C2000产品应用小贴士
贴上TI工程师汇总的C2000产品小贴士,希望对大家有帮助!内容包括:
- Useful Website for C2000
- DPS Software Library & Header Files
- CCS3.3 Version, CSP, CGT and Flash Plug-In
- CCS Versions & CGT Wiki
- Build Options & CGT Documents
- H/W Design Suggestion
- Vdd / Vss in Piccolo
- Piccolo JTAG Connection
- CCS fails to connect with target
- CSM / Device Locked
- Boot Mode
- Codes run in RAM
- Piccolo ADC
- Piccolo Internal Oscillator & Temp Sensor
- Output GPIO Hi/Lo with SET/CLEAR
- XINTF Difference Between F281x and F2833x
- Flash Programming with Plug-In
C2000 Tips.pdf
