#include "inc/hw_ints.h"
#include "inc/hw_memmap.h"
#include "inc/hw_types.h"
#include "driverlib/gpio.h"
#include "driverlib/sysctl.h"
#define PINS GPIO_PIN_6
void delay(int d)
for(;d;--d);
void SysCtlClockSet(unsigned long ulConfig)
void SysCtlPeripheralEnable (unsigned long ulPeripheral)
void GPIODirModeSet(unsigned long ulPort,unsigned char ucPins,unsigned long ulPinIO)
void GPIOPinWrite(unsigned long ulPort, unsigned char ucPins, unsigned char ucVal)
int main(void)
unsigned int i;
SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_OSC|SYSCTL_OSC_MAIN|SYSCTL_XTAL_16MHZ);//直接使用外部晶振
SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOB);//使能GPIO的PB模块
GPIODirModeSet(GPIO_PORTB_BASE,PINS,GPIO_DIR_MODE_OUT);//设置PB6输出
for(i=0;i<10;i++)
GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_6,1);//置PB6低电平
delay(20000);
GPIOPinWrite(GPIO_PORTB_BASE, GPIO_PIN_6,0);//置PB6高电平
delay(20000);
SysCtlClockSet(SYSCTL_SYSDIV_1|SYSCTL_USE_PLL|SYSCTL_OSC_MAIN|SYSCTL_XTAL_16MHZ);//使用PLL
for(i=0;i<10;i++)
{GPIOPinWrite(GPIO_PORTB_BASE,PINS,~PINS);
delay(20000);
GPIOPinWrite(GPIO_PORTB_BASE,PINS,PINS);
delay(20000);
while(1);
// return 0;
GPIOB相应的寄存器数据不改变,单步运行没反应。板子是LM3S9B92 开发环境CCSV5
