用的命令是:
./dtc -I dts -O dtb am57xx-beagle-x15.dts -o x15.dtb
Error: am57xx-beagle-x15.dts:9.1-2 syntax error
FATAL ERROR: Unable to parse input tree
dts源文件是:
* Copyright (C) 2014-2016 Texas Instruments Incorporated - http://www.ti.com/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
#include"am57xx-beagle-x15-common.dtsi"
/* NOTE: This describes the "original" pre-production A2 revision */
model = "TI AM5728 BeagleBoard-X15";
&tpd12s015 {
gpios = <&gpio7 10 GPIO_ACTIVE_HIGH>, /* gpio7_10, CT CP HPD */
<&gpio6 28 GPIO_ACTIVE_HIGH>, /* gpio6_28, LS OE */
<&gpio7 12 GPIO_ACTIVE_HIGH>; /* gpio7_12/sp1_cs2, HPD */
&mmc1 {
pinctrl-names = "default", "hs";
pinctrl-0 = <&mmc1_pins_default>;
pinctrl-1 = <&mmc1_pins_hs>;
vmmc-supply = <&ldo1_reg>;
no-1-8-v;
no-1-8-v;
&mmc2 {
pinctrl-names = "default", "hs", "ddr_1_8v";
pinctrl-0 = <&mmc2_pins_default>;
pinctrl-1 = <&mmc2_pins_hs>;
pinctrl-2 = <&mmc2_pins_ddr_3_3v_rev11 &mmc2_iodelay_ddr_3_3v_rev11_conf>;
/* errata i880 "Ethernet RGMII2 Limited to 10/100 Mbps" */
&phy1 {
max-speed = <100>;
&phy1 {
max-speed = <100>;
