client 调试可以,烧写nand启动后,任务没有启动,求解
在client例程里加了创建了流水灯任务,调试通过,烧写进去试了也可以,把原工程里创建一个连接主机IP收发数据的任务,调试通过,烧写进去还是启动不正常,但是在主函数加了流水灯操作,流水灯能启动,TCP连接主机IP的任务没有启动。有3个疑问,1:client里的StackTest任务是怎么执行的?2:在这个client例程里加IP连接该在哪里加?3:为什么调试的时候可以连接上本地设置的静态IP,烧写进去连接不上了?看到论坛里很多这个问题,没有能够解决问题的,等我这个问题解决了,会整理思路,贴出来。现在请您帮我分析下,非常感谢!
修改后的client.c 程序如下:
 *  ======== client.c ========
 * TCP/IP Network Client example ported to use BIOS6 OS.
 * Copyright (C) 2007 Texas Instruments Incorporated - http://www.ti.com/
 *  Redistribution and use in source and binary forms, with or without
 *  modification, are permitted provided that the following conditions
 *  are met:
 *    Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 *    Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the
 *    distribution.
 *    Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
 *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
 *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
 *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
 *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
 *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
 *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <ti/ndk/inc/netmain.h>
#include <ti/ndk/inc/_stack.h>
#include <ti/ndk/inc/tools/console.h>
#include <ti/ndk/inc/tools/servers.h>
#include "client.h"
/* BIOS6 include */
#include <ti/sysbios/BIOS.h>
/* Platform utilities include */
#include <ti/platform/platform.h>
#include <ti/sysbios/knl/Semaphore.h>
// When USE_OLD_SERVERS set to zero, server daemon is used
#define USE_OLD_SERVERS 0
// Title String
char *VerStr = "\nTCP/IP Stack Example Client\n";
// Our NETCTRL callback functions
static void   NetworkOpen();
static void   NetworkClose();
static void   NetworkIPAddr( IPN IPAddr, uint IfIdx, uint fAdd );
// Fun reporting function
static void   ServiceReport( uint Item, uint Status, uint Report, HANDLE hCfgEntry );
// Configuration
char *HostName    = "tidsp";
char *LocalIPAddr = "192.168.1.43";                  // Set to "0.0.0.0" for DHCP
char *LocalIPMask = "255.255.254.0";    // Not used when using DHCP
char *GatewayIP   = "0.0.0.0";                  // Not used when using DHCP
char *DomainName  = "demo.net";         // Not used when using DHCP
char *DNSServer   = "0.0.0.0";          // Used when set to anything but zero
UINT8 DHCP_OPTIONS[] = { DHCPOPT_SERVER_IDENTIFIER, DHCPOPT_ROUTER };
#undef     TEST_RAW_NC
#undef     TEST_RAW_SEND
#undef     TEST_RAW_RECV
#define     PACKET_SIZE     1000
#define     PACKET_COUNT    1
#ifdef      TEST_RAW_SEND
static HANDLE hSendRaw = 0;
static void SendRawEth();
#endif
#ifdef      TEST_RAW_RECV
static HANDLE hRecvRaw = 0;
static void RecvRawEth();
#endif
 *  @b EVM_init()
 *  @n
 *  Initializes the platform hardware. This routine is configured to start in
 *  the evm.cfg configuration file. It is the first routine that BIOS
 *  calls and is executed before Main is called. If you are debugging within
 *  CCS the default option in your target configuration file may be to execute
 *  all code up until Main as the image loads. To debug this you should disable
 *  that option.
 *  @param[in]  None
 *  @retval
 *      None
void EVM_init()
int i;
platform_init_flags  sFlags;
platform_init_config sConfig;
    /* Status of the call to initialize the platform */
    Int32 pform_status;
    /* Platform Information - we will read it form the Platform Library */
    platform_info sPlatformInfo;
 * You can choose what to initialize on the platform by setting the following
 * flags. We will initialize everything.
memset( (void *) &sFlags,  0, sizeof(platform_init_flags));
memset( (void *) &sConfig, 0, sizeof(platform_init_config));
sFlags.pll = 0;
sFlags.ddr = 0;
    sFlags.tcsl = 0; /* Time stamp counter  */
    sFlags.phy  = 0; /* Ethernet  */
    sFlags.ecc = 0;
    sConfig.pllm = 0;
pform_status = platform_init(&sFlags, &sConfig);
/* If we initialized the platform okay */
if (pform_status == Platform_EOK) {
/* Get information about the platform so we can use it in various places */
memset( (void *) &sPlatformInfo, 0, sizeof(platform_info));
(void) platform_get_info(&sPlatformInfo);
else {
/* Intiialization of the platform failed... die */
printf("Platform failed to initialize. Error code %d \n", pform_status);
printf("We will die in an infinite loop... \n");
while (1) {
(void) platform_led(1, PLATFORM_LED_ON, (LED_CLASS_E) PLATFORM_USER_LED_CLASS);
(void) platform_delay(50000);
(void) platform_led(1, PLATFORM_LED_OFF, (LED_CLASS_E) PLATFORM_USER_LED_CLASS);
platform_write_configure(PLATFORM_WRITE_PRINTF);
platform_uart_init();
platform_uart_set_baudrate(19200);
/* Check to see that we are running on the Master Core */
if (platform_get_coreid() != 0) {
/* We are not on the Master Core... die */
printf("You must run this application on Core 0. \n");
while (1) {
/* Clear the state of the LEDs to OFF */
for (i=0; i < sPlatformInfo.led[1].count; i++) {
platform_led(i, PLATFORM_LED_OFF, (LED_CLASS_E) PLATFORM_USER_LED_CLASS);
return;
char *IPStr = "192.168.1.42";
unsigned int Port = 8000;
Semaphore_Handle sem;
void TcpTest(void)
sem = Semaphore_create(0, NULL, NULL);
// 等待初始化完成
Semaphore_pend(sem, BIOS_WAIT_FOREVER);
printf("Trying to connect 192.168.1.42:8000 ......\n");
    SOCKET  s;
    struct  sockaddr_in SinDst;
    int i;
    char Title[] = "Tronlong Tcp Client Application";
    char *pBuf;
    struct  timeval timeout;
    HANDLE hBuffer;
    // 为任务分配文件描述符并打开一个会话
    fdOpenSession(TaskSelf());
// 创建套接字
s = socket(AF_INET, SOCK_STREAMNC, IPPROTO_TCP);
if(s == INVALID_SOCKET)
printf("failed socket create (%d)\n", fdError());
goto error;
// IP 地址
mmZeroInit(&SinDst, sizeof(struct sockaddr_in));
IPN IPAddr;
    if(!ConStrToIPN(IPStr, &IPAddr))
     printf("Invalid address\n\n");
    SinDst.sin_family      = AF_INET;
    SinDst.sin_addr.s_addr = IPAddr;
    SinDst.sin_port        = htons(Port);
// 超时时间  5秒
timeout.tv_sec  = 5;
timeout.tv_usec = 0;
setsockopt(s, SOL_SOCKET, SO_SNDTIMEO, &timeout, sizeof( timeout ));
setsockopt(s, SOL_SOCKET, SO_RCVTIMEO, &timeout, sizeof( timeout ));
// 建立连接
if(connect(s, (PSA) &SinDst, sizeof(SinDst)) < 0)
printf("failed connect (%d)\n", fdError());
goto error;
printf("Established the connection.\n");
    // 发送一个固定字符串 长度 31
send(s, &Title, 31, 0);
// 测试
    for(;;)
     // 接收数据
     i = (int)recvnc(s, (void **)&pBuf, 0, &hBuffer);
     // 回传接收到的数据
        if(i > 0)
            if(send(s, pBuf, i, 0 ) < 0)
                break;
            recvncfree(hBuffer);
        else
            continue;
error:
if(s != INVALID_SOCKET)
fdClose(s);
// 关闭文件会话
fdCloseSession(TaskSelf());
HANDLE hTask;
void NetOpenHook()
hTask = TaskCreate(TcpTest, "TcpTest", OS_TASKPRINORM, OS_TASKSTKNORM, 0, 0, 0);
void NetCloseHook()
TaskDestroy(hTask);
int ledPlayTask (void) {
platform_info p_info;
uint32_t led_no = 0;
uint32_t ledloop=0;
/* Get information about the platform */
platform_get_info(&p_info);
platform_write("Lets twinkle some LED's\n");
/* Play forever */
for(ledloop=0;ledloop<50;ledloop++) {
platform_led(led_no, PLATFORM_LED_ON, PLATFORM_USER_LED_CLASS);
platform_delay(30000);
platform_led(led_no, PLATFORM_LED_OFF,PLATFORM_USER_LED_CLASS);
led_no = (++led_no) %
p_info.led[PLATFORM_USER_LED_CLASS].count;
return 0;
// Main Entry Point
int main()
ledPlayTask();
NetOpenHook();
    /* Start the BIOS 6 Scheduler */
BIOS_start ();
// Main Thread
int StackTest()
    int               rc;
    HANDLE            hCfg;
    CI_SERVICE_TELNET telnet;
    CI_SERVICE_HTTP   http;
    // THIS MUST BE THE ABSOLUTE FIRST THING DONE IN AN APPLICATION!!
    rc = NC_SystemOpen( NC_PRIORITY_LOW, NC_OPMODE_INTERRUPT );
    if( rc )
        printf("NC_SystemOpen Failed (%d)\n",rc);
        for(;;);
    // Print out our banner
    printf(VerStr);
    // Create and build the system configuration from scratch.
    // Create a new configuration
    hCfg = CfgNew();
    if( !hCfg )
        printf("Unable to create configuration\n");
        goto main_exit;
    // We better validate the length of the supplied names
    if( strlen( DomainName ) >= CFG_DOMAIN_MAX ||
        strlen( HostName ) >= CFG_HOSTNAME_MAX )
        printf("Names too long\n");
        goto main_exit;
    // Add our global hostname to hCfg (to be claimed in all connected domains)
    CfgAddEntry( hCfg, CFGTAG_SYSINFO, CFGITEM_DHCP_HOSTNAME, 0,
                 strlen(HostName), (UINT8 *)HostName, 0 );
    // If the IP address is specified, manually configure IP and Gateway
    if( inet_addr(LocalIPAddr) )
        CI_IPNET NA;
        CI_ROUTE RT;
        IPN      IPTmp;
        // Setup manual IP address
        bzero( &NA, sizeof(NA) );
        NA.IPAddr  = inet_addr(LocalIPAddr);
        NA.IPMask  = inet_addr(LocalIPMask);
        strcpy( NA.Domain, DomainName );
        NA.NetType = 0;
        // Add the address to interface 1
        CfgAddEntry( hCfg, CFGTAG_IPNET, 1, 0,
                           sizeof(CI_IPNET), (UINT8 *)&NA, 0 );
        // Add the default gateway. Since it is the default, the
        // destination address and mask are both zero (we go ahead
        // and show the assignment for clarity).
        bzero( &RT, sizeof(RT) );
        RT.IPDestAddr = 0;
        RT.IPDestMask = 0;
        RT.IPGateAddr = inet_addr(GatewayIP);
        // Add the route
        CfgAddEntry( hCfg, CFGTAG_ROUTE, 0, 0,
                           sizeof(CI_ROUTE), (UINT8 *)&RT, 0 );
        // Manually add the DNS server when specified
        IPTmp = inet_addr(DNSServer);
        if( IPTmp )
            CfgAddEntry( hCfg, CFGTAG_SYSINFO, CFGITEM_DHCP_DOMAINNAMESERVER,
                         0, sizeof(IPTmp), (UINT8 *)&IPTmp, 0 );
    // Else we specify DHCP
    else
        CI_SERVICE_DHCPC dhcpc;
        // Specify DHCP Service on IF-1
        bzero( &dhcpc, sizeof(dhcpc) );
        dhcpc.cisargs.Mode   = CIS_FLG_IFIDXVALID;
        dhcpc.cisargs.IfIdx  = 1;
        dhcpc.cisargs.pCbSrv = &ServiceReport;
        dhcpc.param.pOptions = DHCP_OPTIONS;
        dhcpc.param.len = 2;
        CfgAddEntry( hCfg, CFGTAG_SERVICE, CFGITEM_SERVICE_DHCPCLIENT, 0,
                     sizeof(dhcpc), (UINT8 *)&dhcpc, 0 );
    // Specify TELNET service for our Console example
    bzero( &telnet, sizeof(telnet) );
    telnet.cisargs.IPAddr = INADDR_ANY;
    telnet.cisargs.pCbSrv = &ServiceReport;
    telnet.param.MaxCon   = 2;
    telnet.param.Callback = &ConsoleOpen;
    CfgAddEntry( hCfg, CFGTAG_SERVICE, CFGITEM_SERVICE_TELNET, 0,
                 sizeof(telnet), (UINT8 *)&telnet, 0 );
    // Create RAM based WEB files for HTTP
    AddWebFiles();
    // HTTP Authentication
        CI_ACCT CA;
        // Name our authentication group for HTTP (Max size = 31)
        // This is the authentication "realm" name returned by the HTTP
        // server when authentication is required on group 1.
        CfgAddEntry( hCfg, CFGTAG_SYSINFO, CFGITEM_SYSINFO_REALM1,
                     0, 30, (UINT8 *)"DSP_CLIENT_DEMO_AUTHENTICATE1", 0 );
        // Create a sample user account who is a member of realm 1.
        // The username and password are just "username" and "password"
        strcpy( CA.Username, "username" );
        strcpy( CA.Password, "password" );
        CA.Flags = CFG_ACCTFLG_CH1;  // Make a member of realm 1
        rc = CfgAddEntry( hCfg, CFGTAG_ACCT, CFGITEM_ACCT_REALM,
                          0, sizeof(CI_ACCT), (UINT8 *)&CA, 0 );
    // Specify HTTP service
    bzero( &http, sizeof(http) );
    http.cisargs.IPAddr = INADDR_ANY;
    http.cisargs.pCbSrv = &ServiceReport;
    CfgAddEntry( hCfg, CFGTAG_SERVICE, CFGITEM_SERVICE_HTTP, 0,
                 sizeof(http), (UINT8 *)&http, 0 );
    // Configure IPStack/OS Options
    // We don't want to see debug messages less than WARNINGS
    rc = DBG_INFO;
    CfgAddEntry( hCfg, CFGTAG_OS, CFGITEM_OS_DBGPRINTLEVEL,
                 CFG_ADDMODE_UNIQUE, sizeof(uint), (UINT8 *)&rc, 0 );
    // This code sets up the TCP and UDP buffer sizes
    // (Note 8192 is actually the default. This code is here to
    // illustrate how the buffer and limit sizes are configured.)
    // TCP Transmit buffer size
    rc = 8192;
    CfgAddEntry( hCfg, CFGTAG_IP, CFGITEM_IP_SOCKTCPTXBUF,
    // TCP Receive buffer size (copy mode)
    rc = 8192;
    CfgAddEntry( hCfg, CFGTAG_IP, CFGITEM_IP_SOCKTCPRXBUF,
    // TCP Receive limit (non-copy mode)
    rc = 8192;
    CfgAddEntry( hCfg, CFGTAG_IP, CFGITEM_IP_SOCKTCPRXLIMIT,
    // UDP Receive limit
    rc = 8192;
    CfgAddEntry( hCfg, CFGTAG_IP, CFGITEM_IP_SOCKUDPRXLIMIT,
#if 0
    // TCP Keep Idle (10 seconds)
    rc = 100;
    //   This is the time a connection is idle before TCP will probe
    CfgAddEntry( hCfg, CFGTAG_IP, CFGITEM_IP_TCPKEEPIDLE,
    // TCP Keep Interval (1 second)
    //   This is the time between TCP KEEP probes
    rc = 10;
    CfgAddEntry( hCfg, CFGTAG_IP, CFGITEM_IP_TCPKEEPINTVL,
    // TCP Max Keep Idle (5 seconds)
    //   This is the TCP KEEP will probe before dropping the connection
    rc = 50;
    CfgAddEntry( hCfg, CFGTAG_IP, CFGITEM_IP_TCPKEEPMAXIDLE,
#endif
    // Boot the system using this configuration
    // We keep booting until the function returns 0. This allows
    // us to have a "reboot" command.
    do
        rc = NC_NetStart( hCfg, NetworkOpen, NetworkClose, NetworkIPAddr );
    } while( rc > 0 );
    // Free the WEB files
    RemoveWebFiles();
    // Delete Configuration
    CfgFree( hCfg );
    // Close the OS
main_exit:
    NC_SystemClose();
    return(0);
#if USE_OLD_SERVERS
// System Task Code [ Traditional Servers ]
static HANDLE hEcho=0,hData=0,hNull=0,hOob=0;
#ifdef _INCLUDE_IPv6_CODE
static HANDLE hEcho6=0;
#endif
// NetworkOpen
// This function is called after the configuration has booted
    // Create our local servers
    hEcho = TaskCreate( echosrv, "EchoSrv", OS_TASKPRINORM, 0x1400, 0, 0, 0 );
    hData = TaskCreate( datasrv, "DataSrv", OS_TASKPRINORM, 0x1400, 0, 0, 0 );
    hNull = TaskCreate( nullsrv, "NullSrv", OS_TASKPRINORM, 0x1400, 0, 0, 0 );
    hOob  = TaskCreate( oobsrv,   "OobSrv", OS_TASKPRINORM, 0x1000, 0, 0, 0 );
    hEcho6 = TaskCreate( v6echosrv, "V6EchoSrv", OS_TASKPRINORM, 0x1400, 0, 0, 0 );
#endif
// NetworkClose
// This function is called when the network is shutting down,
// or when it no longer has any IP addresses assigned to it.
    fdCloseSession( hOob );
    fdCloseSession( hNull );
    fdCloseSession( hData );
    fdCloseSession( hEcho );
    fdCloseSession (hEcho6);
#endif
    TaskDestroy (hSendRaw);
#endif
    TaskDestroy (hRecvRaw);
#endif
    // Kill any active console
    ConsoleClose();
    // If we opened NETCTRL as NC_PRIORITY_HIGH, we can't
    // kill our task threads until we've given them the
    // opportunity to shutdown. We do this by manually
    // setting our task priority to NC_PRIORITY_LOW.
    TaskSetPri( TaskSelf(), NC_PRIORITY_LOW );
    TaskDestroy( hOob );
    TaskDestroy( hNull );
    TaskDestroy( hData );
    TaskDestroy( hEcho );
#else
// System Task Code [ Server Daemon Servers ]
static HANDLE hEcho=0,hEchoUdp=0,hData=0,hNull=0,hOob=0;
static HANDLE hEcho6=0, hEchoUdp6=0, hTelnet6=0, hOob6=0, hWeb6=0;
#endif
// NetworkOpen
    hEcho = DaemonNew( SOCK_STREAMNC, 0, 7, dtask_tcp_echo,
                       OS_TASKPRINORM, OS_TASKSTKNORM, 0, 3 );
    hEchoUdp = DaemonNew( SOCK_DGRAM, 0, 7, dtask_udp_echo,
                          OS_TASKPRINORM, OS_TASKSTKNORM, 0, 1 );
    hData = DaemonNew( SOCK_STREAM, 0, 1000, dtask_tcp_datasrv,
    hNull = DaemonNew( SOCK_STREAMNC, 0, 1001, dtask_tcp_nullsrv,
    hOob  = DaemonNew( SOCK_STREAMNC, 0, 999, dtask_tcp_oobsrv,
    // Create the IPv6 Local Servers.
    hEcho6    = Daemon6New (SOCK_STREAM, IPV6_UNSPECIFIED_ADDRESS, 7, dtask_tcp_echo6,
    hEchoUdp6 = Daemon6New (SOCK_DGRAM, IPV6_UNSPECIFIED_ADDRESS, 7, dtask_udp_echo6,
    hTelnet6  = Daemon6New (SOCK_STREAM, IPV6_UNSPECIFIED_ADDRESS, 23,
                            (int(*)(SOCKET,UINT32))telnetClientProcess, OS_TASKPRINORM, OS_TASKSTKLOW,
                            (UINT32)ConsoleOpen, 2 );
    hOob6     = Daemon6New (SOCK_STREAM, IPV6_UNSPECIFIED_ADDRESS, 999, dtask_tcp_oobsrv,
    hWeb6     = Daemon6New (SOCK_STREAM, IPV6_UNSPECIFIED_ADDRESS, HTTPPORT, httpClientProcess,
                            OS_TASKPRINORM, OS_TASKSTKHIGH, 0, 4);
#endif
// NetworkClose
    DaemonFree( hOob );
    DaemonFree( hNull );
    DaemonFree( hData );
    DaemonFree( hEchoUdp );
    DaemonFree( hEcho );
    Daemon6Free (hEcho6);
    Daemon6Free (hEchoUdp6);
    Daemon6Free (hTelnet6);
    Daemon6Free (hOob6);
    Daemon6Free (hWeb6);
#endif
#endif
#endif
    ConsoleClose();
#endif
// NetworkIPAddr
// This function is called whenever an IP address binding is
// added or removed from the system.
    static uint fAddGroups = 0;
    IPN IPTmp;
    Semaphore_post(sem);
    if( fAdd )
        printf("Network Added: ");
    else
        printf("Network Removed: ");
    // Print a message
    IPTmp = ntohl( IPAddr );
    printf("If-%d:%d.%d.%d.%d\n", IfIdx,
            (UINT8)(IPTmp>>24)&0xFF, (UINT8)(IPTmp>>16)&0xFF,
            (UINT8)(IPTmp>>8)&0xFF, (UINT8)IPTmp&0xFF );
    // This is a good time to join any multicast group we require
    if( fAdd && !fAddGroups )
        fAddGroups = 1;
//              IGMPJoinHostGroup( inet_addr("224.1.2.3"), IfIdx );
    /* Create a Task to send/receive Raw ethernet traffic */
    hSendRaw = TaskCreate( SendRawEth, "TxRawEthTsk", OS_TASKPRINORM, 0x1400, 0, 0, 0 );
#endif
    hRecvRaw = TaskCreate( RecvRawEth, "PerformRawRX", OS_TASKPRIHIGH, 0x1400, 0, 0, 0 );
#endif
// DHCP_reset()
// Code to reset DHCP client by removing it from the active config,
// and then reinstalling it.
// Called with:
// IfIdx    set to the interface (1-n) that is using DHCP.
// fOwnTask set when called on a new task thread (via TaskCreate()).
void DHCP_reset( uint IfIdx, uint fOwnTask )
    HANDLE h;
    int    rc,tmp;
    uint   idx;
    // If we were called from a newly created task thread, allow
    // the entity that created us to complete
    if( fOwnTask )
        TaskSleep(500);
    // Find DHCP on the supplied interface
    for(idx=1; ; idx++)
        // Find a DHCP entry
        rc = CfgGetEntry( 0, CFGTAG_SERVICE, CFGITEM_SERVICE_DHCPCLIENT,
                          idx, &h );
        if( rc != 1 )
            goto RESET_EXIT;
        // Get DHCP entry data
        tmp = sizeof(dhcpc);
        rc = CfgEntryGetData( h, &tmp, (UINT8 *)&dhcpc );
        // If not the right entry, continue
        if( (rc<=0) || dhcpc.cisargs.IfIdx != IfIdx )
            CfgEntryDeRef(h);
            h = 0;
            continue;
        // This is the entry we want!
        // Remove the current DHCP service
        CfgRemoveEntry( 0, h );
        // Specify DHCP Service on specified IF
        dhcpc.cisargs.IfIdx  = IfIdx;
        CfgAddEntry( 0, CFGTAG_SERVICE, CFGITEM_SERVICE_DHCPCLIENT, 0,
        break;
RESET_EXIT:
    // If we are a function, return, otherwise, call TaskExit()
    if( fOwnTask )
        TaskExit();
void CheckDHCPOptions();
// Service Status Reports
// Here's a quick example of using service status updates
static char *TaskName[]  = { "Telnet","HTTP","NAT","DHCPS","DHCPC","DNS" };
static char *ReportStr[] = { "","Running","Updated","Complete","Fault" };
static char *StatusStr[] = { "Disabled","Waiting","IPTerm","Failed","Enabled" };
static void ServiceReport( uint Item, uint Status, uint Report, HANDLE h )
    printf( "Service Status: %-9s: %-9s: %-9s: %03d\n",
            TaskName[Item-1], StatusStr[Status],
            ReportStr[Report/256], Report&0xFF );
    // Example of adding to the DHCP configuration space
    // When using the DHCP client, the client has full control over access
    // to the first 256 entries in the CFGTAG_SYSINFO space.
    // Note that the DHCP client will erase all CFGTAG_SYSINFO tags except
    // CFGITEM_DHCP_HOSTNAME. If the application needs to keep manual
    // entries in the DHCP tag range, then the code to maintain them should
    // be placed here.
    // Here, we want to manually add a DNS server to the configuration, but
    // we can only do it once DHCP has finished its programming.
    if( Item == CFGITEM_SERVICE_DHCPCLIENT &&
        Status == CIS_SRV_STATUS_ENABLED &&
        (Report == (NETTOOLS_STAT_RUNNING|DHCPCODE_IPADD) ||
         Report == (NETTOOLS_STAT_RUNNING|DHCPCODE_IPRENEW)) )
        IPN IPTmp;
        if( IPTmp )
            CfgAddEntry( 0, CFGTAG_SYSINFO, CFGITEM_DHCP_DOMAINNAMESERVER,
#if 0
        // We can now check on what the DHCP server supplied in
        // response to our DHCP option tags.
        CheckDHCPOptions();
#endif
    // Reset DHCP client service on failure
    if( Item==CFGITEM_SERVICE_DHCPCLIENT && (Report&~0xFF)==NETTOOLS_STAT_FAULT )
        int tmp;
        // Get DHCP entry data (for index to pass to DHCP_reset).
        // Create the task to reset DHCP on its designated IF
        // We must use TaskCreate instead of just calling the function as
        // we are in a callback function.
        TaskCreate( DHCP_reset, "DHCPreset", OS_TASKPRINORM, 0x1000,
                    dhcpc.cisargs.IfIdx, 1, 0 );
    char IPString[16];
    IPN  IPAddr;
    int  i, rc;
    // Now scan for DHCPOPT_SERVER_IDENTIFIER via configuration
    printf("\nDHCP Server ID:\n");
    for(i=1;;i++)
        // Try and get a DNS server
        rc = CfgGetImmediate( 0, CFGTAG_SYSINFO, DHCPOPT_SERVER_IDENTIFIER,
                              i, 4, (UINT8 *)&IPAddr );
        if( rc != 4 )
            break;
        // We got something
        // Convert IP to a string:
        NtIPN2Str( IPAddr, IPString );
        printf("DHCP Server %d = '%s'\n", i, IPString);
    if( i==1 )
        printf("None\n\n");
    else
        printf("\n");
    // Now scan for DHCPOPT_ROUTER via the configuration
    printf("Router Information:\n");
    for(i=1;;i++)
        rc = CfgGetImmediate( 0, CFGTAG_SYSINFO, DHCPOPT_ROUTER,
        if( rc != 4 )
            break;
        // We got something
        printf("Router %d = '%s'\n", i, IPString);
    if( i==1 )
        printf("None\n\n");
    else
        printf("\n");
/* Routine to demonstrate sending raw ethernet packets using
 * send() / sendnc() APIs and AF_RAWETH family socket.
    char*       pBuffer = NULL;
    ETHHDR*     ptr_eth_header;
    UINT32      rawether_type = 0x300, rawchannel_num = 0;
    UINT8       src_mac[6], dst_mac[6], bData[20];
    int         i, j, val, bytes, retVal;
    SOCKET      sraw = INVALID_SOCKET;
#ifdef TEST_RAW_NC
    PBM_Handle  hPkt = NULL;
#endif
    /* Allocate the file environment for this task */
    fdOpenSession( TaskSelf() );
    /* wait for the ethernet link to come up. */
TaskSleep(20000);
    printf("Raw Eth Task Started ... \n");
    /* Demonstrating use of SO_PRIORITY to configure
     * custom properties for all packets travelling
     * using this socket.
     * Here, in this example we will use it for
     * configuring a distinct EMAC channel number for each
     * of the raw ethernet sockets.
     * For example, Channel Assignment:
     *      Chan 0 - IP
     *      Chan 3 - Raw
    rawchannel_num = 3;
    /* Create the raw ethernet socket */
    sraw = socket(AF_RAWETH, SOCK_RAWETH, rawether_type);
    if( sraw == INVALID_SOCKET )
        printf("Fail socket, %d\n", fdError());
        fdCloseSession (TaskSelf());
        return;
    /* Configure the transmit device */
    val = 1;
    retVal = setsockopt(sraw, SOL_SOCKET, SO_IFDEVICE, &val, sizeof(val));
if(retVal)
printf("error in setsockopt \n");
    /* Configure the EMAC channel number */
    val = rawchannel_num;
    retVal = setsockopt(sraw, SOL_SOCKET, SO_PRIORITY, &val, sizeof(val));
if(retVal)
    /* Send the RAW eth packets out */
for(j = 0; j < PACKET_COUNT; j++)
#ifndef  TEST_RAW_NC
        if ((pBuffer = mmAlloc (sizeof(char) * PACKET_SIZE)) == NULL)
            printf("OOM ?? \n");
            TaskExit();
#else
     if(getsendncbuff(sraw, PACKET_SIZE, (void **) &pBuffer, &hPkt))
            printf("Error: Raw Eth getsendncbuff failed Error:%d\n", fdError());
    fdCloseSession( TaskSelf() );
            fdClose(sraw);
    TaskExit();
#endif
    /* Configure the Source MAC, Destination MAC, Protocol and Payload */
    for (i = 0; i < 6; i++)
     src_mac[i] = 0x10 + i;
        dst_mac[i] = 0x20 + i + 2;
    for (i = 0; i < 20; i++)
        bData[i] = 0x60 + i;
    ptr_eth_header = (ETHHDR*)pBuffer;
    /* Copy the source MAC address as is. */
    mmCopy (ptr_eth_header->SrcMac, src_mac, 6);
    /* Copy the destination MAC address as is. */
    mmCopy (ptr_eth_header->DstMac, dst_mac, 6);
    /* Configure the type in network order. */
    ptr_eth_header->Type = HNC16(rawether_type);
    /* Copy over the payload to the buffer */
    mmCopy(pBuffer + ETHHDR_SIZE, bData, 20);
#ifndef TEST_RAW_NC
        /* Send the packet using the copy version of send() API. */
        bytes = send(sraw, (char *)pBuffer, PACKET_SIZE, 0);
#else
        /* Use the no-copy version of send, sendnc() to send out the data */
        bytes = sendnc(sraw, (char *)pBuffer, PACKET_SIZE, hPkt, 0);
#endif
#ifndef TEST_RAW_NC
        /* If we allocated the buffer, free it up. If we used up the sendnc()
         * API, the buffer will be freed up by the stack.
    mmFree(pBuffer);
#endif
if( bytes < 0 )
            printf("Error: Raw Eth Send failed Error:%d\n", fdError());
#ifdef TEST_RAW_NC
            sendncfree(hPkt);
#endif
            fdClose(sraw);
    TaskExit();
    printf("Raw Eth Task Ended ... \n");
    fdClose(sraw);
/* Close the session & kill the task */
    TaskExit();
#endif
/* Routine to demonstrate packet receive using recvnc() API
 * and AF_RAWETH family sockets.
SOCKET      sraw;
INT32       val,retVal, count = 0, bytes;
    char*     pBuf;
    HANDLE    hBuffer;
UINT32      rawchannel_num;
printf ("Raw Eth Rx Task has been started\n");
     *      Chan 0 - IP
     *      Chan 3 - Raw
    rawchannel_num = 3;
    /* Create the main UDP listen socket */
    sraw = socket(AF_RAWETH, SOCK_RAWETH, 0x300);
        return;
    val = 1;
if(retVal)
    /* Configure the EMAC channel number as the priority tag for packets */
if(retVal)
    /* Configure the Receive buffer size */
    val = 1000;
    retVal = setsockopt(sraw, SOL_SOCKET, SO_RCVBUF, &val, sizeof(val));
if(retVal)
    while (count < PACKET_COUNT)
bytes = (int)recvnc( sraw, (void **)&pBuf, 0, &hBuffer );
        if (bytes < 0)
/* Receive failed: Close the session & kill the task */
printf("Receive failed after packets Error:%d\n",fdError());
    TaskExit();
else
     ptr_eth_header = (ETHHDR*)pBuf;
    printf("Received RAW ETH packet, len: %d \n", PBM_getValidLen((PBM_Handle)hBuffer));
printf("Dst MAC Address = %02x-%02x-%02x-%02x-%02x-%02x Src MAC Address = %02x-%02x-%02x-%02x-%02x-%02x Eth Type = %d Data = %s \n",
            ptr_eth_header->DstMac[0],ptr_eth_header->DstMac[1],ptr_eth_header->DstMac[2],
            ptr_eth_header->DstMac[3],ptr_eth_header->DstMac[4],ptr_eth_header->DstMac[5],
            ptr_eth_header->SrcMac[0],ptr_eth_header->SrcMac[1],ptr_eth_header->SrcMac[2],
            ptr_eth_header->SrcMac[3],ptr_eth_header->SrcMac[4],ptr_eth_header->SrcMac[5],
            ntohs(ptr_eth_header->Type), (pBuf + ETHHDR_SIZE));
count++;
/* Clean out the buffer */
recvncfree( hBuffer );
    TaskExit();
    return;
#endif
