求MSP430FR6047高频振荡器时钟配置例程
特别是判断外置16M晶振起振的判断语句,官网的例程只有低频的32768的配置以及判断。求一下外部高频的配置和判断起振标志语句
  • 例程里有使用8Mhz外部晶振的例子
    www.ti.com/.../slac747
    昵称:灰小子
    qq:1358611172
  • 您可以看一下
    // MSP430FR60xx Demo - ACLK = XT1 = 32768Hz, SMCLK= XT2 = 8MHz, MCLK = DCO
    // Description: Configure ACLK = LFXT, SMCLK = HFXT and MCLK = DCO
    // NOTE1: 32768Hz and 8MHz crystals required!
    If a post answers your question, please mark it with the "verify answer" button.
    若是回复解决了您的问题,请点击“是”确认答案。谢谢!
  • 回复 dirtwillfly:
    我下了例程,可是他那里边用的8M是用DCO生成的,不是外部高频振荡器吧
  • 回复 huan liu:
    也有用外部高频晶振的
    //   MSP430FR60xx Demo - Output USSXT OSC at 8MHz on a pin.
    //   Description: Configure USSXT = 8MHz and output on a pin. This can be used
    //   for monitoring the clock or use the clock as the source of another subsystem.
    //           MSP430FR6047
    //      --|RST            |
    //        |           P1.0|---> LED
    //        |               |-USSXTIN
    //        |               |-USSXTOUT
    //        |           P8.7|---> USSXT_BOUT (8MHz)
    //   Katie Pier
    //   Texas Instruments Inc.
    //   June 2017
    //   Built with IAR Embedded Workbench V6.50 & Code Composer Studio V7.1
    #include <msp430.h>
    #define OSCTYPE__CRYSTAL OSCTYPE_0
    int main(void)
        WDTCTL = WDTPW | WDTHOLD;               // Stop WDT
        // Configure P8.7 as USSXT_BOUT
        P8DIR |= BIT7;
        P8SEL1 |= BIT7;
        P8SEL0 &= ~BIT7;
        // Configure P1.0 as output for LED
        P1OUT &= ~BIT0;
        P1DIR |= BIT0;
        // Disable the GPIO power-on default high-impedance mode to activate
        // previously configured port settings
        PM5CTL0 &= ~LOCKLPM5;
        // Clock System Setup
        CSCTL0_H = CSKEY_H;                     // Unlock CS registers
        CSCTL1 = DCOFSEL_3;                     // Set DCO to 8MHz
        // Set SMCLK = MCLK = DCO, ACLK = VLOCLK
        CSCTL2 = SELA__VLOCLK | SELS__DCOCLK | SELM__DCOCLK;
        CSCTL3 = DIVA__1 | DIVS__8 | DIVM__8;   // MCLK = SMCLK = 1MHz
        CSCTL0_H = 0;                           // Lock CS registers
        //Configure USSXT Oscillator
        HSPLLUSSXTLCTL = OSCTYPE__CRYSTAL |  USSXTEN;
        // Set up timer to wait in LPM for crystal stabilization time = 4096 clocks for crystal resonator.
        // For 8MHz XTAL, 4096 clocks = 512us. Using VLO = 9.4kHz, wait 5 timer clock cycles = 532us.
        TA4CCR0 = 5;
        TA4CCTL0 = CCIE;                        // Enable Interrupt
        TA4CTL = TASSEL__ACLK | TACLR | MC__UP; // Timer sourced from ACLK (VLO), clear timer
        __bis_SR_register(LPM3_bits | GIE);     // Enter LPM3 w/interrupt
        __no_operation();                       // For debug
        // Check if oscillator is stable
        while((HSPLLUSSXTLCTL & OSCSTATE) == 0);
        // Output oscillator on pin
        HSPLLUSSXTLCTL &= ~XTOUTOFF;
        while(1)
            P1OUT ^= BIT0;                      // Toggle LED to show oscillator init complete
            __delay_cycles(50000);              // Wait 100,000 CPU cycles
    // Timer A4 interrupt service routine
    #if defined(__TI_COMPILER_VERSION__) || defined(__IAR_SYSTEMS_ICC__)
    #pragma vector = TIMER4_A0_VECTOR
    __interrupt void Timer4_A0_ISR(void)
    #elif defined(__GNUC__)
    void __attribute__ ((interrupt(TIMER4_A0_VECTOR))) Timer4_A0_ISR (void)
    #else
    #error Compiler not supported!
    #endif
        // Stop the timer and wake from LPM
        TA4CTL = MC__STOP;
        __bic_SR_register_on_exit(LPM3_bits | GIE);
        __no_operation();
    昵称:灰小子
    qq:1358611172
