DMA实现数据处理,实现声音采集,声音处理,及播放
运用5509a,通过配置DMA来实现中断处理,在中段处理函数中实现声音的处理和播放,但是不知道为何播放后的声音是不对的,单步调试的时候会出现声音处理迭代系数只有0和-1两种数字,希望能够得到各位的指教。
/* Define transmit and receive buffers */
#pragma DATA_SECTION(xmt,"dmaMem")
Uint16 xmt[N];
#pragma DATA_SECTION(rcv,"dmaMem")
Uint16 rcv[N];
/*锁相环的设置*/
PLL_Config myConfig     = {
0,   //IAI: the PLL locks using the same process that was underway
               //before the idle mode was entered
1,   //IOB: If the PLL indicates a break in the phase lock,
               //it switches to its bypass mode and restarts the PLL phase-locking
               //sequence
24,   //PLL multiply value; multiply 24 times
1             //Divide by 2 PLL divide value; it can be either PLL divide value
              //(when PLL is enabled), or Bypass-mode divide value
               //(PLL in bypass mode, if PLL multiply value is set to 1)
/**********************************MCBSP设置************************************************/
MCBSP_Config ConfigLoopBack16= {
MCBSP_SPCR1_RMK(
   MCBSP_SPCR1_DLB_OFF,                   /* DLB   = 0,禁止自闭环方式 */
   MCBSP_SPCR1_RJUST_LZF,                 /* RJUST = 2 */
   MCBSP_SPCR1_CLKSTP_DISABLE,           /* CLKSTP = 0 */
   MCBSP_SPCR1_DXENA_ON,                 /* DXENA = 1 */
   0,                                     /* ABIS   = 0 */
   MCBSP_SPCR1_RINTM_RRDY,               /* RINTM = 0 */
   0,                                    /* RSYNCER = 0 */
   MCBSP_SPCR1_RRST_DISABLE               /* RRST   = 0 */
   MCBSP_SPCR2_RMK(
   MCBSP_SPCR2_FREE_NO,                   /* FREE   = 0 */
   MCBSP_SPCR2_SOFT_NO,                   /* SOFT   = 0 */
   MCBSP_SPCR2_FRST_FSG,                 /* FRST   = 0 */
   MCBSP_SPCR2_GRST_CLKG,                 /* GRST   = 0 */
   MCBSP_SPCR2_XINTM_XRDY,               /* XINTM = 0 */
   0,                                     /* XSYNCER = N/A */
 MCBSP_SPCR2_XRST_DISABLE               /* XRST   = 0 */
   /*单数据相,接受数据长度为16位,每相2个数据*/
MCBSP_RCR1_RMK(
    MCBSP_RCR1_RFRLEN1_OF(1),             /* RFRLEN1 = 1 */
    MCBSP_RCR1_RWDLEN1_16BIT               /* RWDLEN1 = 2 */
MCBSP_RCR2_RMK(
   MCBSP_RCR2_RPHASE_SINGLE,             /* RPHASE = 0 */
   MCBSP_RCR2_RFRLEN2_OF(0),             /* RFRLEN2 = 0 */
   MCBSP_RCR2_RWDLEN2_8BIT,               /* RWDLEN2 = 0 */
   MCBSP_RCR2_RCOMPAND_MSB,               /* RCOMPAND = 0 */
   MCBSP_RCR2_RFIG_YES,                   /* RFIG   = 0 */
   MCBSP_RCR2_RDATDLY_1BIT               /* RDATDLY = 1 */
   MCBSP_XCR1_RMK(
   MCBSP_XCR1_XFRLEN1_OF(1),             /* XFRLEN1 = 1 */
   MCBSP_XCR1_XWDLEN1_16BIT               /* XWDLEN1 = 2 */
MCBSP_XCR2_RMK(
   MCBSP_XCR2_XPHASE_SINGLE,             /* XPHASE = 0 */
   MCBSP_XCR2_XFRLEN2_OF(0),             /* XFRLEN2 = 0 */
   MCBSP_XCR2_XWDLEN2_8BIT,               /* XWDLEN2 = 0 */
   MCBSP_XCR2_XCOMPAND_MSB,               /* XCOMPAND = 0 */
   MCBSP_XCR2_XFIG_YES,                   /* XFIG   = 0 */
   MCBSP_XCR2_XDATDLY_1BIT               /* XDATDLY = 1 */
MCBSP_SRGR1_DEFAULT,
MCBSP_SRGR2_DEFAULT,
MCBSP_MCR1_DEFAULT,
MCBSP_MCR2_DEFAULT,
MCBSP_PCR_RMK(
   MCBSP_PCR_IDLEEN_RESET,                 /* IDLEEN   = 0   */
   MCBSP_PCR_XIOEN_SP,                     /* XIOEN   = 0   */
   MCBSP_PCR_RIOEN_SP,                     /* RIOEN   = 0   */
   MCBSP_PCR_FSXM_EXTERNAL,               /* FSXM     = 0   */
   MCBSP_PCR_FSRM_EXTERNAL,               /* FSRM     = 0   */
   0,                                     /* DXSTAT = N/A   */
   MCBSP_PCR_CLKXM_INPUT,                 /* CLKXM   = 0   */
   MCBSP_PCR_CLKRM_INPUT,                 /* CLKRM   = 0   */
   MCBSP_PCR_SCLKME_NO,                   /* SCLKME   = 0   */
   MCBSP_PCR_FSXP_ACTIVEHIGH,             /* FSXP     = 0   */
   MCBSP_PCR_FSRP_ACTIVEHIGH,             /* FSRP     = 1   */
   MCBSP_PCR_CLKXP_FALLING,               /* CLKXP   = 1   */
   MCBSP_PCR_CLKRP_RISING                 /* CLKRP   = 1   */
MCBSP_RCERA_DEFAULT,
MCBSP_RCERB_DEFAULT,
MCBSP_RCERC_DEFAULT,
MCBSP_RCERD_DEFAULT,
MCBSP_RCERE_DEFAULT,
MCBSP_RCERF_DEFAULT,
MCBSP_RCERG_DEFAULT,
MCBSP_RCERH_DEFAULT,
MCBSP_XCERA_DEFAULT,
MCBSP_XCERB_DEFAULT,
MCBSP_XCERC_DEFAULT,
MCBSP_XCERD_DEFAULT,
MCBSP_XCERE_DEFAULT,
MCBSP_XCERF_DEFAULT,
MCBSP_XCERG_DEFAULT,
MCBSP_XCERH_DEFAULT
/************************************DMA设置************************************************/
/* Create DMA Receive Side Configuration */
DMA_Config dmaRcvConfig = {
DMA_DMACSDP_RMK(
   DMA_DMACSDP_DSTBEN_NOBURST,   //Destination burst :-不使用突发
   DMA_DMACSDP_DSTPACK_OFF,       //Destination packing :-目标口禁止打包
   DMA_DMACSDP_DST_DARAM,         //Destination selection :-接收的目标口是DARAM
   DMA_DMACSDP_SRCBEN_NOBURST,   //Source burst :-源突发禁止
   DMA_DMACSDP_SRCPACK_OFF,       //Source packing :-源口禁止打包
   DMA_DMACSDP_SRC_PERIPH,       //Source selection :-外设mcbsp
   DMA_DMACSDP_DATATYPE_16BIT     //Data type :-设置数据类型16bit字长
),                               /* DMACSDP 源与目标参数寄存器 */
DMA_DMACCR_RMK(
   DMA_DMACCR_DSTAMODE_POSTINC,   //Destination address mode :-自动执行后增量(由于本程序中数据类型是16bit,所以+2)
   DMA_DMACCR_SRCAMODE_CONST,     //Source address mode :-源地址为恒定地址
   DMA_DMACCR_ENDPROG_ON,         //End of programmation bit :-
   DMA_DMACCR_REPEAT_ON,           //Repeat condition :-不管编程配置结束位,结束传输自动初始化开始
   //DMA_DMACCR_REPEAT_OFF,
   DMA_DMACCR_AUTOINIT_ON,         //Auto initialization bit :-
       //DMA_DMACCR_AUTOINIT_OFF,
   DMA_DMACCR_EN_STOP,             //Channel enable :-设置时先关闭通道
   DMA_DMACCR_PRIO_LOW,           //Channel priority :-设置为低优先级
   DMA_DMACCR_FS_ELEMENT,         //Frame/Element Sync :-单元事件同步
       //DMA_DMACCR_FS_DISABLE,
   DMA_DMACCR_SYNC_REVT0          //Synchronization control :-McBSP1 Receive Event(REVT1)
),                                       /* DMACCR 通道控制寄存器 */
DMA_DMACICR_RMK(
   DMA_DMACICR_BLOCKIE_ON,       //Whole block interrupt enable :-块传输完成后中断使能
   //DMA_DMACICR_BLOCKIE_OFF,
   DMA_DMACICR_LASTIE_OFF,       //Last frame interrupt enable :-
   DMA_DMACICR_FRAMEIE_OFF,     //Whole frame interrupt enable :-
       //DMA_DMACICR_FRAMEIE_ON,
   DMA_DMACICR_FIRSTHALFIE_OFF, //Half frame interrupt enable :-
   DMA_DMACICR_DROPIE_OFF,       //Sync. event drop interrupt enable :-
   DMA_DMACICR_TIMEOUTIE_OFF     //Time out interrupt enable :-
),                                       /* DMACICR 中断控制寄存器 */
   (DMA_AdrPtr)(MCBSP_ADDR(DRR10)),       /* DMACSSAL 源地址低位 */
   0,                                     /* DMACSSAU 源地址高位*/
   (DMA_AdrPtr)&rcv,                 /* DMACDSAL 目的地址低位*/
   0,                                     /* DMACDSAU 目的地址高位*/
   2,                                     /* DMACEN   1 帧内数据长度 16*2 两个数据一个帧*/
   N/2,                                   /* DMACFN 帧数大小 */
   0,                                     /* DMACFI */
   0                                     /* DMACEI */
/* Create DMA Transmit Side Configuration */
DMA_Config dmaXmtConfig = {
DMA_DMACSDP_RMK(
   DMA_DMACSDP_DST_PERIPH,       //Destination selection :-接收的目标口是外设mcbsp
   DMA_DMACSDP_SRC_DARAM,         //Source selection :源口为DARAM
DMA_DMACCR_RMK(
   DMA_DMACCR_DSTAMODE_CONST,   //Destination address mode :-目标口地址为恒定地址
   DMA_DMACCR_SRCAMODE_POSTINC, //Source address mode :-自动执行后增量(由于本程序中数据类型是16bit,所以+2)
   DMA_DMACCR_SYNC_XEVT0        //Synchronization control :-McBSP1 Transmit Event(XEVT1)
DMA_DMACICR_RMK(
   (DMA_AdrPtr)&xmt[0],               /* DMACSSAL 源地址低位*/
   0,                                     /* DMACSSAU 源地址高位 */
   (DMA_AdrPtr)(MCBSP_ADDR(DXR10)),       /* DMACDSAL 目的地址低位*/
   0,                                     /* DMACFI   */
   0                                     /* DMACEI   */
/* Define a DMA_Handle object to be used with DMA_open function */
DMA_Handle hDmaRcv, hDmaXmt;
/* Define a MCBSP_Handle object to be used with MCBSP_open function */
MCBSP_Handle hMcbsp;
volatile Uint16 transferComplete = FALSE;
Uint16 err = 0;
Uint16 old_intm;
Uint16 xmtEventId, rcvEventId;
//---------Function prototypes---------
/* Reference start of interrupt vector table   */
/* This symbol is defined in file, vectors.s55 */
extern void VECSTART(void);
/* Protoype for interrupt functions */
interrupt void dmaXmtIsr(void);
interrupt void dmaRcvIsr(void);
void taskFxn(void);
/***********************************I2C的设置和AIC的设置************************************/
/* This next struct shows how to use the I2C API */
/* Create and initialize an I2C initialization structure */
I2C_Setup I2Cinit = {
       0,             /* 7 bit address mode */
       0,         /* own address - don't care if master */
       144,           /* clkout value (Mhz) */
       50,           /* a number between 10 and 400*/
       0,             /* number of bits/byte to be received or transmitted (8)*/
       0,             /* DLB mode on*/
       1               /* FREE mode of operation on*/
/*数字音频接口格式设置
AIC23为主模式,数据为DSP模式,数据长度16位*/
Uint16 digital_audio_inteface_format[2]={0x0e,0x53};
/*AIC23的波特率设置,采样率为44.1K*/
Uint16 sample_rate_control[2] = {0x10,0x23};
/*AIC23寄存器复位*/
Uint16 reset[2] ={0x1e,0x00};
/*AIC23节电方式设置,所有部分均所与工作状态*/
Uint16 power_down_control[2] ={0x0c,0x00};
/*AIC23模拟音频的控制
DAC使能,ADC输入选择为mic*/
Uint16 analog_aduio_path_control[2] ={0x08,0x10};
//Uint16 analog_aduio_path_control[2] ={0x08,0x15};//MIC IN 有增益
//Uint16 analog_aduio_path_control[2] ={0x08,0x14};//MIC IN 无增益
//Uint16 analog_aduio_path_control[2] ={0x08,0x10};//Line IN
/*AIC23数字音频通路的控制*/
Uint16 digital_audio_path_control[2] ={0x0a,0x05};
/*AIC23数字接口的使能*/
Uint16 digital_interface_activation[2] ={0x12,0x01};
/*AIC23左通路音频调节*/
Uint16 left_line_input_volume_control[2] ={0x00,0x17};
/*AIC23右通路音频调节*/
Uint16 right_line_input_volume_control[2] ={0x02,0x17};
/*AIC23耳机左通路音频调节*/
Uint16 left_headphone_volume_control[2] ={0x05,0xFF};
/*AIC23耳机右通路音频调节*/
Uint16 right_headphone_volume_control[2] = {0x07,0xFF};
void delay(Uint32 k)
   while(k--);
void CODEC(void)
   //printf ("%s\n","CODEC");
       /*I2C is undet reset*/
       I2C_RSET(I2CMDR,0);
       /*设置预分频寄存器,I2C的mode clock is 10MHz*/
       delay(100);
       I2C_RSET(I2CSAR,0x001A);
       I2C_RSET(I2CMDR,0x0620);
   I2C_setup(&I2Cinit);
    /*设置I2C的Mater clock*/
       I2C_RSET(I2CCLKL,100);
       I2C_RSET(I2CCLKH,100);
   /*reset AIC23*/
   i2c_status = I2C_write( reset,         //pointer to data array
                                2,                         //length of data to be transmitted
                                1,                         //master or slaver
                                CODEC_ADDR,         //slave address to transmit to
                                 1,                         //transfer mode of operation
                                30000                   //time out for bus busy
       delay(1000);
   /*设置AIC23各部分均工作*/
   i2c_status = I2C_write( power_down_control,//pointer to data array
       /*设置AIC23的数字接口*/
       i2c_status = I2C_write( digital_audio_inteface_format,//pointer to data array
       /*设置AIC23模拟通路*/
       i2c_status = I2C_write( analog_aduio_path_control,//pointer to data array
       /*设置数字通路*/
       i2c_status = I2C_write( digital_audio_path_control,//pointer to data array
       /*设置AIC23的采样率*/
       i2c_status = I2C_write( sample_rate_control,//pointer to data array
       /*设置耳机音量*/
       i2c_status = I2C_write( left_headphone_volume_control,//pointer to data array
       i2c_status = I2C_write( right_headphone_volume_control,//pointer to data array
       /*设置Line输入的音量*/
       i2c_status = I2C_write( left_line_input_volume_control,//pointer to data array
       i2c_status = I2C_write( right_line_input_volume_control,//pointer to data array
       /*启动AIC23*/
       i2c_status = I2C_write( digital_interface_activation,//pointer to data array
int ShiftArray(int *Sx,int lastx)
   int i;
   for(i=n-1;i>0;i--)
          Sx[i]=Sx[i-1];
          Sx[0]=lastx;
          return(0);
int dotProd(int *Firx,int *Firh)
   int i;
   int sum=0;
   for(i=0;i<n;i++)
     sum+=(Firx[i]*Firh[i]);
       return(sum);
int fxlms(int *xx,int *XX,int ee)
   int yy;
   int i;
   long temp;
   ShiftArray(en,e);
   e=dotProd(en,H3);
   x=e-d;
   ShiftArray(xn,x);
   X=dotProd(xn,H3);
   ShiftArray(Xn,X);
   for(i=0;i<n;i++)
     temp=(long)(XX[i]*ee*u);
       wn[i]=wn[i]+(temp)>>(15);
   for(i=0;i<n;i++)
       yy+=xx[i]*wn[i];
   return(yy);
//---------main routine---------
void main(void)
   Uint16 i;
   for(i=n-1;i>0;i--)
       wn[i]=0;
       xn[i]=0;
       yn[i]=0;
       en[i]=0;
   /* Initialize CSL library - This is REQUIRED !!! */
   CSL_init();
   /* Set IVPD/IVPH to start of interrupt vector table */
   IRQ_setVecs((Uint32)(&VECSTART));
       PLL_config(&myConfig);
   /* Call function to effect transfer */
       CODEC();
   taskFxn();
void taskFxn(void)
   Uint16 srcAddrHi, srcAddrLo;
   Uint16 dstAddrHi, dstAddrLo;
   Uint16 i;
   /* By default, the TMS320C55xx compiler assigns all data symbols word */
   /* addresses. The DMA however, expects all addresses to be byte       */
   /* addresses. Therefore, we must shift the address by 2 in order to   */
   /* change the word address to a byte address for the DMA transfer.   */
   srcAddrHi = (Uint16)(((Uint32)(MCBSP_ADDR(DRR10))) >> 15) & 0xFFFFu;
   srcAddrLo = (Uint16)(((Uint32)(MCBSP_ADDR(DRR10))) << 1) & 0xFFFFu;
   dstAddrHi = (Uint16)(((Uint32)(&rcv)) >> 15) & 0xFFFFu;
   dstAddrLo = (Uint16)(((Uint32)(&rcv)) << 1) & 0xFFFFu;
   dmaRcvConfig.dmacssal = (DMA_AdrPtr)srcAddrLo;
   dmaRcvConfig.dmacssau = srcAddrHi;
   dmaRcvConfig.dmacdsal = (DMA_AdrPtr)dstAddrLo;
   dmaRcvConfig.dmacdsau = dstAddrHi;
   srcAddrHi = (Uint16)(((Uint32)(&xmt[0])) >> 15) & 0xFFFFu;
   srcAddrLo = (Uint16)(((Uint32)(&xmt[0])) << 1) & 0xFFFFu;
   dstAddrHi = (Uint16)(((Uint32)(MCBSP_ADDR(DXR10))) >> 15) & 0xFFFFu;
   dstAddrLo = (Uint16)(((Uint32)(MCBSP_ADDR(DXR10))) << 1) & 0xFFFFu;
   dmaXmtConfig.dmacssal = (DMA_AdrPtr)srcAddrLo;
   dmaXmtConfig.dmacssau = srcAddrHi;
   dmaXmtConfig.dmacdsal = (DMA_AdrPtr)dstAddrLo;
   dmaXmtConfig.dmacdsau = dstAddrHi;
   /* Open MCBSP Port 1 and set registers to their power on defaults */
   hMcbsp = MCBSP_open(MCBSP_PORT0, MCBSP_OPEN_RESET);
   /* Open DMA channels 4 & 5 and set regs to power on defaults */
   hDmaRcv = DMA_open(DMA_CHA4,DMA_OPEN_RESET);
   hDmaXmt = DMA_open(DMA_CHA5,DMA_OPEN_RESET);
   /* Get interrupt event associated with DMA receive and transmit */
   xmtEventId = DMA_getEventId(hDmaXmt);
   rcvEventId = DMA_getEventId(hDmaRcv);
   /* Temporarily disable interrupts and clear any pending */
   /* interrupts for MCBSP transmit */
   old_intm = IRQ_globalDisable();
   /* Clear any pending interrupts for DMA channels */
   IRQ_clear(xmtEventId);
   IRQ_clear(rcvEventId);
   /* Enable DMA interrupt in IER register */
   IRQ_enable(xmtEventId);
   IRQ_enable(rcvEventId);
   /* Set Start Of Interrupt Vector Table */
   IRQ_setVecs(0x10000);
   /* Place DMA interrupt service addresses at associate vector */
   IRQ_plug(xmtEventId,&dmaXmtIsr);
   IRQ_plug(rcvEventId,&dmaRcvIsr);
   /* Write values from configuration structure to MCBSP control regs */
   MCBSP_config(hMcbsp, &ConfigLoopBack16);
   /* Write values from configuration structure to DMA control regs */
   DMA_config(hDmaRcv,&dmaRcvConfig);
   DMA_config(hDmaXmt,&dmaXmtConfig);
#if 0
   /* Take MCBSP transmit and receive out of reset */
   MCBSP_start(hMcbsp,
               MCBSP_XMIT_START | MCBSP_RCV_START,
               0u);
   /* Prime MCBSP DXR */
   while (!(MCBSP_xrdy(hMcbsp))){
   MCBSP_write16(hMcbsp,xmt[0]);
   /* Enable all maskable interrupts */
   IRQ_globalEnable();
   /* Enable DMA */
   DMA_start(hDmaRcv);
   DMA_start(hDmaXmt);
   /* Start Sample Rate Generator and Enable Frame Sync */
   MCBSP_start(hMcbsp,
               MCBSP_SRGR_START | MCBSP_SRGR_FRAMESYNC,
               0x300u);
       printf ("%s\n""IF");
#else
   IRQ_globalEnable();
   MCBSP_start(hMcbsp,
               0x300u);
   /* Enable DMA */
   DMA_start(hDmaRcv);
   DMA_start(hDmaXmt);
   MCBSP_start(hMcbsp,
               0u);
       printf ("%s\n","ELSE");
#endif
   //while(DMA_FGETH(hDmaRcv, DMACCR, ENDPROG));
   /* Wait for DMA transfer to be complete */
   //DMA_FSETH(hDmaRcv, DMACCR, ENDPROG,1);
   //DMA_FSETH(hDmaXmt, DMACCR, ENDPROG,1);
   //printf ("%s\n","AGAIN");
       //printf ("%s\n",err?"TEST FAILED" : "TEST PASSED");
   /* Restore status of global interrupt enable flag */
   //IRQ_globalRestore(old_intm);
   /* We're done with MCBSP and DMA , so close them */
   //MCBSP_close(hMcbsp);
   //DMA_close(hDmaRcv);
   //DMA_close(hDmaXmt);
interrupt void dmaXmtIsr(void) {
   Uint16 i;
   //DMA_stop(hDmaXmt);
   //IRQ_disable(xmtEventId);
   //printf ("%s\n","dmaXmtIsr");
   //DMA_start(hDmaRcv);
   //DMA_start(hDmaXmt);
   TestflagT++;
interrupt void dmaRcvIsr(void) {
   //DMA_stop(hDmaRcv);
   //IRQ_disable(rcvEventId);
   //printf ("%s\n","dmaRcvIsr");
//   Uint16 i;
//   for(i = 0; i <= N - 1; i++)
//       xmt[i]=rcv[i];
       int i;
       for(i = 0; i < N; i++)
       e=rcv[i];
       y=fxlms(xn,Xn,e);
       xmt[i]=y;
     ShiftArray(yn,y);
       d=dotProd(yn,H3)+e;
   DMA_start(hDmaXmt);
   TestflagR++;
4 个回复
