Description Resource Path Location Type
<a href="file:/D:/ti/ccsv5/tools/compiler/dmed/HTML/17003.html">#17003-D</a> ../CharCut.c relocation from function "AreaCut" to symbol "areaDownBord" overflowed; the 17-bit relocated address 0x18e77 is too large to encode in the 15-bit unsigned field (type = 'R_C6000_SBR_U15_H' (12), file = "../Source/imgproc/SerialNumLib.lib<CharCut.obj>", offset = 0x00000a14, section = ".text") main_billacceptor line 400 C/C++ Problem
此警告是什么意思,结构体变量中增加了几个参数后,工程有几百个类似的警告,然后影响程序正常运行
