4.9.3 DCA1000
For data capture using the DCA1000, set up the board to MMWAVEICBOOST mode, having the SOP and UART
muxed set correctly. Continue as you would with the IWR6843ISK. For more information, see Section 2.5.3.
Figure 2-12. IWR6843ISK-MMWAVEICBOOST-DCA1000EVM Test Setup
