我想在用安卓端配置一次之后,存下输出并识别的wifi密码,让板子以后可以自己读取连入,不知道现在的cc3200 Lunchpad能不能做到呢?还有,密码在Smart Config例子里面哪里可以找到识别出来的密码?有没有具体的变量名称?...新手很多东西不懂,请大家帮下忙解答下。感激不尽。
Launchpad可以做到。
你可以通过add profile的方式,将SmartConfig以后获得的AP信息添加到Profile里面,最多可以添加7个AP的信息,并且可以设置不同的优先级。
//Add Profile
/* user needs to change SSID_NAME = "<Secured AP>"
SECURITY_TYPE = SL_SEC_TYPE_WPA
SECURITY_KEY = "<password>"
and set the priority as per requirement
to connect with a secured AP */
SlSecParams_t secParams;
secParams.Key = SECURITY_KEY;
secParams.KeyLen = strlen(SECURITY_KEY);
secParams.Type = SECURITY_TYPE;
sl_WlanProfileAdd(SSID_NAME,strlen(SSID_NAME),0,&secParams,0,1,0);
//set AUTO policy
sl_WlanPolicySet(SL_POLICY_CONNECTION,
SL_CONNECTION_POLICY(1,0,0,0,0),
&policyVal, 1 /*PolicyValLen*/);
//wait until IP is acquired
为了安全起见,smartconfig设置之后的密码MCU端是读不到的,只能读到SSID。 这是为了保护终端用户的隐私,即便是MCU开发者也不能拿到。
int SmartConfigConnect()
unsigned char policyVal;
long lRetVal = -1;
// Clear all profiles
// This is of course not a must, it is used in this example to make sure
// we will connect to the new profile added by SmartConfig
// lRetVal = sl_WlanProfileDel(WLAN_DEL_ALL_PROFILES);
// ASSERT_ON_ERROR(lRetVal);
//set AUTO policy
lRetVal = sl_WlanPolicySet( SL_POLICY_CONNECTION,
SL_CONNECTION_POLICY(1,0,0,0,1),
&policyVal,
// Start SmartConfig
// This example uses the unsecured SmartConfig method
lRetVal = sl_WlanSmartConfigStart(0, /*groupIdBitmask*/
SMART_CONFIG_CIPHER_NONE, /*cipher*/
0, /*publicKeyLen*/
0, /*group1KeyLen*/
0, /*group2KeyLen */
NULL, /*publicKey */
NULL, /*group1Key */
NULL); /*group2Key*/
// Wait for WLAN Event
while((!IS_CONNECTED(g_ulStatus)) || (!IS_IP_ACQUIRED(g_ulStatus)))
_SlNonOsMainLoopTask();
// Turn ON the RED LED to indicate connection success
GPIO_IF_LedOn(MCU_RED_LED_GPIO);
//wait for few moments
MAP_UtilsDelay(80000000);
//reset to default AUTO policy
&policyVal,
return SUCCESS;
Ti工程师 pan ,你好。
这代码(是Ti官方SmartConfig demo 注掉了profile_del() )每次都需要APP配置后才连到AP, 需要怎么改后可以达到你说的 ‘配置好’?
盼回复!
