各位工程师好:
我自己编写了一个基于28377D的CAN Bootloader程序,程序位于FLASHA和FLASHB。要升级的程序放在FLASHE。
目前的问题是,上位机传送烧写完之后,dsp断电重启不能跳转至FLASHE中的APP程序(通过GPIO口高低电平判断是否进入bootloader)
随后,我进行了以下几个实验:
(1) 将APP程序利用仿真器烧入FLASH-E(不擦除FLASHA、B中的Bootloader程序),DSP开机后可成功由Bootloader跳转至APP程序;
(2) 使用上位机向DSP的FLASH-E中烧写HEX文件,利用仿真器擦除FLASHA、B中的Bootloader程序并重新烧写Bootloader程序(不擦除FLASH-E中的 APP程序),在线单步运行时,可以由Bootloader跳转至APP程序,并自动运行;
(3) 我分别对比了HEX数据、利用仿真器烧入FLASH-E中的数据和利用上位机程序烧入FLASH-E中的数据,对比结果是地址和数据完全正确。
以下是跳转语句:ENTRYADDR为FLASHE前的BEGIN起始地址
static void(*APPEntry)(void);
APPEntry = (void(*)(void))(ENTRYADDR);
ESTOP0;
(*APPEntry)();
以下为Bootloader程序的CMD文件:
MEMORY
PAGE 0: /* Program Memory */
/* Memory (RAM/FLASH) blocks can be moved to PAGE1 for data allocation */
/* BEGIN is used for the "boot to Flash" bootloader mode */
BEGIN : origin = 0x080000, length = 0x000002
RAMM0 : origin = 0x000122, length = 0x0002DE
RAMD0 : origin = 0x00B000, length = 0x000800
RAMLS0 : origin = 0x008000, length = 0x000800
RAMLS1 : origin = 0x008800, length = 0x000800
RAMLS2 : origin = 0x009000, length = 0x000800
RAMLS3 : origin = 0x009800, length = 0x000800
RAMLS4 : origin = 0x00A000, length = 0x000800
RAMGS14 : origin = 0x01A000, length = 0x001000
RAMGS15 : origin = 0x01B000, length = 0x001000
RESET : origin = 0x3FFFC0, length = 0x000002
/* Flash sectors */
FLASHA : origin = 0x080002, length = 0x001FFE /* on-chip Flash */ //Bootloader
FLASHB : origin = 0x082000, length = 0x002000 /* on-chip Flash */ //Bootloader
FLASHC : origin = 0x084000, length = 0x002000 /* on-chip Flash */
FLASHD : origin = 0x086000, length = 0x002000 /* on-chip Flash */
FLASHE : origin = 0x088000, length = 0x008000 /* on-chip Flash */ //APP烧入
FLASHF : origin = 0x090000, length = 0x008000 /* on-chip Flash */
FLASHG : origin = 0x098000, length = 0x008000 /* on-chip Flash */
FLASHH : origin = 0x0A0000, length = 0x008000 /* on-chip Flash */
FLASHI : origin = 0x0A8000, length = 0x008000 /* on-chip Flash */
FLASHJ : origin = 0x0B0000, length = 0x008000 /* on-chip Flash */
FLASHK : origin = 0x0B8000, length = 0x002000 /* on-chip Flash */
FLASHL : origin = 0x0BA000, length = 0x002000 /* on-chip Flash */
FLASHM : origin = 0x0BC000, length = 0x002000 /* on-chip Flash */
FLASHN : origin = 0x0BE000, length = 0x002000 /* on-chip Flash */
PAGE 1 : /* Data Memory */
/* Memory (RAM/FLASH) blocks can be moved to PAGE0 for program allocation */
BOOT_RSVD : origin = 0x000002, length = 0x000120 /* Part of M0, BOOT rom will use this for stack */
RAMM1 : origin = 0x000400, length = 0x000400 /* on-chip RAM block M1 */
RAMD1 : origin = 0x00B800, length = 0x000800
RAMLS5 : origin = 0x00A800, length = 0x000800
RAMGS0 : origin = 0x00C000, length = 0x001000
RAMGS1 : origin = 0x00D000, length = 0x001000
RAMGS2 : origin = 0x00E000, length = 0x001000
RAMGS3 : origin = 0x00F000, length = 0x001000
RAMGS4 : origin = 0x010000, length = 0x001000
RAMGS5 : origin = 0x011000, length = 0x001000
RAMGS6 : origin = 0x012000, length = 0x001000
RAMGS7 : origin = 0x013000, length = 0x001000
RAMGS8 : origin = 0x014000, length = 0x001000
RAMGS9 : origin = 0x015000, length = 0x001000
RAMGS10111213 : origin = 0x016000, length = 0x004000
/* RAMGS11 : origin = 0x017000, length = 0x001000
RAMGS12 : origin = 0x018000, length = 0x001000
RAMGS13 : origin = 0x019000, length = 0x001000
CPU2TOCPU1RAM : origin = 0x03F800, length = 0x000400
CPU1TOCPU2RAM : origin = 0x03FC00, length = 0x000400
SECTIONS
/* Allocate program areas: */
.cinit : > FLASHA PAGE = 0
.pinit : > FLASHA , PAGE = 0
.text : >> FLASHA | FLASHB PAGE = 0
codestart : > BEGIN PAGE = 0
#ifdef __TI_COMPILER_VERSION__
#if __TI_COMPILER_VERSION__ >= 15009000
GROUP
.TI.ramfunc
{ -l F021_API_F2837xD_FPU32.lib}
} LOAD = FLASHA ,
RUN = RAMGS14 | RAMGS15, // modified RAMLS03 to RAMGS14 | RAMGS15
LOAD_START(_RamfuncsLoadStart),
LOAD_SIZE(_RamfuncsLoadSize),
LOAD_END(_RamfuncsLoadEnd),
RUN_START(_RamfuncsRunStart),
RUN_SIZE(_RamfuncsRunSize),
RUN_END(_RamfuncsRunEnd),
PAGE = 0
#else
GROUP
ramfuncs
} LOAD = FLASHA ,
PAGE = 0
#endif
#endif
/* Allocate uninitalized data sections: */
.stack : > RAMM1 PAGE = 1
.ebss : >> RAMGS10111213 PAGE = 1
.esysmem : > RAMLS5 PAGE = 1
/* Initalized sections go in Flash */
.econst : >> FLASHA PAGE = 0
.switch : > FLASHA PAGE = 0
.reset : > RESET, PAGE = 0, TYPE = DSECT /* not used, */
Filter_RegsFile : > RAMGS0, PAGE = 1
SHARERAMGS0 : > RAMGS0, PAGE = 1
SHARERAMGS1 : > RAMGS1, PAGE = 1
/* Flash Programming Buffer */
BufferDataSection : > RAMD1, PAGE = 1, ALIGN(4)
/* The following section definitions are required when using the IPC API Drivers */
GROUP : > CPU1TOCPU2RAM, PAGE = 1
PUTBUFFER
PUTWRITEIDX
GETREADIDX
GROUP : > CPU2TOCPU1RAM, PAGE = 1
GETBUFFER : TYPE = DSECT
GETWRITEIDX : TYPE = DSECT
PUTREADIDX : TYPE = DSECT
// End of file.
以下为APP程序的CMD文件:
MEMORY
PAGE 0 : /* Program Memory */
BEGIN : origin = 0x088000, length = 0x000002
RAMGS14 : origin = 0x01A000, length = 0x001000 /* Only Available on F28379D, F28377D, F28375D devices. Remove line on other devices. */
RAMGS15 : origin = 0x01B000, length = 0x001000 /* Only Available on F28379D, F28377D, F28375D devices. Remove line on other devices. */
/* Flash sectors */
FLASHA : origin = 0x080000, length = 0x002000 /* on-chip Flash */
FLASHE : origin = 0x088002, length = 0x007FFE /* on-chip Flash */
SECTIONS
.cinit : > FLASHE PAGE = 0, ALIGN(4)
.pinit : > FLASHE, PAGE = 0, ALIGN(4)
.text : >> FLASHE PAGE = 0, ALIGN(4)
codestart : > BEGIN PAGE = 0, ALIGN(4)
.econst : >> FLASHE PAGE = 0, ALIGN(4)
.switch : > FLASHE PAGE = 0, ALIGN(4)
ramgs0 : > RAMGS0, PAGE = 1
ramgs1 : > RAMGS1, PAGE = 1
.TI.ramfunc : {} LOAD = FLASHE,
PAGE = 0, ALIGN(4)
#else
ramfuncs : LOAD = FLASHE,
PAGE = 0, ALIGN(4)
#endif
#endif
PUTBUFFER
PUTWRITEIDX
GETREADIDX
/* The following section definition are for SDFM examples */
Filter1_RegsFile : > RAMGS1, PAGE = 1, fill=0x1111
Filter2_RegsFile : > RAMGS2, PAGE = 1, fill=0x2222
Filter3_RegsFile : > RAMGS3, PAGE = 1, fill=0x3333
Filter4_RegsFile : > RAMGS4, PAGE = 1, fill=0x4444
Difference_RegsFile : >RAMGS5, PAGE = 1, fill=0x3333
// End of file.
实在不知问题出在了哪里,望解答,谢谢!!
