TM4C TI PinMux工具使用教程
记得以前TI的TM4C12x是有PinMux这个工具的电脑版的,可以自由的安装和使用,不过现在电脑版被放弃了,主打的是网络版。
地址如下所示:
https://dev.ti.com/pinmux/app.html#/default
打开后显示如下:
首先选择开发板的型号和芯片的名称,由于我是自己的板子,所以直接选择芯片的名称就好了。点击start开始进行设计。
打开后的界面如下所示。最左面是所选择的芯片对应的所有外设名称和数量,中间是当前所选择外设的引脚,并列出了可选择或者映射的引脚名称,最右面是芯片的引脚图和可生成的配置文件下载。
配置好外设的引脚名称和功能后,点击最右面的下载,即可下载配置好的外设初始化.c.h文件了。
  • 生成的代码如下所示:
    // Configure the device pins for different signals
    // Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/
    //  Redistribution and use in source and binary forms, with or without
    //  modification, are permitted provided that the following conditions
    //  are met:
    //    Redistributions of source code must retain the above copyright
    //    notice, this list of conditions and the following disclaimer.
    //    Redistributions in binary form must reproduce the above copyright
    //    notice, this list of conditions and the following disclaimer in the
    //    documentation and/or other materials provided with the
    //    distribution.
    //    Neither the name of Texas Instruments Incorporated nor the names of
    //    its contributors may be used to endorse or promote products derived
    //    from this software without specific prior written permission.
    //  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
    //  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
    //  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    //  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
    //  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
    //  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
    //  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
    //  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
    //  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
    //  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
    //  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    // This file was automatically generated on 2018/2/20 at 下午10:45:29
    // by TI PinMux version 4.0.1511
    #include <stdbool.h>
    #include <stdint.h>
    #include "inc/hw_gpio.h"
    #include "inc/hw_memmap.h"
    #include "inc/hw_types.h"
    #include "driverlib/gpio.h"
    #include "driverlib/pin_map.h"
    #include "driverlib/rom.h"
    #include "driverlib/rom_map.h"
    #include "driverlib/sysctl.h"
    #include "pinout.h"
    //! \addtogroup pinout_api
    //! Configures the device pins for the customer specific usage.
    //! \return None.
    void
    PinoutSet(void)
        // Enable Peripheral Clocks
    	MAP_SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD);
        // Configure the GPIO Pin Mux for PD0
    	// for GPIO_PD0
    	MAP_GPIOPinTypeGPIOOutput(GPIO_PORTD_BASE, GPIO_PIN_0);
    	MAP_GPIOPinWrite(GPIO_PORTD_BASE, GPIO_PIN_0, GPIO_PIN_0);
        // Configure the GPIO Pin Mux for PD2
    	// for GPIO_PD2
    	MAP_GPIOPinTypeGPIOInput(GPIO_PORTD_BASE, GPIO_PIN_2);
        // Configure the GPIO Pin Mux for PD3
    	// for GPIO_PD3
    	MAP_GPIOPinTypeGPIOInput(GPIO_PORTD_BASE, GPIO_PIN_3);
        // Configure the GPIO Pin Mux for PD1
    	// for GPIO_PD1
    	MAP_GPIOPinTypeGPIOInput(GPIO_PORTD_BASE, GPIO_PIN_1);
    // Close the Doxygen group.
    // pinout.h
    // configure the device pins for different signals
    //  are met:
    //    distribution.
    // This file was automatically generated on 2018/2/20 at 下午10:45:32
    #ifndef __DRIVERS_PINOUT_H__
    #define __DRIVERS_PINOUT_H__
    // If building with a C++ compiler, make all of the definitions in this header
    // have a C binding.
    #ifdef __cplusplus
    extern "C"
    #endif
    // Prototypes.
    extern void PinoutSet(void);
    // Mark the end of the C bindings section for C++ compilers.
    #ifdef __cplusplus
    #endif
    #endif // __DRIVERS_PINOUT_H__
