1. 2A 算法和 sensor的wdr算法 曝光控制互相影响,图像不正常
http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/80913.aspx
2. DM385 demo板 PWM_VIDEO 问题
http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/92314.aspx
3. dm385 gpio配置问题
http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/91562.aspx
4. DM385外挂tvp5151时capturelink及deilink的配置问题求助
http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/84343.aspx
5. DM385改变主频问题
http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/89603.aspx
6. DM388 500MegaPiexls 30fps
http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/91924.aspx
7. ezsdk中是不是不包含两个M3和dsp的code?如果要修改生成新的xe文件只能用rdk版本进行开发?
http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/95749.aspx
8. IPNC lowpower问题
http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/89570.aspx
9. Live555获得的帧数据是否可以通过IPC bits links
http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/85448.aspx
11. 关于DM8107多核通信机制的求解
http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/82688.aspx
12. 在usecase multich_tristream_lowpower中增加 ISS_NF link
13. 怎么才可以拿到DM388的RDK包
http://www.deyisupport.com/question_answer/dsp_arm/davinci_digital_media_processors/f/39/t/93911.aspx
