如题:请问各位大佬们这个DATALOG 模块的作用是什么?初始化时这几句是什么作用
dlog.trig_value = 0x01;
dlog.size = 0x400;
dlog.prescalar = 1;
其头文件如下:
#ifndef __DLOG4CH_H__
#define __DLOG4CH_H__
#define NULL 0
typedef struct { long task; // Variable: Task address pointer
int *iptr1; // Input: First input pointer (Q15)
int *iptr2; // Input: Second input pointer (Q15)
int *iptr3; // Input: Third input pointer (Q15)
int *iptr4; // Input: Fourth input pointer (Q15)
int trig_value; // Input: Trigger point (Q15)
int prescalar; // Parameter: Data log prescale
int skip_cntr; // Variable: Data log skip counter
int cntr; // Variable: Data log counter
long write_ptr; // Variable: Graph address pointer
int size; // Parameter: Maximum data buffer
int (*init)(); // Pointer to init function
int (*update)(); // Pointer to update function
} DLOG_4CH;
typedef DLOG_4CH *DLOG_4CH_handle;
void DLOG_4CH_init(void *);
void DLOG_4CH_update(void *);
Default initalizer for the DLOG_4CH object.
#define DLOG_4CH_DEFAULTS { 0UL, \
NULL, \
NULL, \
NULL, \
NULL, \
0, \
1, \
0, \
0, \
0UL, \
0x400, \
(int (*)(int))DLOG_4CH_init, \
(int (*)(int))DLOG_4CH_update }
#define NULL 0
} DLOG_4CH;
NULL, \
NULL, \
NULL, \
NULL, \
0, \
1, \
0, \
0, \
0UL, \
0x400, \
#endif
其初始化语句如下:
// Initialize DATALOG module
dlog.iptr1 = &DlogCh1;
dlog.iptr2 = &DlogCh2;
dlog.iptr3 = &DlogCh3;
dlog.iptr4 = &DlogCh4;
dlog.size = 0x400;
dlog.prescalar = 1;
dlog.init(&dlog);
dlog.size = 0x400;
dlog.prescalar = 1;
dlog.init(&dlog);
