UART_RX_CLEAR |
UART_TX_CLEAR);
void UARTFIFOLevelSet (unsigned int baseAdd, unsigned int rxLevel)
HWREG(baseAdd + UART_FCR) = ((rxLevel & (UART_RX_TRIG_LEVEL)) |
UART_FIFO_MODE);
