ubifs文件系统只能挂载一次
Other Parts Discussed in Thread: TPS65910
制作了一个ubifs的文件系统,第一次启动的时候,可以正常启动,能进入到命令。
具体启动信息如下:
Uncompressing Linux... done, booting the kernel.
[    0.000000] Linux version 3.2.0 (yhh@virtual-machine) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #84 Wed May 14 15:31:59 CST 2014
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: am335xevm
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES2.1 (sgx neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 60960
[    0.000000] Kernel command line: console=ttyO0,115200n8 rootfstype=ubifs ubi.mtd=3 init=/linuxrc root=ubi0:rootfs
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 240MB = 240MB total
[    0.000000] Memory: 236732k/236732k available, 9028k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xcf800000 - 0xff000000   ( 760 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xcf000000   ( 240 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc05e6000   (6008 kB)
[    0.000000]       .init : 0xc05e6000 - 0xc0624000   ( 248 kB)
[    0.000000]       .data : 0xc0624000 - 0xc068df98   ( 424 kB)
[    0.000000]        .bss : 0xc068dfbc - 0xc06b4fa4   ( 156 kB)
[    0.000000] NR_IRQS:396
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[    0.000000] omap_dm_timer_switch_src: Switching to HW default clocksource(sys_clkin_ck) for timer1, this may impact timekeeping in low powe
[    0.000000] OMAP clocksource: GPTIMER1 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000242] Calibrating delay loop... 498.89 BogoMIPS (lpj=2494464)
[    0.056312] pid_max: default: 32768 minimum: 301
[    0.056473] Security Framework initialized
[    0.056602] Mount-cache hash table entries: 512
[    0.057075] CPU: Testing write buffer coherency: ok
[    0.078931] omap_hwmod: pruss: failed to hardreset
[    0.080323] print_constraints: dummy:
[    0.080800] NET: Registered protocol family 16
[    0.083624] OMAP GPIO hardware version 0.1
[    0.087267] omap_mux_init: Add partition: #1: core, flags: 0
[    0.089686]  omap_i2c.1: alias fck already exists
[    0.090825]  omap2_mcspi.1: alias fck already exists
[    0.091144]  omap2_mcspi.2: alias fck already exists
[    0.092415]  edma.0: alias fck already exists
[    0.092447]  edma.0: alias fck already exists
[    0.092474]  edma.0: alias fck already exists
[    0.130214] bio: create slab <bio-0> at 0
[    0.133183] SCSI subsystem initialized
[    0.135360] usbcore: registered new interface driver usbfs
[    0.135773] usbcore: registered new interface driver hub
[    0.136046] usbcore: registered new device driver usb
[    0.136474] registerd cppi-dma Intr @ IRQ 17
[    0.136495] Cppi41 Init Done Qmgr-base(cf87a000) dma-base(cf878000)
[    0.136511] Cppi41 Init Done
[    0.136546] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[    0.136942] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[    0.156383] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[    0.158712] tps65910 1-002d: JTAGREVNUM 0x0
[    0.161305] print_constraints: VRTC:
[    0.162878] print_constraints: VIO: at 1500 mV
[    0.165335] print_constraints: VDD1: 600 <--> 1500 mV at 1100 mV normal
[    0.167782] print_constraints: VDD2: 600 <--> 1500 mV at 1100 mV normal
[    0.168899] print_constraints: VDD3: 5000 mV
[    0.170427] print_constraints: VDIG1: at 1800 mV
[    0.171986] print_constraints: VDIG2: at 1800 mV
[    0.173523] print_constraints: VPLL: at 1800 mV
[    0.175075] print_constraints: VDAC: at 1800 mV
[    0.176612] print_constraints: VAUX1: at 1800 mV
[    0.178195] print_constraints: VAUX2: at 3300 mV
[    0.179739] print_constraints: VAUX33: at 3300 mV
[    0.181289] print_constraints: VMMC: at 3300 mV
[    0.181987] tps65910 1-002d: No interrupt support, no core IRQ
[    0.183858] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.185346] Switching to clocksource gp timer
[    0.207259] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.207476] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[    0.207892] MUSB0 controller's USBSS revision = 4ea20800
[    0.207938] musb0: Enabled SW babble control
[    0.209149] musb-hdrc musb-hdrc.0: USB OTG mode controller at cf83c000 using DMA, IRQ 18
[    0.209356] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[    0.209761] MUSB1 controller's USBSS revision = 4ea20800
[    0.209801] musb1: Enabled SW babble control
[    0.210384] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    0.210498] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    0.210665] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.210688] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.210708] usb usb1: Product: MUSB HDRC host driver
[    0.210725] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[    0.210741] usb usb1: SerialNumber: musb-hdrc.1
[    0.211782] hub 1-0:1.0: USB hub found
[    0.211822] hub 1-0:1.0: 1 port detected
[    0.212552] musb-hdrc musb-hdrc.1: USB Host mode controller at cf83e800 using DMA, IRQ 19
[    0.213090] NET: Registered protocol family 2
[    0.213323] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.213704] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.213929] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.214068] TCP: Hash tables configured (established 8192 bind 8192)
[    0.214086] TCP reno registered
[    0.214104] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.214146] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.214402] NET: Registered protocol family 1
[    0.214716] RPC: Registered named UNIX socket transport module.
[    0.214736] RPC: Registered udp transport module.
[    0.214750] RPC: Registered tcp transport module.
[    0.214764] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.215080] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.227800] VFS: Disk quotas dquot_6.5.2
[    0.227900] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.228521] msgmni has been set to 462
[    0.232838] alg: No test for stdrng (krng)
[    0.233696] io scheduler noop registered
[    0.233716] io scheduler deadline registered
[    0.233808] io scheduler cfq registered (default)
[    0.235275] Could not set LED4 to fully on
[    0.237502] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    0.895948] console [ttyO0] enabled
[    0.900362] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    0.908371] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    0.916338] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    0.924242] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    0.932199] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    0.940784] omap4_rng omap4_rng: OMAP4 Random Number Generator ver. 2.00
[    0.960846] brd: module loaded
[    0.970795] loop: module loaded
[    0.974313] i2c-core: driver [tsl2550] using legacy suspend method
[    0.980821] i2c-core: driver [tsl2550] using legacy resume method
[    0.987288] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[    1.001217] Detected a daughter card on AM335x EVM..
[    1.006249] Unknown CPLD version found
[    1.010397] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[    1.017689] The board is general purpose EVM in profile 0
[    1.024607]  da8xx_lcdc.0: alias fck already exists
[    1.030279] da8xx_lcdc da8xx_lcdc.0: GLCD: Found TFC_S9700RTWV35TR_01B panel
[    1.059709] Console: switching to colour frame buffer device 100x30
[    1.079622] omap-gpmc omap-gpmc: GPMC revision 6.0
[    1.084642] Registering NAND on CS0
[    1.089265]  omap_i2c.2: alias fck already exists
[    1.105488] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
[    1.112224] tsl2550 2-0039: standard operating mode
[    1.117535] tsl2550: probe of 2-0039 failed with error -121
[    1.124208]  davinci-mcasp.1: alias fck already exists
[    1.130245]  omap_hsmmc.0: alias fck already exists
[    1.135617] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[    1.142971]  omap_hsmmc.2: alias fck already exists
[    1.148639] Configure Bluetooth Enable pin...
[    1.157104] registered am33xx_sr device
[    1.161432] _regulator_get: 2-0018 supply Vdd not found, using dummy regulator
[    1.169107] _regulator_get: 2-0018 supply Vdd_IO not found, using dummy regulator
[    1.197264] lis3lv02d: unknown sensor type 0x87
[    1.202102] lis3lv02d_i2c: probe of 2-0018 failed with error -22
[    1.211751] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.219257] omap2-nand driver initializing
[    1.223623] ______________nand test ....lxd.........
[    1.229196] NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit)
[    1.238327] Creating 4 MTD partitions on "omap2-nand.0":
[    1.243896] 0x000000000000-0x000000200000 : "Bootloader"
[    1.252295] 0x000000200000-0x000000a00000 : "Logo"
[    1.262376] 0x000000a00000-0x000001200000 : "Kernel"
[    1.272855] 0x000001200000-0x000040000000 : "Rootfs"
[    1.708662] UBI: attaching mtd3 to ubi0
[    1.712686] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[    1.719291] UBI: logical eraseblock size:    126976 bytes
[    1.724928] UBI: smallest flash I/O unit:    2048
[    1.729856] UBI: VID header offset:          2048 (aligned 2048)
[    1.736144] UBI: data offset:                4096
[    2.117701] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[    2.124712] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.132202] usb 1-1: Product: USB 2.0 Hub
[    2.165686] hub 1-1:1.0: USB hub found
[    2.169699] hub 1-1:1.0: 4 ports detected
[   16.748839] UBI: max. sequence number:       2
[   16.787038] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 77, need 80
[   16.803221] UBI: attached mtd3 to ubi0
[   16.807247] UBI: MTD device name:            "Rootfs"
[   16.812538] UBI: MTD device size:            1006 MiB
[   16.817843] UBI: number of good PEBs:        8048
[   16.822773] UBI: number of bad PEBs:         0
[   16.827438] UBI: number of corrupted PEBs:   0
[   16.832090] UBI: max. allowed volumes:       128
[   16.836939] UBI: wear-leveling threshold:    4096
[   16.841863] UBI: number of internal volumes: 1
[   16.846542] UBI: number of user volumes:     1
[   16.851198] UBI: available PEBs:             0
[   16.855865] UBI: total number of reserved PEBs: 8048
[   16.861063] UBI: number of PEBs reserved for bad PEB handling: 77
[   16.867463] UBI: max/mean erase counter: 2/0
[   16.871932] UBI: image sequence number:  0
[   16.876428] UBI: background thread "ubi_bgt0d" started, PID 586
[   16.896298] CAN device driver interface
[   16.900321] CAN bus driver for Bosch D_CAN controller 1.0
[   16.966268] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[   16.972762] davinci_mdio davinci_mdio.0: detected phy mask ffffffde
[   17.005980] davinci_mdio.0: probed
[   17.009553] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
[   17.016970] davinci_mdio davinci_mdio.0: phy[5]: device 0:05, driver unknown
[   17.046496] usbcore: registered new interface driver zd1201
[   17.052638] usbcore: registered new interface driver cdc_ether
[   17.065518] usbcore: registered new interface driver cdc_eem
[   17.075511] usbcore: registered new interface driver dm9601
[   17.081413] cdc_ncm: 04-Aug-2011
[   17.095511] usbcore: registered new interface driver cdc_ncm
[   17.101441] Initializing USB Mass Storage driver...
[   17.115550] usbcore: registered new interface driver usb-storage
[   17.121827] USB Mass Storage support registered.
[   17.146326] mousedev: PS/2 mouse device common for all mice
[   17.165861] input: matrix-keypad as /devices/platform/matrix-keypad/input/input0
[   17.186984] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input1
[   17.206302] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as rtc0
[   17.213624] i2c /dev entries driver
[   17.226210] Linux video capture interface: v2.00
[   17.236294] usbcore: registered new interface driver uvcvideo
[   17.242318] USB Video Class driver (1.1.1)
[   17.255769] lm75: probe of 2-0048 failed with error -121
[   17.305566] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[   17.335885] cpuidle: using governor ladder
[   17.356111] cpuidle: using governor menu
[   17.445858] omap4_aes_mod_init: loading AM33X AES driver
[   17.451577] omap4-aes omap4-aes: AM33X AES hw accel rev: 3.02
[   17.465857] omap4_aes_probe: probe() done
[   17.470370] omap4_sham_mod_init: loading AM33X SHA/MD5 driver
[   17.476603] omap4-sham omap4-sham: AM33X SHA/MD5 hw accel rev: 4.03
[   17.606143] omap4_sham_probe: probe() done
[   17.646252] usbcore: registered new interface driver usbhid
[   17.652127] usbhid: USB HID core driver
[   17.665942] tiadc tiadc: attached adc driver
[   17.686486] usbcore: registered new interface driver snd-usb-audio
[   17.707144] _regulator_get: 2-001b supply IOVDD not found, using dummy regulator
[   17.715002] _regulator_get: 2-001b supply DVDD not found, using dummy regulator
[   17.722797] _regulator_get: 2-001b supply AVDD not found, using dummy regulator
[   17.730546] _regulator_get: 2-001b supply DRVDD not found, using dummy regulator
[   17.776239] asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
[   17.797037] ALSA device list:
[   17.800167]   #0: AM335X EVM
[   17.803191] oprofile: hardware counters not available
[   17.808539] oprofile: using timer interrupt.
[   17.813063] nf_conntrack version 0.5.0 (3698 buckets, 14792 max)
[   17.819942] ip_tables: (C) 2000-2006 Netfilter Core Team
[   17.825728] TCP cubic registered
[   17.829132] NET: Registered protocol family 17
[   17.833824] can: controller area network core (rev 20090105 abi 8)
[   17.840461] NET: Registered protocol family 29
[   17.845143] can: raw protocol (rev 20090105)
[   17.849662] can: broadcast manager protocol (rev 20090105 t)
[   17.855682] Registering the dns_resolver key type
[   17.860715] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[   17.868822] ThumbEE CPU extension supported.
[   17.873390] mux: Failed to setup hwmod io irq -22
[   17.879173] Power Management for AM33XX family
[   17.884089] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[   17.890859] Copied the M3 firmware to UMEM
[   17.895255] Cortex M3 Firmware Version = 0x181
[   17.928151] create_regulator: VDD1: Failed to create debugfs directory
[   17.948135] smartreflex smartreflex: am33xx_sr_probe: Driver initialized
[   17.990907] clock: disabling unused clocks to save power
[   18.296686] Detected MACID=c4:ed:ba:8e:57:bd
[   18.302438] cpsw: Detected MACID = c4:ed:ba:8e:57:bf
[   18.309647] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[   18.317498] omap_rtc am33xx-rtc: setting system clock to 2002-07-09 20:10:04 UTC (1026245404)
[   18.571624] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[   18.578009] UBIFS: file system size:   252555264 bytes (246636 KiB, 240 MiB, 1989 LEBs)
[   18.586468] UBIFS: journal size:       9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[   18.594170] UBIFS: media format:       w4/r0 (latest is w4/r0)
[   18.600325] UBIFS: default compressor: lzo
[   18.604642] UBIFS: reserved for root:  0 bytes (0 KiB)
[   18.614972] VFS: Mounted root (ubifs filesystem) on device 0:13.
[   18.621760] Freeing init memory: 248K
hwclock: can't o/ #
于是重启的时候,就出现了错误
具体启动信息如下:
[    0.000246] Calibrating delay loop... 498.89 BogoMIPS (lpj=2494464)
[    0.056308] pid_max: default: 32768 minimum: 301
[    0.056471] Security Framework initialized
[    0.056600] Mount-cache hash table entries: 512
[    0.057071] CPU: Testing write buffer coherency: ok
[    0.078926] omap_hwmod: pruss: failed to hardreset
[    0.080315] print_constraints: dummy:
[    0.080784] NET: Registered protocol family 16
[    0.083573] OMAP GPIO hardware version 0.1
[    0.087221] omap_mux_init: Add partition: #1: core, flags: 0
[    0.089651]  omap_i2c.1: alias fck already exists
[    0.090783]  omap2_mcspi.1: alias fck already exists
[    0.091100]  omap2_mcspi.2: alias fck already exists
[    0.092364]  edma.0: alias fck already exists
[    0.092395]  edma.0: alias fck already exists
[    0.092422]  edma.0: alias fck already exists
[    0.130130] bio: create slab <bio-0> at 0
[    0.133088] SCSI subsystem initialized
[    0.135252] usbcore: registered new interface driver usbfs
[    0.135673] usbcore: registered new interface driver hub
[    0.135941] usbcore: registered new device driver usb
[    0.136366] registerd cppi-dma Intr @ IRQ 17
[    0.136387] Cppi41 Init Done Qmgr-base(cf87a000) dma-base(cf878000)
[    0.136402] Cppi41 Init Done
[    0.136437] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[    0.136835] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[    0.156381] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[    0.158740] tps65910 1-002d: JTAGREVNUM 0x0
[    0.161337] print_constraints: VRTC:
[    0.162909] print_constraints: VIO: at 1500 mV
[    0.165367] print_constraints: VDD1: 600 <--> 1500 mV at 1100 mV normal
[    0.167818] print_constraints: VDD2: 600 <--> 1500 mV at 1100 mV normal
[    0.168936] print_constraints: VDD3: 5000 mV
[    0.170465] print_constraints: VDIG1: at 1800 mV
[    0.172018] print_constraints: VDIG2: at 1800 mV
[    0.173550] print_constraints: VPLL: at 1800 mV
[    0.175100] print_constraints: VDAC: at 1800 mV
[    0.176640] print_constraints: VAUX1: at 1800 mV
[    0.178212] print_constraints: VAUX2: at 3300 mV
[    0.179758] print_constraints: VAUX33: at 3300 mV
[    0.181314] print_constraints: VMMC: at 3300 mV
[    0.182008] tps65910 1-002d: No interrupt support, no core IRQ
[    0.183886] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.185403] Switching to clocksource gp timer
[    0.207345] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.207563] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[    0.207978] MUSB0 controller's USBSS revision = 4ea20800
[    0.208024] musb0: Enabled SW babble control
[    0.209240] musb-hdrc musb-hdrc.0: USB OTG mode controller at cf83c000 using DMA, IRQ 18
[    0.209439] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[    0.209846] MUSB1 controller's USBSS revision = 4ea20800
[    0.209885] musb1: Enabled SW babble control
[    0.210467] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    0.210579] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[    0.210743] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.210766] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.210787] usb usb1: Product: MUSB HDRC host driver
[    0.210803] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[    0.210819] usb usb1: SerialNumber: musb-hdrc.1
[    0.211871] hub 1-0:1.0: USB hub found
[    0.211909] hub 1-0:1.0: 1 port detected
[    0.212633] musb-hdrc musb-hdrc.1: USB Host mode controller at cf83e800 using DMA, IRQ 19
[    0.213162] NET: Registered protocol family 2
[    0.213395] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.213773] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.214000] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.214138] TCP: Hash tables configured (established 8192 bind 8192)
[    0.214157] TCP reno registered
[    0.214175] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.214218] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.214468] NET: Registered protocol family 1
[    0.214790] RPC: Registered named UNIX socket transport module.
[    0.214808] RPC: Registered udp transport module.
[    0.214822] RPC: Registered tcp transport module.
[    0.214835] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.215150] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.227892] VFS: Disk quotas dquot_6.5.2
[    0.227990] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.228609] msgmni has been set to 462
[    0.232928] alg: No test for stdrng (krng)
[    0.233779] io scheduler noop registered
[    0.233799] io scheduler deadline registered
[    0.233888] io scheduler cfq registered (default)
[    0.235339] Could not set LED4 to fully on
[    0.237580] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    0.896032] console [ttyO0] enabled
[    0.900446] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    0.908458] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    0.916412] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    0.924324] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    0.932286] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    0.940899] omap4_rng omap4_rng: OMAP4 Random Number Generator ver. 2.00
[    0.960983] brd: module loaded
[    0.970897] loop: module loaded
[    0.974420] i2c-core: driver [tsl2550] using legacy suspend method
[    0.980930] i2c-core: driver [tsl2550] using legacy resume method
[    0.987392] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[    1.001315] Detected a daughter card on AM335x EVM..
[    1.006347] Unknown CPLD version found
[    1.010498] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[    1.017793] The board is general purpose EVM in profile 0
[    1.024728]  da8xx_lcdc.0: alias fck already exists
[    1.030399] da8xx_lcdc da8xx_lcdc.0: GLCD: Found TFC_S9700RTWV35TR_01B panel
[    1.059828] Console: switching to colour frame buffer device 100x30
[    1.079727] omap-gpmc omap-gpmc: GPMC revision 6.0
[    1.084750] Registering NAND on CS0
[    1.089373]  omap_i2c.2: alias fck already exists
[    1.105543] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
[    1.112295] tsl2550 2-0039: standard operating mode
[    1.117603] tsl2550: probe of 2-0039 failed with error -121
[    1.124262]  davinci-mcasp.1: alias fck already exists
[    1.130295]  omap_hsmmc.0: alias fck already exists
[    1.135662] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[    1.143016]  omap_hsmmc.2: alias fck already exists
[    1.148686] Configure Bluetooth Enable pin...
[    1.157152] registered am33xx_sr device
[    1.161471] _regulator_get: 2-0018 supply Vdd not found, using dummy regulator
[    1.169148] _regulator_get: 2-0018 supply Vdd_IO not found, using dummy regulator
[    1.197300] lis3lv02d: unknown sensor type 0x87
[    1.202134] lis3lv02d_i2c: probe of 2-0018 failed with error -22
[    1.211759] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.219268] omap2-nand driver initializing
[    1.223633] ______________nand test ....lxd.........
[    1.229203] NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit)
[    1.238329] Creating 4 MTD partitions on "omap2-nand.0":
[    1.243900] 0x000000000000-0x000000200000 : "Bootloader"
[    1.252313] 0x000000200000-0x000000a00000 : "Logo"
[    1.262414] 0x000000a00000-0x000001200000 : "Kernel"
[    1.272928] 0x000001200000-0x000040000000 : "Rootfs"
[    1.708730] UBI: attaching mtd3 to ubi0
[    1.712755] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[    1.719358] UBI: logical eraseblock size:    126976 bytes
[    1.724995] UBI: smallest flash I/O unit:    2048
[    1.729923] UBI: VID header offset:          2048 (aligned 2048)
[    1.736214] UBI: data offset:                4096
[    2.119114] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[    2.126151] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.133615] usb 1-1: Product: USB 2.0 Hub
[    2.176094] hub 1-1:1.0: USB hub found
[    2.180108] hub 1-1:1.0: 4 ports detected
[   17.414399] UBI: max. sequence number:       3
[   17.453124] UBI warning: print_rsvd_warning: cannot reserve enough PEBs for bad PEB handling, reserved 77, need 80
[   17.469350] UBI: attached mtd3 to ubi0
[   17.473283] UBI: MTD device name:            "Rootfs"
[   17.478635] UBI: MTD device size:            1006 MiB
[   17.483909] UBI: number of good PEBs:        8048
[   17.488838] UBI: number of bad PEBs:         0
[   17.493481] UBI: number of corrupted PEBs:   0
[   17.498134] UBI: max. allowed volumes:       128
[   17.502953] UBI: wear-leveling threshold:    4096
[   17.507879] UBI: number of internal volumes: 1
[   17.512517] UBI: number of user volumes:     1
[   17.517168] UBI: available PEBs:             0
[   17.521813] UBI: total number of reserved PEBs: 8048
[   17.527008] UBI: number of PEBs reserved for bad PEB handling: 77
[   17.533372] UBI: max/mean erase counter: 2/0
[   17.537843] UBI: image sequence number:  0
[   17.542264] UBI: background thread "ubi_bgt0d" started, PID 586
[   17.549359] CAN device driver interface
[   17.553375] CAN bus driver for Bosch D_CAN controller 1.0
[   17.605485] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[   17.611953] davinci_mdio davinci_mdio.0: detected phy mask ffffffde
[   17.619984] davinci_mdio.0: probed
[   17.623546] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
[   17.630956] davinci_mdio davinci_mdio.0: phy[5]: device 0:05, driver unknown
[   17.638809] usbcore: registered new interface driver zd1201
[   17.644899] usbcore: registered new interface driver cdc_ether
[   17.651318] usbcore: registered new interface driver cdc_eem
[   17.657486] usbcore: registered new interface driver dm9601
[   17.663372] cdc_ncm: 04-Aug-2011
[   17.667003] usbcore: registered new interface driver cdc_ncm
[   17.672926] Initializing USB Mass Storage driver...
[   17.678370] usbcore: registered new interface driver usb-storage
[   17.684647] USB Mass Storage support registered.
[   17.690143] mousedev: PS/2 mouse device common for all mice
[   17.696938] input: matrix-keypad as /devices/platform/matrix-keypad/input/input0
[   17.706537] input: ti-tsc as /devices/platform/omap/ti_tscadc/tsc/input/input1
[   17.715566] omap_rtc am33xx-rtc: rtc core: registered am33xx-rtc as rtc0
[   17.722895] i2c /dev entries driver
[   17.727462] Linux video capture interface: v2.00
[   17.732727] usbcore: registered new interface driver uvcvideo
[   17.738768] USB Video Class driver (1.1.1)
[   17.743360] lm75: probe of 2-0048 failed with error -121
[   17.752238] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[   17.763649] cpuidle: using governor ladder
[   17.768602] cpuidle: using governor menu
[   17.846767] omap4_aes_mod_init: loading AM33X AES driver
[   17.852482] omap4-aes omap4-aes: AM33X AES hw accel rev: 3.02
[   17.859164] omap4_aes_probe: probe() done
[   17.863665] omap4_sham_mod_init: loading AM33X SHA/MD5 driver
[   17.869902] omap4-sham omap4-sham: AM33X SHA/MD5 hw accel rev: 4.03
[   17.882699] omap4_sham_probe: probe() done
[   17.889864] usbcore: registered new interface driver usbhid
[   17.895782] usbhid: USB HID core driver
[   17.900578] tiadc tiadc: attached adc driver
[   17.909113] usbcore: registered new interface driver snd-usb-audio
[   17.918164] _regulator_get: 2-001b supply IOVDD not found, using dummy regulator
[   17.926121] _regulator_get: 2-001b supply DVDD not found, using dummy regulator
[   17.933871] _regulator_get: 2-001b supply AVDD not found, using dummy regulator
[   17.941631] _regulator_get: 2-001b supply DRVDD not found, using dummy regulator
[   17.952755] asoc: tlv320aic3x-hifi <-> davinci-mcasp.1 mapping ok
[   17.960788] ALSA device list:
[   17.963932]   #0: AM335X EVM
[   17.967002] oprofile: hardware counters not available
[   17.972321] oprofile: using timer interrupt.
[   17.976856] nf_conntrack version 0.5.0 (3698 buckets, 14792 max)
[   17.983745] ip_tables: (C) 2000-2006 Netfilter Core Team
[   17.989543] TCP cubic registered
[   17.992954] NET: Registered protocol family 17
[   17.997670] can: controller area network core (rev 20090105 abi 8)
[   18.004292] NET: Registered protocol family 29
[   18.008998] can: raw protocol (rev 20090105)
[   18.013496] can: broadcast manager protocol (rev 20090105 t)
[   18.019510] Registering the dns_resolver key type
[   18.024546] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[   18.032682] ThumbEE CPU extension supported.
[   18.037262] mux: Failed to setup hwmod io irq -22
[   18.043037] Power Management for AM33XX family
[   18.047988] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[   18.054722] Copied the M3 firmware to UMEM
[   18.059143] Cortex M3 Firmware Version = 0x181
[   18.066654] create_regulator: VDD1: Failed to create debugfs directory
[   18.075175] smartreflex smartreflex: am33xx_sr_probe: Driver initialized
[   18.091238] clock: disabling unused clocks to save power
[   18.111803] Detected MACID=c4:ed:ba:8e:57:bd
[   18.117619] cpsw: Detected MACID = c4:ed:ba:8e:57:bf
[   18.124724] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[   18.132606] omap_rtc am33xx-rtc: setting system clock to 2002-07-01 20:10:00 UTC (1025554200)
[   18.379397] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read 126976 bytes
[   18.626328] UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 4:4096, read 126976 bytes
[   18.639309] UBIFS: recovery needed
[   18.649124] UBI error: ubi_io_read: error -74 (ECC error) while reading 11 bytes from PEB 10:6144, read 11 bytes
[   18.659884] UBIFS error (pid 1): ubifs_leb_read: reading 11 bytes from LEB 8:2048 failed, error -74
[   18.669429] Backtrace:
[   18.672045] [<c0018e54>] (dump_backtrace+0x0/0x110) from [<c045fc58>] (dump_stack+0x18/0x1c)
[   18.680952]  r7:00000008 r6:00000800 r5:0000000b r4:ffffffb6
[   18.686962] [<c045fc40>] (dump_stack+0x0/0x1c) from [<c01863f0>] (ubifs_leb_read+0x88/0x90)
[   18.695795] [<c0186368>] (ubifs_leb_read+0x0/0x90) from [<c019cbac>] (ubifs_lpt_init+0x148/0x72c)
[   18.705142]  r7:ce2c8000 r6:00000003 r5:c0654b00 r4:0000000b
[   18.711153] [<c019ca64>] (ubifs_lpt_init+0x0/0x72c) from [<c0181098>] (ubifs_fill_super+0xbc8/0x1870)
[   18.720889] [<c01804d0>] (ubifs_fill_super+0x0/0x1870) from [<c018217c>] (ubifs_mount+0x43c/0x540)
[   18.730363] [<c0181d40>] (ubifs_mount+0x0/0x540) from [<c00b2ce0>] (mount_fs+0x4c/0x188)
[   18.738922] [<c00b2c94>] (mount_fs+0x0/0x188) from [<c00cbaf8>] (vfs_kern_mount+0x58/0x94)
[   18.747652] [<c00cbaa0>] (vfs_kern_mount+0x0/0x94) from [<c00cbb90>] (do_kern_mount+0x3c/0xd4)
[   18.756739]  r9:ce01dec0 r8:c0657ccc r7:ce2b4240 r6:00000000 r5:ce2c7f80
[   18.763665] r4:00008000
[   18.766455] [<c00cbb54>] (do_kern_mount+0x0/0xd4) from [<c00cc270>] (do_mount+0x648/0x73c)
[   18.775164]  r9:ce01dec0 r8:00000020 r7:ce2b4240 r6:ce2c7f80 r5:00008000
[   18.782074] r4:00000000
[   18.784852] [<c00cbc28>] (do_mount+0x0/0x73c) from [<c00cc404>] (sys_mount+0xa0/0xd0)
[   18.793133] [<c00cc364>] (sys_mount+0x0/0xd0) from [<c05e6b44>] (do_mount_root+0x2c/0xc8)
[   18.801762]  r7:c0617ae4 r6:ce2c4000 r5:c0617af0 r4:ce2c4000
[   18.807769] [<c05e6b18>] (do_mount_root+0x0/0xc8) from [<c05e6d6c>] (mount_block_root+0x98/0x240)
[   18.817131]  r8:c0626290 r7:c0617ae4 r6:ce2c4000 r5:c0617af0 r4:ce2c4000
[   18.824226] [<c05e6cd4>] (mount_block_root+0x0/0x240) from [<c05e7080>] (prepare_namespace+0x90/0x1e8)
[   18.834056] [<c05e6ff0>] (prepare_namespace+0x0/0x1e8) from [<c05e6324>] (kernel_init+0x120/0x13c)
[   18.843506]  r6:c06237d8 r5:c0623dbc r4:c0623dbc
[   18.848423] [<c05e6204>] (kernel_init+0x0/0x13c) from [<c00443c8>] (do_exit+0x0/0x6d0)
[   18.856776]  r7:00000013 r6:c00443c8 r5:c05e6204 r4:00000000
[   18.863604] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0)
[   18.871076] Please append a correct "root=" boot option; here are the available partitions:
[   18.879940] 1f00            2048 mtdblock0  (driver?)
[   18.885272] 1f01            8192 mtdblock1  (driver?)
[   18.890618] 1f02            8192 mtdblock2  (driver?)
[   18.895964] 1f03         1030144 mtdblock3  (driver?)
[   18.901293] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[   18.910012] Backtrace:
[   18.912609] [<c0018e54>] (dump_backtrace+0x0/0x110) from [<c045fc58>] (dump_stack+0x18/0x1c)
[   18.921516]  r7:c0617ae4 r6:ce2c4000 r5:c0617ae4 r4:c0690c88
[   18.927519] [<c045fc40>] (dump_stack+0x0/0x1c) from [<c045fcd0>] (panic+0x74/0x1b8)
[   18.935612] [<c045fc5c>] (panic+0x0/0x1b8) from [<c05e6e68>] (mount_block_root+0x194/0x240)
[   18.944414]  r3:00000000 r2:ce07f934 r1:ce01df60 r0:c053d010
[   18.950417] [<c05e6cd4>] (mount_block_root+0x0/0x240) from [<c05e7080>] (prepare_namespace+0x90/0x1e8)
[   18.960248] [<c05e6ff0>] (prepare_namespace+0x0/0x1e8) from [<c05e6324>] (kernel_init+0x120/0x13c)
[   18.969702]  r6:c06237d8 r5:c0623dbc r4:c0623dbc
[   18.974594] [<c05e6204>] (kernel_init+0x0/0x13c) from [<c00443c8>] (do_exit+0x0/0x6d0)
[   18.982949]  r7:00000013 r6:c00443c8 r5:c05e6
貌似挂载的系统在NAND FLASH里的数据改变了。内核识别不了是ubifs系统,挂载不上去了。
希望有人可以解答一下。
  • 有参考过下面这篇文档吗:
    http://www.deyisupport.com/question_answer/dsp_arm/sitara_arm/f/25/t/59921.aspx
    我没有发现第二次挂在不上的现象
  • 你好。
    文档参考过了。
    根据文档去制作了ubifs文件系统,烧写进去后。是可以挂载文件系统的。
     不过,文件系统真的只能挂载一次。
    怀疑可能是在文件系统挂载后,在内核有进行nand_write操作,导致修改了文件系统的内容,导致下次启动的时候,无法再挂载文件系统了。
     所以,可能是这样的吧
    在内核里,添加了一些测试打印信息时,发现,当内核启动到这里的时候。
    17.488066] UBI: number of bad PEBs: 0
    [ 17.492709] UBI: number of corrupted PEBs: 0
    [ 17.497361] UBI: max. allowed volumes: 128
    [ 17.502182] UBI: wear-leveling threshold: 4096
    [ 17.507110] UBI: number of internal volumes: 1
    [ 17.511749] UBI: number of user volumes: 1
    [ 17.516401] UBI: available PEBs: 0
    [ 17.521043] UBI: total number of reserved PEBs: 8048
    [ 17.526239] UBI: number of PEBs reserved for bad PEB handling: 77
    [ 17.532603] UBI: max/mean erase counter: 2/0
    [ 17.537075] UBI: image sequence number: 0
    [ 17.541497] UBI: background thread "ubi_bgt0d" started, PID 586
    在这之后就有时候出现了调用nand_write_page_hwecc这个函数。
    而且是多次调用。启动到SHELL后,一定时间内也会调用这个函数。
    当调用这个函数的时候,有一个奇怪的现象,就是一页应该是2048个字节的。每512个字节生成ecc。共4次写。
    但是从打印出来的ECC数据看,只有第一个512字节有ecc,剩下的三个512字节得到的ecc都是0。也就是写进去的2048个字节里,只有前面512个字节是有数据,后面的3个512字节是0。
     我在想是不是我哪里配置错误了,或者内核里,哪里没有修改,导致这样的问题。
     现在问题还不确定是在内核里还是文件系统里。
  • 你好。
    经测试后,发现,如果在内核里,把ecc.mode改成NONE后,也就是直接在内核里,修改成不启用ECC,就可以一直挂载。每次启动都可以挂载文件系统了。
    但如果改成BCH8的方式,当第一次挂载文件系统后,重启后,就不能再挂载文件系统了。
    我的文件系统在bootloader烧写的时候,是以BCH8的方式写到NAND 的文件系统分区里的。
    现在也不清楚是nand_read的错误还是nand_write的错误。
    因为,如果说nand_read错误,但它至少能成功挂载文件系统了。
    只是重启之后,就不能再挂载文件系统了
    在第一次挂载文件系统的时候,是出现的nand_write的操作。如果在内核里,修改nand_write,就是调用nand_write的时候,就直接返回。这样的话,也可以一直挂载文件系统。初步原因就是启动文件系统后,出现写操作,而读和写的ECC校验失败。
  • 您好,我也遇到了同样的问题,将内核的ecc.mode设置为none后,就可以挂载成功,请问找到详细的具体原因了么?
    谢谢。。。
  • hi:
         我用的海力士的nand,H27U4G8F2D 。  UBI 还一直挂载不上。  你所说的在内核的ecc.mode 改为NONE  是在哪儿?
  •  你好。
     之前ubifs文件系统只能挂载一次问题的,改过ecc.mode为none后,可以挂载。后来发现,根本问题不在ecc.mode。
    后来重新制作过文件系统后,发现使用ecc BCH8也可以,因此应该是之前文件系统制作的过程,参数不正确,没有按实际使用的NAND FLASH来配置参数,导致制作的UBIFS文件系统信息和内核分区不匹配。
     因为启动了系统后,会有对文件系统所在的分区有写的操作的,由于文件系统配置信息不对,导致写的时候,写错了位置,导致第二次启动的时候。
    可能这里有点疑惑,使用ecc.mode=none也同样会出现写的操作,而且也是同样写错同一个位置。因为在写的时候,需要先擦除,因此会把原先的ECC数据擦除。因为一擦除就是一整块,但写的数据未必就刚好是一整块。
    还有就是有一些NAND FLASH不支持子页操作的,需要去掉子页读写功能。
  • 很好的总结啊,我当时做UBIFS的时候,尝试过几款NAND FLASH,发现如果不把FLASH研究透,参数错一点启动都会有问题,所以写了那篇文档。
    希望能有更多型号的NAND FLASH被验证!
  • 刚开始接触的时候,对文件系统,NAND FLASH不是很了解,所以,有时候遇到问题也不知道原因在哪里。有时候就只好这边试试,那边改改,通过现象来反馈问题的所在。
      后来也用来镁光,三星等的FLASH。更换FLASH后,出现文件系统挂载不上,对比FLASH的差异以及文件系统制作过程的参数,才找到问题所在。特别是在三星的FLASH,由U0D换为U0E后,也遇到文件系统问题,只是一个支持子页,一个不支持子页,这个问题就得改代码。问题遇到多了,找到问题的所在,把ecc.mode改为none也许并不是解决问题的根本办法,因为表面上也许可以挂载ubifs了,但有可能会存在潜在的系统隐患在里面,后面带来的问题或损失会更大。
     之前看到周工那篇UBIFS文件系统制作的总结,写得挺好的。因为第一次搞ubifs,刚看的时候半懂不懂,后来调试多了,反复读了几次,也慢慢有了感觉。
  • hi, xidong & Jian zhou:
             对于使用支持子页的Nand, 相对应的要修改哪里呢?  我这边是用的海力士  的H27U4G8F 。看datasheet 是支持子页的。
             现在UBI  Fs 虽然能挂载了,但是启动的过程中会报错:
    [ 7.145874] UBI: run torture test for PEB 1237
    [ 7.264953] UBI error: torture_peb: read problems on freshly erased PEB 1237, must be bad
    [ 7.273498] UBI error: erase_worker: failed to erase PEB 1237, error -5
    [ 7.280426] UBI: mark PEB 1237 as bad
    [ 7.284851] UBI: 22 PEBs left in the reserve
    [ 7.335205] UBI: run torture test for PEB 1238
    [ 7.453765] UBI error: torture_peb: read problems on freshly erased PEB 1238, must be bad
    [ 7.462310] UBI error: erase_worker: failed to erase PEB 1238, error -5
    [ 7.469238] UBI: mark PEB 1238 as bad
    [ 7.473602] UBI: 21 PEBs left in the reserve
    把好多标为了坏区,实际上并不是坏区。不知何故??
    linux下 如何检验Nand的好坏?
  • 这里有篇关于UBI的介绍,建议你看看,有些有价值的信息,关键字"peb" :http://blog.csdn.net/kickxxx/article/details/6707589
  • 很好的总结,之前也遇到过同类问题,换了个nandflash,再回去试试看
  • 你好,我也碰到了这问题,请问下你能给下,你的详细参数吗?或者是你改了那个参数才好的?现在我不知道改那个地方的参数,是制作Ubifs文件的,还是Uboot里面的?求教?
  • 我也遇到ubifs文件系统只能挂载一次的问题。
    1、uboot烧录后第一次可以正常加载FS,重启后报错“UBI error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read 126976 bytes”
    2、omap_nand_probe
        info->nand.ecc.mode             = NAND_ECC_NONE;
    ecc mode设置为NAND_ECC_NONE后,FS可以多次加载。
    3、最后发现根本原因是mkfs.ubifsd的选项有问题, –F 应该写成 -F,太隐蔽了。
    当时是参考周工的文档(http://www.deyisupport.com/question_answer/dsp_arm/sitara_arm/f/25/t/59921.aspx)制作的UBIFS,但是“Ubifs文件系统的制作和启动.pdf ”中选项 –F 写的有问题,应该是 -F
