请教一下TMS320F28069这款DSP的浮点运算能力怎么样?
我做了一个简单测试: 运算同样的代码(表达式有加减乘除法),其中定点运算方式采用放大、移位方式执行。测试发现定点运算的时间是1.54us,但浮点运算的时间是2.85us,相对定点运算,浮点运算时间更长。(执行此部分代码时有屏蔽中断)
我的CCS版本为V5.2,工程配置为:
-v28 -ml -mt --cla_support=cla0 --float_support=fpu32 --vcu_support=vcu0 -g --
我的CCS版本为V5.2,工程配置为:
Hi, Eric,
我的测试代码如下:
其中stAD_SAMP_CHn、stAD_MIDP_CHn、stAD_REAL_CHn定义为signed int型;stAD_REAL_CH1_F为float型。
//FOR FIXED
/*get adc value*/
stAD_SAMP_CH1 = AdcResult.ADCRESULT0 - stAD_MIDP_CH1;
stAD_SAMP_CH2 = AdcResult.ADCRESULT1 - stAD_MIDP_CH2;
stAD_SAMP_CH3 = AdcResult.ADCRESULT2 - stAD_MIDP_CH3;
stAD_SAMP_CH4 = AdcResult.ADCRESULT3 - stAD_MIDP_CH4;
stAD_SAMP_CH5 = AdcResult.ADCRESULT4 - stAD_MIDP_CH5;
stAD_SAMP_CH6 = AdcResult.ADCRESULT5 - stAD_MIDP_CH6;
stAD_SAMP_CH7 = AdcResult.ADCRESULT6 - stAD_MIDP_CH7;
stAD_SAMP_CH8 = AdcResult.ADCRESULT7 - stAD_MIDP_CH8;
stAD_SAMP_CH9 = AdcResult.ADCRESULT8 - stAD_MIDP_CH9;
stAD_SAMP_CH10 = AdcResult.ADCRESULT9 - stAD_MIDP_CH10;
stAD_SAMP_CH11 = AdcResult.ADCRESULT10 - stAD_MIDP_CH11;
stAD_SAMP_CH12 = AdcResult.ADCRESULT11 - stAD_MIDP_CH12;
stAD_SAMP_CH13 = AdcResult.ADCRESULT12 - stAD_MIDP_CH13;
stAD_SAMP_CH14 = AdcResult.ADCRESULT13 - stAD_MIDP_CH14;
stAD_SAMP_CH15 = AdcResult.ADCRESULT14 - stAD_MIDP_CH15;
stAD_SAMP_CH16 = AdcResult.ADCRESULT15 - stAD_MIDP_CH16;
/*calculate the real value*/
stAD_REAL_CH1 = (int16_t)(((int32_t)stAD_SAMP_CH1 * cRatio_CH1) >> 12);
stAD_REAL_CH2 = (int16_t)(((int32_t)stAD_SAMP_CH2 * cRatio_CH2) >> 12);
stAD_REAL_CH3 = (int16_t)(((int32_t)stAD_SAMP_CH3 * cRatio_CH3) >> 12);
stAD_REAL_CH4 = (int16_t)(((int32_t)stAD_SAMP_CH4 * cRatio_CH4) >> 12);
stAD_REAL_CH5 = (int16_t)(((int32_t)stAD_SAMP_CH5 * cRatio_CH5) >> 12);
stAD_REAL_CH6 = (int16_t)(((int32_t)stAD_SAMP_CH6 * cRatio_CH6) >> 12);
stAD_REAL_CH7 = (int16_t)(((int32_t)stAD_SAMP_CH7 * cRatio_CH7) >> 12);
//FOR FLOAT
/*get adc value*/
stAD_REAL_CH1_F = (float)stAD_SAMP_CH1 * 0.2134256;
stAD_REAL_CH2_F = (float)stAD_SAMP_CH2 * 0.2134256;
stAD_REAL_CH3_F = (float)stAD_SAMP_CH3 * 0.2134256;
stAD_REAL_CH4_F = (float)stAD_SAMP_CH4 * 0.2134256;
stAD_REAL_CH5_F = (float)stAD_SAMP_CH5 * 0.2134256;
stAD_REAL_CH6_F = (float)stAD_SAMP_CH6 * 0.2134256;
stAD_REAL_CH7_F = (float)stAD_SAMP_CH7 * 0.2134256;
BenShan,
下面是我的测试代码,开发环境CCSv5.3, 使用的配置是从controlSUITE中导入一个28069的timer_blink程序。加载"rts2800_fpu32.lib", "rts2800_fpu32_fast_supplement.lib", "IQmath_fpu32.lib", 程序load在RAM中。
// fpu test
Uint32 temp = 0;
float result =0;
_iq result1 ;
_iq temp1; //断点 clock 清零
result = 0.12*0.12;
result = 0.12*0.12;
result = 0.12*0.12;
result = 0.12*0.12;
result = 0.12*0.12;
temp = 1; // 断点 clock = 12; 所以使用FPU单元,计算5条乘法指令为12个系统时钟; clock 清零
temp1=_IQ(0.12); // gloable IQ = 24
result1 = _IQmpy(temp1,temp1);
temp = 2; // 断点 clock = 28 ; 使用IQmath库进行运算,使用28个时钟; clock清零
result = 0.125*0.12;
temp = 1; // 断点 clock = 12;clock 清零
temp1=_IQ(0.12);
result1 = temp1>>3;
result1 = temp1>>3;
result1 = temp1>>3;
result1 = temp1>>3;
result1 = temp1>>3;
temp = 2; // 断点 移3位时clock = 17; 若只移1位 clock =9;
通过上面的测试,可以看出有些时候移位确实会比FPU的效率高一点,但是如果移位数增加了,FPU的效率也会超过移位。
另外FPU在编程上也更方便。希望以上对你有些帮助。
Eric
