无法安装filterpro软件
如图所示,好像是提示关于.notwork的相关错误
是版本对不上吗
请求协助
以下是install.log的内容
The following properties have been set:
Property: [AdminUser] = true {boolean}
Property: [ProcessorArchitecture] = Intel {string}
Property: [VersionNT] = 5.1.3 {version}
Running checks for package 'Windows Installer 3.1', phase BuildList
The following properties have been set for package 'Windows Installer 3.1':
Running checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe'
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'VersionMsi' and value '3.1': true
Result of checks for command 'WindowsInstaller3_1\WindowsInstaller-KB893803-v2-x86.exe' is 'Bypass'
'Windows Installer 3.1' RunCheck result: No Install Needed
Running checks for package '.NET Framework 3.5 SP1', phase BuildList
Reading value 'SP' of registry key 'HKLM\Software\Microsoft\NET Framework Setup\NDP\v3.5'
Read integer value 0
Setting value '0 {int}' for property 'DotNet35SP'
The following properties have been set for package '.NET Framework 3.5 SP1':
Property: [DotNet35SP] = 0 {int}
Running checks for command 'DotNetFX35SP1\dotNetFx35setup.exe'
Result of running operator 'ValueGreaterThanEqualTo' on property 'DotNet35SP' and value '1': false
Result of running operator 'ValueEqualTo' on property 'AdminUser' and value 'false': false
Result of running operator 'VersionLessThan' on property 'VersionNT' and value '5.1.2': false
Result of running operator 'VersionEqualTo' on property 'VersionNT' and value '5.2.0': false
Result of running operator 'ValueEqualTo' on property 'ProcessorArchitecture' and value 'IA64': false
Result of checks for command 'DotNetFX35SP1\dotNetFx35setup.exe' is 'Install'
'.NET Framework 3.5 SP1' RunCheck result: Install Needed
EULA for components '.NET Framework 3.5 SP1' was accepted.
Copying files to temporary directory "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSD285.tmp\"
Downloading files to "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSD285.tmp\"
(2012-7-5 19:05:45) Downloading 'DotNetFX35SP1\dotNetFx35setup.exe' from 'http://go.microsoft.com/fwlink/?linkid=118076' to 'C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSD285.tmp\'
Download completed at 2012-7-5 19:05:49
Verifying file integrity of C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSD285.tmp\DotNetFX35SP1\dotNetFx35setup.exe
WinVerifyTrust returned -2146762496
File not signed
Error: Setup has detected that the file 'C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSD285.tmp\DotNetFX35SP1\dotNetFx35setup.exe' has changed since it was initially published.
(2012-7-5 19:05:50) Downloading 'DotNetFX35SP1\dotNetFx35setup.exe' from 'http://go.microsoft.com/fwlink/?linkid=118076' to 'C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSD285.tmp\'
Download completed at 2012-7-5 19:05:51
File not signed
(2012-7-5 19:05:52) Downloading 'DotNetFX35SP1\dotNetFx35setup.exe' from 'http://go.microsoft.com/fwlink/?linkid=118076' to 'C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSD285.tmp\'
Download completed at 2012-7-5 19:05:53
File not signed
(2012-7-5 19:05:54) Downloading 'DotNetFX35SP1\dotNetFx35setup.exe' from 'http://go.microsoft.com/fwlink/?linkid=118076' to 'C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSD285.tmp\'
Download completed at 2012-7-5 19:05:54
File not signed
(2012-7-5 19:06:06) Downloading 'DotNetFX35SP1\dotNetFx35setup.exe' from 'http://go.microsoft.com/fwlink/?linkid=118076' to 'C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSD285.tmp\'
Download completed at 2012-7-5 19:06:06
File not signed
(2012-7-5 19:06:07) Downloading 'DotNetFX35SP1\dotNetFx35setup.exe' from 'http://go.microsoft.com/fwlink/?linkid=118076' to 'C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\VSD285.tmp\'
Download completed at 2012-7-5 19:06:07
File not signed
