opa211仿真语法错误
Other Parts Discussed in Thread: OPA211
下载的OPA211 仿真文件,扩展名改为.ckt后导入altium designer进行仿真,加粗的几行提示语法错误
.SUBCKT VCCS_LIM_GR_0_0_OPA211   VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1
.PARAM IPOS = 0.066086
.PARAM INEG = -0.066086
G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VC+,VC-),INEG,IPOS)}
.ENDS
.SUBCKT VCCS_LIM_4_0_0_OPA211   VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1
.PARAM IPOS = 0.231
.PARAM INEG = -0.2394
.ENDS
.SUBCKT VCCS_LIM_3_0_0_OPA211   VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1
.PARAM IPOS = 0.1155
.PARAM INEG = -0.1197
.ENDS
全部的仿真模型如下:
* OPA211
* (C) Copyright 2019 Texas Instruments Incorporated. All rights reserved.
** This model is designed as an aid for customers of Texas Instruments.
** TI and its licensors and suppliers make no warranties, either expressed
** or implied, with respect to this model, including the warranties of
** merchantability or fitness for a particular purpose.  The model is
** provided solely on an "as is" basis.  The entire risk as to its quality
** and performance is with the customer
* This model is subject to change without notice. Texas Instruments
* Incorporated is not responsible for updating this model.
** Released by: Online Design Tools, Texas Instruments Inc.
* Part: OPA211
* Date: 06FEB2019
* Model Type: Generic (suitable for all analysis types)
* EVM Order Number: N/A
* EVM Users Guide:  N/A
* Datasheet: SBOS377K -OCTOBER 2006-REVISED SEPTEMBER 2018
* Created with Green-Williams-Lis Op Amp Macro-model Architecture
* Model Version: Final 1.2
* Updates:
* Final 1.2
* Updated with unique subckt name, Vos drift and edits in claw block
* Final 1.1
* Release to Web.
* Model Usage Notes:
* 1. The following parameters are modeled:
*   OPEN-LOOP GAIN AND PHASE VS. FREQUENCY  WITH RL, CL EFFECTS (Aol)
*   UNITY GAIN BANDWIDTH (GBW)
*   INPUT COMMON-MODE REJECTION RATIO VS. FREQUENCY (CMRR)
*   POWER SUPPLY REJECTION RATIO VS. FREQUENCY (PSRR)
*   DIFFERENTIAL INPUT IMPEDANCE (Zid)
*   COMMON-MODE INPUT IMPEDANCE (Zic)
*   OPEN-LOOP OUTPUT IMPEDANCE VS. FREQUENCY (Zo)
*   OUTPUT CURRENT THROUGH THE SUPPLY (Iout)
*   INPUT VOLTAGE NOISE DENSITY VS. FREQUENCY (en)
*   INPUT CURRENT NOISE DENSITY VS. FREQUENCY (in)
*   OUTPUT VOLTAGE SWING vs. OUTPUT CURRENT (Vo)
*   SHORT-CIRCUIT OUTPUT CURRENT (Isc)
*   QUIESCENT CURRENT (Iq)
*   SETTLING TIME VS. CAPACITIVE LOAD (ts)
*   SLEW RATE (SR)
*   SMALL SIGNAL OVERSHOOT VS. CAPACITIVE LOAD
*   LARGE SIGNAL RESPONSE
*   OVERLOAD RECOVERY TIME (tor)
*   INPUT BIAS CURRENT (Ib)
*   INPUT OFFSET CURRENT (Ios)
*   INPUT OFFSET VOLTAGE (Vos)
*   INPUT OFFSET VOLTAGE VS. TEMPERATURE (VOS DRIFT)
*   INPUT COMMON-MODE VOLTAGE RANGE (Vcm)
*   INPUT OFFSET VOLTAGE VS. INPUT COMMON-MODE VOLTAGE (Vos vs. Vcm)
*   INPUT/OUTPUT ESD CELLS (ESDin, ESDout)
.subckt OPA211 IN+ IN- VCC VEE OUT
.model R_NOISELESS RES (TCE=0 T_ABS=-273.15)
V_ORn       31 VCLP -24.64
V_ORp       32 VCLP 24.6374
XV_OS        39 40 VOS_DRIFT_OPA211
V4          ZO_OUT_J1 OUT 0
V_GRp       53 MID 55
V_GRn       54 MID -57
V_ISCp      49 MID 44.1288
V_ISCn      50 MID -69.656
V11         44 48 0
V12         43 47 0
VCM_MIN     67 VEE_B 1.8
VCM_MAX     68 VCC_B -1.4
I_Q         VCC VEE 3.6M
I_OS        ESDn MID 35N
I_B         40 MID 60N
XU5         VEE VCC ESDn ESDp ESD_0_OPA211
XU1 Zo_Cleft CL_CLAMP Zo_Cright MID ZO_OUT_J1 AOL_INN_J1 AOL_INP_J1 CLAMP
+ CLAW_CLAMP VSENSE AOL_ZO_0_OPA211
XU4         OUT_J1_26 ESDp MID PSRR_CMRR_0_OPA211
XU2         OUT_J1_27 VCC_B MID PSRR_CMRR_1_OPA211
XU3         OUT_J1 VEE_B MID PSRR_CMRR_2_OPA211
Xi_nn       ESDn MID FEMT_0_0_OPA211
XGR_SRC     29 30 CLAMP MID VCCS_LIM_GR_0_0_OPA211
XCL_SRC     33 34 CL_CLAMP MID VCCS_LIM_4_0_0_OPA211
XCLAW_SRC   35 36 CLAW_CLAMP MID VCCS_LIM_3_0_0_OPA211
XCLAWp      VIMON MID 37 VCC_B VCCS_LIM_CLAW+_0_0_OPA211
XCLAWn      MID VIMON VEE_B 38 VCCS_LIM_CLAW-_0_0_OPA211
Xe_n        40 ESDp VNSE_0_0_OPA211
Xi_np       MID 40 FEMT_0_0_OPA211
H2          41 MID V11 -1
H3          42 MID V12 1
S1          Zo_Cleft Zo_Cright SW_OL MID  S_VSWITCH_1
S7          VEE OUT VEE OUT  S_VSWITCH_2
S6          OUT VCC OUT VCC  S_VSWITCH_3
SOR_SWp     CLAMP 43 CLAMP 43  S_VSWITCH_4
SOR_SWn     44 CLAMP 44 CLAMP  S_VSWITCH_5
C_CMn       ESDn MID 2P
C_CMp       MID ESDp 2P
C28         45 MID 1P
R77         42 45  R_NOISELESS 100
C27         46 MID 1P
R76         41 46  R_NOISELESS 100
R75         MID 47  R_NOISELESS 1
GVCCS8      47 MID 32 MID  -1
R74         48 MID  R_NOISELESS 1
GVCCS7      48 MID 31 MID  -1
XIQPos      VIMON MID MID VCC VCCS_LIMIT_IQ_0_OPA211
XIQNeg      MID VIMON VEE MID VCCS_LIMIT_IQ_0_OPA211
C_DIFF      ESDp ESDn 8P
XCL_AMP     49 50 VIMON MID 51 52 CLAMP_AMP_LO_0_OPA211_0_OPA211
XGR_AMP     53 54 55 MID 56 57 CLAMP_AMP_HI_0_OPA211
R39         53 MID  R_NOISELESS 1T
R37         54 MID  R_NOISELESS 1T
R42         VSENSE 55  R_NOISELESS 1M
C19         55 MID 1F
R38         56 MID  R_NOISELESS 1
R36         MID 57  R_NOISELESS 1
R40         56 29  R_NOISELESS 1M
R41         57 30  R_NOISELESS 1M
C17         29 MID 1F
C18         MID 30 1F
R21         51 MID  R_NOISELESS 1
R20         MID 52  R_NOISELESS 1
R29         51 33  R_NOISELESS 1M
R30         52 34  R_NOISELESS 1M
C9          33 MID 1F
C8          MID 34 1F
R22         49 MID  R_NOISELESS 1T
R19         MID 50  R_NOISELESS 1T
R12         37 VCC_B  R_NOISELESS 1K
R16         37 58  R_NOISELESS 1M
R13         VEE_B 38  R_NOISELESS 1K
R17         59 38  R_NOISELESS 1M
C6          59 MID 1F
C5          MID 58 1F
G2          VCC_CLP MID 58 MID  -1M
R15         VCC_CLP MID  R_NOISELESS 1K
G3          VEE_CLP MID 59 MID  -1M
R14         MID VEE_CLP  R_NOISELESS 1K
XCLAW_AMP   VCC_CLP VEE_CLP VOUT_S MID 60 61 CLAMP_AMP_LO_0_OPA211
R26         VCC_CLP MID  R_NOISELESS 1T
R23         VEE_CLP MID  R_NOISELESS 1T
R25         60 MID  R_NOISELESS 1
R24         MID 61  R_NOISELESS 1
R27         60 35  R_NOISELESS 1M
R28         61 36  R_NOISELESS 1M
C11         35 MID 1F
C10         MID 36 1F
C12         SW_OL MID 100P
R32         62 SW_OL  R_NOISELESS 100
R31         62 MID  R_NOISELESS 1
XOL_SENSE   MID 62 46 45 OL_SENSE_0_OPA211
H1          63 MID V4 1K
R11         MID 64  R_NOISELESS 1T
R18         64 VOUT_S  R_NOISELESS 100
C7          VOUT_S MID 1N
E2          64 MID OUT MID  1
C13         VIMON MID 1N
R33         63 VIMON  R_NOISELESS 100
R10         MID 63  R_NOISELESS 1T
R47         65 VCLP  R_NOISELESS 100
C24         VCLP MID 100P
E4          65 MID CL_CLAMP MID  1
C4          AOL_INP_J1 MID 1F
R9          AOL_INP_J1 66  R_NOISELESS 1M
R7          MID 67  R_NOISELESS 1T
R6          68 MID  R_NOISELESS 1T
R8          MID 66  R_NOISELESS 1
XVCM_CLAMP  69 MID 66 MID 68 67 VCCS_EXT_LIM_0_OPA211
E1          MID 0 70 0  1
R89         VEE_B 0  R_NOISELESS 1
R5          71 VEE_B  R_NOISELESS 1M
C3          71 0 1F
R60         70 71  R_NOISELESS 1MEG
C1          70 0 1
R3          70 0  R_NOISELESS 1T
R59         72 70  R_NOISELESS 1MEG
C2          72 0 1F
R4          VCC_B 72  R_NOISELESS 1M
R88         VCC_B 0  R_NOISELESS 1
G17         VEE_B 0 VEE 0  -1
G16         VCC_B 0 VCC 0  -1
R_PSR       73 69  R_NOISELESS 1K
G1          69 73 OUT_J1_27 OUT_J1  -1M
R2          AOL_INN_J1 ESDn  R_NOISELESS 1M
R1          73 74  R_NOISELESS 1M
R_CMR       39 74  R_NOISELESS 1K
G5          74 39 OUT_J1_26 MID  -1M
R53         ESDn MID  R_NOISELESS 1T
R52         MID ESDp  R_NOISELESS 1T
R35         IN- ESDn  R_NOISELESS 10M
R34         IN+ ESDp  R_NOISELESS 10M
.MODEL S_VSWITCH_1 VSWITCH (RON=1M ROFF=1G VON=900M VOFF=800M)
.MODEL S_VSWITCH_2 VSWITCH (RON=50 ROFF=1T VON=500M VOFF=450M)
.MODEL S_VSWITCH_3 VSWITCH (RON=50 ROFF=1T VON=500M VOFF=450M)
.MODEL S_VSWITCH_4 VSWITCH (RON=10M ROFF=1G VON=10M VOFF=0)
.MODEL S_VSWITCH_5 VSWITCH (RON=10M ROFF=1G VON=10M VOFF=0)
.ENDS OPA211
.SUBCKT VOS_DRIFT_OPA211  VOS+ VOS-
.PARAM DC = 27.21U
.PARAM POL = 1
.PARAM DRIFT = .35E-6
E1 VOS+ VOS- VALUE={DC+POL*DRIFT*(TEMP-27)}
.ENDS
.SUBCKT ESD_0_OPA211 VEE VCC ESDn ESDp
SW5         ESDp ESDn ESDp ESDn  S_VSWITCH_1
SW6         ESDn ESDp ESDn ESDp  S_VSWITCH_2
SW1         VEE ESDp VEE ESDp  S_VSWITCH_3
SW3         VEE ESDn VEE ESDn  S_VSWITCH_4
SW4         ESDn VCC ESDn VCC  S_VSWITCH_5
SW2         ESDp VCC ESDp VCC  S_VSWITCH_6
.MODEL S_VSWITCH_1 VSWITCH (RON=50 ROFF=1T VON=700M VOFF=650M)
.MODEL S_VSWITCH_2 VSWITCH (RON=50 ROFF=1T VON=700M VOFF=650M)
.MODEL S_VSWITCH_4 VSWITCH (RON=50 ROFF=1T VON=500M VOFF=450M)
.MODEL S_VSWITCH_5 VSWITCH (RON=50 ROFF=1T VON=500M VOFF=450M)
.MODEL S_VSWITCH_6 VSWITCH (RON=50 ROFF=1T VON=500M VOFF=450M)
.ENDS
.SUBCKT AOL_ZO_0_OPA211 ZO_CLEFT CL_CLAMP ZO_CRIGHT MID ZO_OUT AOL_INN AOL_INP CLAMP
+ CLAW_CLAMP VSENSE
C2_A6       76 MID  3.97900000000000E-0016
R3_A6       MID 76 R_NOISELESS 1MEG
GVCCS3_A6   76 MID 77 MID  -1U
GVCCS4_A5   79 MID 78 MID  -8.333K
R4_A5       79 MID R_NOISELESS 1
R5_A5       77 79 R_NOISELESS 10K
R6_A5       77 MID R_NOISELESS 1.2
C3_A5       79 77 663.1F
C2_A4       78 MID 12.19F
R3_A4       MID 78 R_NOISELESS 1MEG
GVCCS3_A4   78 MID 80 MID  -1U
C2_A3       80 MID  3.53700000000000E-0016
R3_A3       MID 80 R_NOISELESS 1MEG
GVCCS3_A3   80 MID 81 MID  -1U
GVCCS4_A2   82 MID VSENSE MID  -1.053K
R4_A2       82 MID R_NOISELESS 1
R5_A2       81 82 R_NOISELESS 10K
R6_A2       81 MID R_NOISELESS 9.509
C3_A2       82 81 83.77F
Rdummy      MID ZO_OUT R_NOISELESS 1K
XVCCS_LIM_ZO 83 MID MID 84 VCCS_LIM_ZO_0_0_OPA211
R9_3        84 MID R_NOISELESS 1
R11_3       83 MID R_NOISELESS 3.2577
C4_3        83 85 33.157F
R10_3       83 85 R_NOISELESS 10K
R1_3        85 MID R_NOISELESS 1
Rx          ZO_OUT 84 R_NOISELESS 10K
GVCCS2_2    85 MID 86 MID  -1
C2_2        87 MID 3.8059P
R5_2        86 87 R_NOISELESS 10K
R4_2        86 88 R_NOISELESS 2.284MEG
R7_2        88 MID R_NOISELESS 1
GVCCS1_1    88 MID ZO_CRIGHT MID  -774.2835
C1_1        ZO_CLEFT ZO_CRIGHT 90.736N
R2_1        ZO_CRIGHT MID R_NOISELESS 12.9319
R1_1        ZO_CRIGHT ZO_CLEFT R_NOISELESS 10K
Rdc         ZO_CLEFT MID R_NOISELESS 1
G_Aol_Zo    ZO_CLEFT MID CL_CLAMP ZO_OUT  -89.0549
R4_CL       MID CL_CLAMP R_NOISELESS 1K
GVCCS4_CL   CL_CLAMP MID CLAW_CLAMP MID  -1M
R4_CC       MID CLAW_CLAMP R_NOISELESS 1K
GVCCS4_CC   CLAW_CLAMP MID 76 MID  -1M
XVCCS_LIM_2 4_A0 MID MID CLAMP VCCS_LIM_2_0_0_OPA211
C1_A0       CLAMP MID 690.7P
R4_A0       MID CLAMP R_NOISELESS 1MEG
R3_A0       MID 4_A0 R_NOISELESS 1MEG
XVCCS_LIM_1 AOL_INP AOL_INN MID 4_A0 VCCS_LIM_1_0_OPA211
R4_VS       MID VSENSE R_NOISELESS 1K
GVCCS4_VS   VSENSE MID CLAMP MID  -1M
.ENDS
.SUBCKT PSRR_CMRR_0_OPA211 OUT IN MID
G_2         OUT MID 89 MID  -142.8571
R74         MID OUT R_NOISELESS 1
R2a         MID 90 R_NOISELESS 704.9345418K
C1a         90 91 22.736F
R48         91 90 R_NOISELESS 100MEG
G_1         91 MID IN MID  -168.97U
Rsrc        MID 91 R_NOISELESS 1
R2b         MID 89 R_NOISELESS 704.9345418K
C2a         89 92 22.736F
R73         92 89 R_NOISELESS 100MEG
GVCCS7      92 MID 90 MID  -1
R49         MID 92 R_NOISELESS 1
.ENDS
.SUBCKT PSRR_CMRR_1_OPA211 OUT IN MID
R80         MID OUT R_NOISELESS 73.4749
C27         OUT 4_93 345.99P
R79         4_93 OUT R_NOISELESS 100MEG
GVCCS8      4_93 MID IN MID  -126.65M
R78         MID 4_93 R_NOISELESS 1
.ENDS
.SUBCKT PSRR_CMRR_2_OPA211 OUT IN MID
R80         MID OUT R_NOISELESS 105.6605
C27         OUT 4_94 189.47P
R79         4_94 OUT R_NOISELESS 100MEG
GVCCS8      4_94 MID IN MID  -88.072M
R78         MID 4_94 R_NOISELESS 1
.ENDS
.SUBCKT FEMT_0_0_OPA211   1 2
.PARAM FLWF=0.1
.PARAM NLFF=38746
.PARAM NVRF=1700
.PARAM GLFF={PWR(FLWF,0.25)*NLFF/1164}
.PARAM RNVF={1.184*PWR(NVRF,2)}
.MODEL DVNF D KF={PWR(FLWF,0.5)/1E11} IS=1.0E-16
I1 0 7 10E-3
I2 0 8 10E-3
D1 7 0 DVNF
D2 8 0 DVNF
E1 3 6 7 8 {GLFF}
R1 3 0 1E9
R2 3 0 1E9
R3 3 6 1E9
E2 6 4 5 0 10
R4 5 0 {RNVF}
R5 5 0 {RNVF}
R6 3 4 1E9
R7 4 0 1E9
G1 1 2 3 4 1E-6
.ENDS
.PARAM GAIN = 1
.ENDS
.PARAM GAIN = 1
.PARAM IPOS = 0.231
.ENDS
.PARAM GAIN = 1
.ENDS
.SUBCKT VCCS_LIM_CLAW+_0_0_OPA211   VC+ VC- IOUT+ IOUT-
G1 IOUT+ IOUT- TABLE {(V(VC+,VC-))} =
+(0, 0.23E-3)
+(32.3193, 1.47E-03)
+(34.0342, 2.62E-03)
+(36.5985, 6.23E-03)
+(39.7159, 0.010687)
+(40.6966, 0.011568)
+(41.6772, 0.01264)
+(42.6578, 0.013191)
+(43.6385, 0.01392)
+(44.1288, 0.014895)
.ENDS
.SUBCKT VCCS_LIM_CLAW-_0_0_OPA211   VC+ VC- IOUT+ IOUT-
+(0, 0.23E-3)
+(46.9533, 5.02E-04)
+(48.6732, 6.43E-04)
+(51.0811, 1.22E-03)
+(57.4447, 3.95E-03)
+(61.9164, 0.0068168)
+(62.6904, 0.007324)
+(64.2383, 0.0085276)
+(65.7862, 0.0096693)
+(67.3341, 0.010742)
+(68.882, 0.011778)
+(69.656, 0.012297)
.ENDS
.SUBCKT VNSE_0_0_OPA211   1 2
.PARAM FLW=0.1
.PARAM NLF=24.63
.PARAM NVR=1.3
.PARAM GLF={PWR(FLW,0.25)*NLF/1164}
.PARAM RNV={1.184*PWR(NVR,2)}
.MODEL DVN D KF={PWR(FLW,0.5)/1E11} IS=1.0E-16
I1 0 7 10E-3
I2 0 8 10E-3
D1 7 0 DVN
D2 8 0 DVN
E1 3 6 7 8 {GLF}
R1 3 0 1E9
R2 3 0 1E9
R3 3 6 1E9
E2 6 4 5 0 10
R4 5 0 {RNV}
R5 5 0 {RNV}
R6 3 4 1E9
R7 4 0 1E9
E3 1 2 3 4 1
.ENDS
.SUBCKT VCCS_LIMIT_IQ_0_OPA211  VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1E-3
G1 IOUT- IOUT+ VALUE={IF( (V(VC+,VC-)<=0),0,GAIN*V(VC+,VC-) )}
.ENDS
.SUBCKT CLAMP_AMP_LO_0_OPA211_0_OPA211   VC+ VC- VIN COM VO+ VO-
.PARAM G=1
GVO+ COM VO+ VALUE = {IF(V(VIN,COM)>V(VC+,COM),((V(VIN,COM)-V(VC+,COM))*G),0)}
GVO- COM VO- VALUE = {IF(V(VIN,COM)<V(VC-,COM),((V(VC-,COM)-V(VIN,COM))*G),0)}
.ENDS
.SUBCKT CLAMP_AMP_HI_0_OPA211  VC+ VC- VIN COM VO+ VO-
.PARAM G=10
.ENDS
.SUBCKT CLAMP_AMP_LO_0_OPA211  VC+ VC- VIN COM VO+ VO-
.PARAM G=1
.ENDS
.SUBCKT OL_SENSE_0_OPA211  COM SW+ OLN  OLP
GSW+ COM SW+ VALUE = {IF((V(OLN,COM)>10E-3 | V(OLP,COM)>10E-3),1,0)}
.ENDS
.SUBCKT VCCS_EXT_LIM_0_OPA211  VIN+ VIN- IOUT- IOUT+ VP+ VP-
.PARAM GAIN = 1
G1 IOUT+ IOUT- VALUE={LIMIT(GAIN*V(VIN+,VIN-),V(VP-,VIN-), V(VP+,VIN-))}
.ENDS
.SUBCKT VCCS_LIM_ZO_0_0_OPA211   VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 3070.6491
.PARAM IPOS = 882.576E2
.PARAM INEG = -1393.121E2
.ENDS
.SUBCKT VCCS_LIM_2_0_0_OPA211   VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 0.0029817
.PARAM IPOS = 1.864E-2
.PARAM INEG = -1.864E-2
.ENDS
.SUBCKT VCCS_LIM_1_0_OPA211  VC+ VC- IOUT+ IOUT-
.PARAM GAIN = 1E-4
.PARAM IPOS = .5
.PARAM INEG = -.5
.ENDS
  • 您好,
    感谢您对TI产品的关注!
    .ckt文件您是在哪里下载的呢,据我了解的信息,TI应该没有提供OPA211的.ckt文件,根据这个网页(https://www.fileviewpro.com/zh-cn/file-extension-ckt)描述,.ckt应该是Altium公司开发的文件,您可以寻求Altium公司的支持
    抱歉,关于.ckt文件问题无法给您提供帮助,如果您在使用OPA211设计电路时遇到问题,您可以发帖,我们可以一起讨论解决
  • ckt文件是我在TI官网OPA211芯片下的设计工具和仿真里下载的Spice模型(sbom307e或sboc250c内的OPA211.lib文件我把更改扩展名为.ckt)
    按照文件前面的介绍,应该是可以适用的
    * Part: OPA211
    * Date: 06FEB2019
  • 一般的话,这种Spice模型文件直接改为ckt扩展名是可以用的,其他TI芯片的仿真模型也是可以这么用的
