请问NIRScan Nano 光栅型号和参数采用的Richardson光栅型号和参数是多少?BOM里面的型号(GRATING (33A12BF01-640R -- Newport gratings))是否正确?我按照BOM里面的型号去联系Newport代理人员,代理人员说找不到这个型号的,我在Richardson gratings的产品列表里也没找到。非常感谢!
感谢您关注TI的DLP产品。
Product list (640R):
www.gratinglab.com/.../T2.aspx
Grating specs:
www.gratinglab.com/.../Efficiency.aspx
Available overstock parts:
www.gratinglab.com/.../Overstock.aspx
• Both aluminum and gold coated versions are available. Our system used aluminum because it is more inexpensive, although gold would have a higher efficiency.
The important specifications to match if it is being replaced are:
• 300 grooves per mm
• 1.2μm nominal blaze wavelength
• 10.4° nominal blaze angle
• Dimensions: 8x8x3mm
