我买的CC3235S的开发板,程序不管是工作在接收数据模式,还是发送数据模式,工作一段时间后,就会进入
void SimpleLinkFatalErrorEventHandler(SlDeviceFatal_t *slFatalErrorEvent) 函数,打印 FATAL ERROR: Abort NWP event detected,AbortType = 3错误,
这个函数的注释说明,要程序重启设备:
This handler gets called whenever a socket event is reported by the NWP / Host driver. After this routine is called, the user's application must restart the device in order to recover.
下面是我的log:
