Other Parts Discussed in Thread: CC2530
1、Touch Link连接问题,详细描述如下:
Initiator:ZED
Target:ZR
在Initiator中只有注释掉下面的bdb_StartCommissioning(BDB_COMMISSIONING_MODE_NWK_STEERING) Touch link才能正常工作
bdb_initialize();
printf("IsOnANetwork: %d\n", bdbAttributes.bdbNodeIsOnANetwork);
if(bdbAttributes.bdbNodeIsOnANetwork == FALSE)
//bdb_StartCommissioning(BDB_COMMISSIONING_MODE_NWK_STEERING);
此时Touch Link连接过程如下图,但是没有发送Simple request。
不注释bdb_StartCommissioning(BDB_COMMISSIONING_MODE_NWK_STEERING)这行代码的话就永远加不进网络,如下图,我在代码中添加了很多打印,
发现Initiator收不到Scan Response,打印信息如下,"bdbTL_HdlIncoming\n"并没有打印出来。
static ZStatus_t bdbTL_HdlIncoming( zclIncoming_t *pInMsg )
ZStatus_t status = ZSuccess;
printf("bdbTL_HdlIncoming\n");
if ( StubAPS_InterPan( pInMsg->msg->srcAddr.panId, pInMsg->msg->srcAddr.endPoint ) )
return ( bdbTL_HdlInInterPANCommands( pInMsg ) );
if ( zcl_ClusterCmd( pInMsg->hdr.fc.type ) )
// Is this a manufacturer specific command?
if ( pInMsg->hdr.fc.manuSpecific == 0 )
status = bdbTL_HdlInSpecificCommands( pInMsg );
else
// We don't support any manufacturer specific command.
status = ZFailure;
else
// Handle all the normal (Read, Write...) commands -- should never get here
status = ZFailure;
return ( status );
2、Initiator和Target均已开启NV_INIT和NV_RESTORE=1,Initiator掉电重启后只会Rejoin一次,而且没有成功过;Target掉电重启后清除了NV信息。
如下图
抓包信息如下:
