使用CMPSS来强制拉低TMS320F28377D的ePWM
     大家好,
     我想用CMPSS实现降压转换器的峰值电流模式控制。 因此,我编写了一些代码来测试CMPSS和ePWM。 测试波形如下,其中浅蓝色线表示CMPIN1P / ADCINA2中连接的信号,粉色线表示CMPIN1N / ADCINA3中连接的信号。 绿线是输出信号(ePWM6A)。
       在代码中,我将默认占空比设置为50%,并在CMPSS跳闸事件发生时强制为低。 图1给出了CMPSS工作的波形,它可以强制PWM为低电平。 但是,根据图2,当CMPIN1P> CMPIN1N时,ePWM总是很低,这不是我想要的。 我希望在CMPIN1P> CMPIN1N期间,PWM总是输出我设置的占空比(50%而不是总是低)。 代码如下所示,我应该如何设置寄存器? 谢谢!
void InitEPwm6Example(void)
    EPwm6Regs.TBPRD = 500;                       // Set timer period
    EPwm6Regs.TBPHS.bit.TBPHS = 0x0000;           // Phase is 0
    EPwm6Regs.TBCTR = 0x0000;                     // Clear counter
    // Setup TBCLK
    EPwm6Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up
    EPwm6Regs.TBCTL.bit.PHSEN = TB_DISABLE;        // Disable phase loading
    EPwm6Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1;       // Clock ratio to SYSCLKOUT
    EPwm6Regs.TBCTL.bit.CLKDIV = TB_DIV1;          // Slow just to observe on
    // the scope.
    EPwm6Regs.TBCTL.bit.PHSEN = TB_ENABLE;         //禁止相位控制
    EPwm6Regs.TBCTL.bit.PRDLD = TB_SHADOW;          //TBPRD寄存器采用映射模式
    EPwm6Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; //禁止同步信号
    // Setup compare
    EPwm6Regs.CMPA.bit.CMPA = 250;                   //计数到此,强制拉低
    // Set actions
    EPwm6Regs.AQCTLA.bit.ZRO = AQ_SET;               //在计数为0处,设置EPWMA为高电平
    EPwm6Regs.AQCTLA.bit.CAU = AQ_CLEAR;             // 达到设定计数值CMPA处,EPWMA为低电平
    EALLOW;
    //Configure DCB to be TRIP4
    EPwm6Regs.DCTRIPSEL.bit.DCBHCOMPSEL = 3;         //选择Zone4 作为触发Trip 4
    EPwm6Regs.TZDCSEL.bit.DCBEVT2 = TZ_DCBH_HI;      //Digital compare output B event 2 选择
    EPwm6Regs.TZSEL.bit.DCBEVT2 = 1;//Configure DCB as CBC
    //Configure DCB path to be filtered & async
    EPwm6Regs.DCBCTL.bit.EVT2SRCSEL = DC_EVT_FLT;            // Source is DCBEVT2 Signa
    EPwm6Regs.DCBCTL.bit.EVT2FRCSYNCSEL = DC_EVT_SYNC;    // 0: Source Is Synchronous Signal
   //空窗设置
    EPwm6Regs.DCFCTL.bit.BLANKE=1;                        //1: Blanking window is enabled
    EPwm6Regs.DCFCTL.bit.PULSESEL=2;                      // Time-base counter equal to zero (TBCTR = 0x00)
    EPwm6Regs.DCFCTL.bit.SRCSEL=3;                        // Source Is DCBEVT2 Signal
    EPwm6Regs.DCFOFFSET=0;                                //Blanking Window Offset
    EPwm6Regs.DCFWINDOW=30;                               //0.1 us  20
    EPwmXbarRegs.TRIP4MUXENABLE.bit.MUX0 = 1;  //Enable TRIP4 Mux for Output
    EPwm6Regs.TZCTL.bit.TZA=TZ_FORCE_LO;       // Force EPWMxA to a low state
    EPwm6Regs.TZCLR.bit.CBCPULSE=0;            //CTR = zero pulse clears CBC trip latch. (Same as legacy designs.)
    EPwmXbarRegs.TRIP5MUXENABLE.bit.MUX0 = 1;  //Enable TRIP4 Mux for Output
    EDIS;
// InitCMPSS - Initialize CMPSS1 and configure settings
void InitCMPSS(void)
    EALLOW;
    //Enable CMPSS
    Cmpss1Regs.COMPCTL.bit.COMPDACE = 1;
    //NEG signal comes from DAC
    Cmpss1Regs.COMPCTL.bit.COMPHSOURCE = NEGIN_PIN;
    //Use VDDA as the reference for DAC
    Cmpss1Regs.COMPDACCTL.bit.SELREF = REFERENCE_VDDA;
    //Set DAC to midpoint for arbitrary reference
//    Cmpss1Regs.DACHVALS.bit.DACVAL = 800;
    // Configure CTRIPOUT path
    // Asynch output feeds CTRIPH and CTRIPOUTH
//    Cmpss1Regs.COMPCTL.bit.CTRIPHSEL = CTRIP_SYNCH;
//    Cmpss1Regs.COMPCTL.bit.CTRIPOUTHSEL = CTRIP_SYNCH;
    EDIS;
1 个回复
