文档在.\docs目录下。
下面是release note:
Applies to Release 1.0
Publication Date: March 13, 2015
1. Overview
This document is the Release Notes of KeyStone 2 Self Test Kit (STK) based on ARM. This software release gives users the ability to debug the KeyStone 2 device and test the performance of KeyStone device, the source code can also be used as reference for customer’s driver code development.
2. Platform and Device Support
This release supports the Texas Instruments K2H, K2K, K2E and K2L high performance Multicore DSP+ARM KeyStone 2 System-on-Chip (SoC).
The release is tested and verified on the ARM core of K2H/K EVM, K2E EVM and K2L EVM.
3. Dependencies
This release requires following software components and tools versions to successfully function:
- CCS6.1 or higher;
- CSL header files in pdk_keystone2_3_01_01_04
4. Releases
Below is a summary of the features of all modules.
4.1 Memory Test
Features |
Status |
Test Masters |
All ARM cores, All EDMA TCs |
Tested memories |
MSRAM (Multicore Shared RAM), DDR3A, DDR3B, cache, prefetch buffer |
Test algorithm |
Data pattern filling; Addressing; Bit walking |
DDR3A configuration |
32 bits x 1333MTS, 64 bits x 1600 MTS |
DDR3B configuration |
4.2 Memory Performance
Features, Test Cases |
Status |
Test Masters |
ARM core, All EDMA TCs |
Tested memories |
MSRAM, DDR3A, DDR3B |
Cache/Prefetch buffer configuration cases |
No cache and no prefetch; cache and perfetchable |
ARM core memory copy throughput |
ARM core read/write latency |
EDMA memory copy throughput |
EDMA transfer overhead |
EDMA test with different ACNT |
EDMA test with different Index |
4.3 Multicore Navigator
Status |
Test Masters |
ARM core, QMSS Packet DMA 1 and 2, PA packet DMA |
Test with different memory buffer |
MSRAM, DDR3A |
Descriptor types |
Host, Monolithic |
Tested Queue Manager |
QM1, QM2 |
Tested INTD |
INTD1, INDT2 |
linking RAM |
Internal, External |
Core Cycles for PUSH/POP operation through VBUSP and VBUSM |
Interrupt latency for queue pending |
descriptor accumulation latency |
descriptor Reclamation latency |
Packet DMA Throughput |
Packet DMA transfer overhead |
4.4 Timer
Status |
one-shot pulse and interrupt |
continual clock and interrupts |
square waves with special duty cycle |
watch-dog and exception |
4.5 HyperLink
Status |
Test Master |
ARM core, EDMA |
Internal loopback |
Serdes loopback |
Test between two devices |
Integrity test |
Data pattern filling; Addressing test |
Interrupts test |
Speed |
3.125Gbps, 5Gbps |
4.6 PCIE
Status |
Test Master |
ARM core, EDMA |
Internal loopback |
Serdes loopback |
Integrity test |
Interrupts test |
Speed |
5Gbps, 2.5Gbps |
4.7 GE (Gigabit Ethernet)
Status |
Internal loopback |
EMAC, SGMII, Serdes loopback |
External loopback, data from device 0 to device 1 |
MSRAM, DDR3A |
Multiple ports test |
Throughput test |
Interrupts test |
Speed |
10Mbps, 100Mbps, 1000Mbps |
4.8 SPI
Features |
Status |
Test Masters |
ARM core, EDMA |
internal loopback |
FLASH test |
Data pattern filling; Addressing |
Max test Speed |
66MHz |
4.9 UART
Status |
Test Masters |
ARM core, EDMA |
internal loopback |
Tests between EVM and PC |
Echo to PC; continuous data patterns transfer between EVM and PC |
Max test Speed |
3Mbps |
4.10 GPIO
Status |
Direction |
input, output |
loopback test |
Interrupts |
4.11 Robust features
Status |
Test masters |
ARM core, EDMA |
Memory Protection |
MSRAM, DDR, Reserved space |
EDC |
MSRAM, DDR |
MPU (Peripherals protection) |
EDMA error handling |
4.12 EMIF
Status |
NAND FLASH |
NOR FLASH |
4.13 I2C
Status |
internal loopback |
EEPROM test |
I2C speed |
400K |
4.14 USIM
Status |
Read ATR |
Read ICCID |
