cc2650调用pin_open()异常
用2.2版本的sdk(ble),用sensortag的例子工程,在iar中编译正常,但功能异常,跟踪发现在i2c的初始化调用pin_open()出现异常,提示cstack指针超出范围:Sun Jan 28, 2018 19:20:51: The stack pointer for stack 'CSTACK' (currently 0x200030F0) is outside the stack range (0x20003F48 to 0x20004348)
