你好,
这是一个客户的问题。
现象:MCU采用外部硬件看门狗电路,硬件看门狗电路输出正常的复位信号(通过示波器测量复位信号的高低电平均正常)。该复位信号输入到MSP430芯片后,MSP430晶振无法正常起振。(用示波器测量晶振信号为直流电平。无源晶振不起振现象为偶发现象,并非每块板卡都会,概率:几十次出现一次)。测量MCU电源未发现异常,查看晶振PCB走线,走线很短,阻抗50Ω,包地良好,且无源晶振附近无其他信号线。
可以帮忙看一下吗?
你好,
这是一个客户的问题。
可以帮忙看一下吗?
另外代码内XTS要重新配置成1来使能XT1的高频功能。
/* --COPYRIGHT--,BSD_EX
* Copyright (c) 2012, Texas Instruments Incorporated
* All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
* THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
* OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
* WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
* OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* MSP430 CODE EXAMPLE DISCLAIMER
* MSP430 code examples are self-contained low-level programs that typically
* demonstrate a single peripheral function or device feature in a highly
* concise manner. For this the code may rely on the device's power-on default
* register values and settings such as the clock configuration and care must
* be taken when combining code from several examples to avoid potential side
* effects. Also see www.ti.com/grace for a GUI- and www.ti.com/msp430ware
* for an API functional library-approach to peripheral configuration.
* --/COPYRIGHT--*/
// MSP-FET430P140 Demo - Basic Clock, MCLK Sourced from HF XTAL
// Description: Proper selection of an external HF XTAL for MCLK is shown by
// first polling the OSC fault until XTAL is stable - only then is MCLK
// sourced by LFXT1. MCLK is on P5.4
// ACLK= MCLK= LFXT1= HF XTAL
// //* HF XTAL NOT INSTALLED ON FET *//
// //* Min Vcc required varies with MCLK frequency - refer to datasheet *//
// MSP430F149
// /|\| XIN|-
// | | | HF XTAL (455k - 8Mhz)
// --|RST XOUT|-
// | P5.4|-->MCLK = XTAL
// M. Buccini
// Texas Instruments Inc.
// Feb 2005
// Built with CCE Version: 3.2.0 and IAR Embedded Workbench Version: 3.21A
#include <msp430.h>
int main(void)
volatile unsigned int i;
WDTCTL = WDTPW + WDTHOLD; // Stop WDT
P5DIR |= 0x10; // P5.4= output direction
P5SEL |= 0x10; // P5.4= MCLK option select
BCSCTL1 |= XTS; // ACLK= LFXT1 = HF XTAL
do
IFG1 &= ~OFIFG; // Clear OSCFault flag
for (i = 0xFF; i > 0; i--); // Time for flag to set
while ((IFG1 & OFIFG)); // OSCFault flag still set?
BCSCTL2 |= SELM_3; // MCLK= LFXT1 (safe)
for (;;); // Do nothing
