cc2640r2f 有一个蓝牙任务,然后创建一个adc驱动任务,手机连接上后,蓝牙发送一段时间就不发了
仿真调试发现,程序卡在osal_start_system 函数里面,
osal_run_system();  ICall_wait(ICALL_TIMEOUT_FOREVER);这两句话反复执行,
具体完整代码如下
void osal_start_system( void )
#ifdef USE_ICALL
/* Kick off timer service in order to allocate resources upfront.
* The first timeout is required to schedule next OSAL timer event
* as well. */
ICall_Errno errno = ICall_setTimer(1, osal_msec_timer_cback,
(void *) osal_msec_timer_seq,
&osal_timerid_msec_timer);
if (errno != ICALL_ERRNO_SUCCESS)
ICall_abort();
#endif /* USE_ICALL */
#if !defined ( ZBIT ) && !defined ( UBIT )
for(;;) // Forever Loop
#endif
osal_run_system();
#ifdef USE_ICALL
请问什么原因导致的?
