CC2652 zigbee RTC
请问在Ti-RTOS 里有相关RTC的API吗,或者zigbee协议栈有相关RTC协议栈的API吗?
可以设置当前时间(UTC),读取当前时间以及通过zigbee发送事件发生事件
类似BLE协议栈里封装的RTC的APIs,如下
blog.csdn.net/.../42458351
  • 有的,具体API请看这边:
    file:///C:/ti/simplelink_cc26x2_sdk_2_10_00_44/docs/driverlib_cc13xx_cc26xx/cc13x2_cc26x2_v1/driverlib/aon__rtc_8h.html
  • 有的,你可以直接参考这个写一样的,我自己写了一个玩的,你可以仅供参考:
    /* XDC Module Headers */
    #include <xdc/std.h>
    #include <xdc/runtime/System.h>
    #include <stdlib.h>
    #include <string.h>
    /* BIOS Module Headers */
    #include <ti/sysbios/BIOS.h>
    #include <time.h>
    #include<assert.h>
    #include <ti/sysbios/hal/Seconds.h>
    /* Example/Board Header files */
    #include "Board.h"
    void settime(void)
    struct tm ltm;
    memset(&ltm, 0, sizeof(struct tm));
    ltm.tm_year = 2018-1900;
    ltm.tm_mon = 8;
    ltm.tm_mday = 29;
    ltm.tm_hour = 15;
    ltm.tm_min = 26;
    ltm.tm_sec = 0;
    // Convert to number of seconds, this will also fill up tm_wday and tm_yday
    time_t seconds = mktime(&ltm);
    // Convert the struct date to string
    char* currTime = asctime(&ltm);
    // Convert the number of seconds to string, just to check
    currTime = ctime(&seconds);
    // Set the date into the system
    Seconds_set(seconds);
    void gettime(void)
    struct tm *ltm;
    UInt32 seconds = Seconds_get();
    System_printf("seconds = %u\n", (ULong)seconds);
    ltm = localtime(&seconds);
    char* currTime = asctime(ltm);
    char buffer [80];
    strftime (buffer, 80, "Time is %Y/%m/%d %H:%M:%S", ltm);
    System_printf(buffer);
  • 也可以参考:
    C:\TI\simplelink_cc26x2_sdk_2_30_00_34\examples\rtos\CC26X2R1_LAUNCHXL\sysbios\bigtime
  • 在API里没有看到设置系统时间为年 月日的函数啊?
  • zigbee 怎样发送UTC的命令函数?
     * Copyright (c) 2015-2017, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     *    notice, this list of conditions and the following disclaimer.
     * *  Redistributions in binary form must reproduce the above copyright
     *    notice, this list of conditions and the following disclaimer in the
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     *    its contributors may be used to endorse or promote products derived
     *    from this software without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *  ======== bigtime.cpp ========
    /* XDC module Headers */
    #include <xdc/runtime/Diags.h>
    /* BIOS module Headers */
    #include <ti/sysbios/knl/Semaphore.h>
    #include <ti/sysbios/knl/Task.h>
    #include <ti/sysbios/knl/Clock.h>
    #include "Board.h"
    #define TASKSTACKSIZE   512
    class Clock {
        private:
             // data
             int id;
             double ticks;
             int microsecond;
             int millisecond;
             int second;
             int minute;
             int hour;
             int day;
             int month;
             int year;
             int century;
             int millenium;
             Diags_Mask clockLog;
        public:
            // methods
            Clock(int newId);  // Constructor
            ~Clock();          // Destructor
            void tick();
            long getTicks();
            int getId();
            int getMicrosecond();
            int getMillisecond();
            int getSecond();
            int getMinute();
            int getHour();
            int getDay();
            int getMonth();
            int getYear();
            int getCentury();
            int getMillenium();
            void setMicrosecond();
            void setMillisecond();
            void setMillisecond(int nMilliseconds);
            void setSecond();
            void setMinute();
            void setHour();
            void setDay();
            void setMonth();
            void setYear();
            void setCentury();
            void setMillenium();
    const char *months[12] = { "January", "February", "March",
                               "April",   "May",      "June",
                               "July",    "August",   "September",
                               "October", "November", "December" };
     * Extern "C" block to prevent name mangling
     * of functions called within the Configuration
     * Tool
    extern "C" {
    /* Wrapper function to terminate the example */
    void clockTerminate(UArg arg);
    /* Wrapper functions to call Clock::tick() */
    void clockTask(UArg arg);
    void clockPrd(UArg arg);
    void clockIdle(void);
    } // end extern "C"
    /* Global clock objects */
    Clock cl0(0);  /* idle loop clock */
    Clock cl1(1);  /* periodic clock, period = 1 ms */
    Clock cl2(2);  /* periodic clock, period = 1 sec */
    Clock cl3(3);  /* task clock */
    Clock cl4(4);  /* task clock */
    Task_Struct task0Struct, task1Struct;
    Char task0Stack[TASKSTACKSIZE], task1Stack[TASKSTACKSIZE];
    Semaphore_Struct sem0Struct, sem1Struct;
    Semaphore_Handle sem0Handle, sem1Handle;
    Clock_Struct clk0Struct, clk1Struct;
     *  ======== main ========
    int main()
        /* Construct BIOS objects */
        Task_Params taskParams;
        Semaphore_Params semParams;
        Clock_Params clkParams;
        /* Construct clock Task thread */
        Task_Params_init(&taskParams);
        taskParams.arg0 = (UArg)&cl3;
        taskParams.stackSize = TASKSTACKSIZE;
        taskParams.stack = &task0Stack;
        Task_construct(&task0Struct, (Task_FuncPtr)clockTask, &taskParams, NULL);
        taskParams.stack = &task1Stack;
        taskParams.arg0 = (UArg)&cl4;
        Task_construct(&task1Struct, (Task_FuncPtr)clockTask, &taskParams, NULL);
        /* Construct Semaphores for clock thread to pend on, initial count 1 */
        Semaphore_Params_init(&semParams);
        Semaphore_construct(&sem0Struct, 1, &semParams);
        /* Re-use default params */
        Semaphore_construct(&sem1Struct, 1, &semParams);
        /* Obtain instance handles */
        sem0Handle = Semaphore_Handle(&sem0Struct);
        sem1Handle = Semaphore_Handle(&sem1Struct);
        Clock_Params_init(&clkParams);
        clkParams.period = 100;
        clkParams.startFlag = true;
        clkParams.arg = (UArg)&cl1;
        Clock_construct(&clk0Struct, (Clock_FuncPtr)clockPrd,
                        1, &clkParams);
        clkParams.period = 1000;
        clkParams.arg = (UArg)&cl2;
        Clock_construct(&clk1Struct, (Clock_FuncPtr)clockPrd,
                        1, &clkParams);
        System_printf("bigTime started.\n");
        BIOS_start();    /* does not return */
        return(0);
     *  ======== clockTerminate ========
     *  This function simply terminates the example
        System_printf("bigTime ended.\n");
        BIOS_exit(0);
     *  ======== clockTask ========
     *  Wrapper function for Task objects calling
     *  Clock::tick()
        Clock *clock = (Clock *)arg;
        int count = 0;
        if (clock->getId() == 3) {
            for(;;) {             // task id = 3
                Semaphore_pend(sem0Handle, BIOS_WAIT_FOREVER);
                clock->tick();
                if(count == 50) {
                    Task_sleep(25);
                    count = 0;
                count++;
                Semaphore_post(sem1Handle);
        else {
            for(;;) {             // task id = 4
                Semaphore_pend(sem1Handle, BIOS_WAIT_FOREVER);
                if(count == 50) {
                    Task_sleep(25);
                    count = 0;
                clock->tick();
                count++;
                Semaphore_post(sem0Handle);
     * ======== clockPrd ========
     * Wrapper function for PRD objects calling
     * Clock::tick()
        clock->tick();
        return;
     * ======== clockIdle ========
     * Wrapper function for IDL objects calling
     * Clock::tick()
     * It also calls System_flush() to periodically
     * print the contents in the SysMin buffer
        cl0.tick();
        System_flush();
        return;
     * Clock methods
    Clock::Clock(int newId)
        id = newId;
        ticks = 0;
        microsecond = 0;
        millisecond = 0;
        second = 0;
        minute = 0;
        hour = 0;
        day = 19;
        month = 8;
        year = 10;
        century = 20;
        millenium = 0;
    Clock::~Clock()
    void Clock::tick()
        ticks++;
        if (getId() == 1) {
            System_printf("id %d : %d:%d:%d.%d\n", getId(), hour, minute, second, millisecond / 100);
            System_printf("id %d : %s %d, %d%d\n", getId(), (IArg)months[month-1], day, century, year);
             * id 1 expires every 100 ticks (and each tick is 1 millisecond)
            setMillisecond(100);
        if (getId() == 2) {
            System_printf("id %d : %d:%d:%d\n", getId(), hour, minute, second);
             * Change selected function to alter clock rate
    //      setMicrosecond();
    //      setMillisecond();
            setSecond();
    //      setMinute();
    //      setDay();
            if (ticks == 2) {
                clockTerminate(0);
        return;
    void Clock::setMicrosecond()
        if (microsecond >= 999) {
            setMillisecond();
            microsecond = 0;
        else {
            microsecond++;
        return;
    void Clock::setMillisecond()
        if (millisecond >= 999) {
            setSecond();
            millisecond = 0;
        else {
            millisecond++;
        return;
    void Clock::setMillisecond(int nMilliseconds)
        int secs;
        millisecond += nMilliseconds;
        secs = millisecond / 1000;
        millisecond %= 1000;
        while (secs--) {
            setSecond();
        return;
    void Clock::setSecond()
        if (second == 59) {
            setMinute();
            second = 0;
        else {
            second++;
        return;
    void Clock::setMinute()
        if (minute == 59) {
            setHour();
            minute = 0;
        else {
            minute++;
        return;
    void Clock::setHour()
        if (hour == 23) {
            setDay();
            hour = 0;
        else {
            hour++;
        return;
    void Clock::setDay()
        bool thirtydays = false;
        bool feb = false;
        bool leap = false;
        if (month == 4 || month == 6 || month == 9 || month == 11) {
            // April, June, September, November.
            thirtydays = true;
        if (month == 2) {  // Test for February
            feb = true;
         * A year is a leap year if it is divisible by 4, but not by 100.
         * If a year is divisible by 4 and by 100, it is a leap year only
         * if it is also divisible by 400.
        if ((year%4 == 0 && year%100 != 0) ||
                (year%4 == 0 && year%100 == 0 && year%400 == 0)) {
            leap = true;
        if ((day == 28) && (feb) && (!leap)) {
            setMonth();
            day = 1;
        else if ((day == 29) && (feb) && (leap)) {
            setMonth();
            day = 1;
        else if ((day == 30) && (thirtydays == true)) {
            setMonth();
            day = 1;
        else if ((day == 31) && (thirtydays == false)) {
            setMonth();
            day = 1;
        else {
            day++;
        return;
    void Clock::setMonth()
        if (month >= 12) {
            setYear();
            month = 1;
        else {
            month++;
        return;
    void Clock::setYear()
        year++;
        if ((year%100) == 0) {
            setCentury();
        return;
    void Clock::setCentury()
        century++;
        if ((century%10) == 0) {
            setMillenium();
        return;
    void Clock::setMillenium()
        millenium++;
        return;
    long Clock::getTicks()
        return ticks;
    int Clock::getId()
        return id;
    int Clock::getMicrosecond()
        return microsecond;
    int Clock::getMillisecond()
        return millisecond;
    int Clock::getSecond()
        return second;
    int Clock::getMinute()
        return minute;
    int Clock::getHour()
        return hour;
    int Clock::getDay()
        return day;
    int Clock::getMonth()
        return month;
    int Clock::getYear()
        return year;
    int Clock::getCentury()
        return century;
    int Clock::getMillenium()
        return millenium;
