Hi,
I noticed that the chip(TMS570LS0714PGE)has 2 output ports named GIOB2, pin142 and pin55.
And pin55 has functions as follows,
MIBSPI3NCS[0]/AD2EVT/GIOB[2]/EQEP1I/N2HET2_PIN_nD IS |
but in HCG ,pin55' configuration item is grey and can not be configured as any function other than GIOB2.
And it doesn't output anything.
Can you tell me how I can use pin55 as an output pin?
thank you .
