Other Parts Discussed in Thread: DAC8728
DAC8728必须要在cs信号为高的时候才输出么?说明文档40面里面说到 异步模式 When the correction engine is off (SCE bit = '0'), the DAC Data Registers and DAC latches are updated immediately when CS goes high. cs是片选信号,低有效,片选为高了,芯片都不工作了,怎么还输出?
还有个问题,文档里面说 Asynchronous Mode :In this mode, the LDAC pin is set low at power-up. Synchronous Mode:To activate this mode, take LDAC low or set the LD bit to '1' after CS goes high. 我就设置LDAC一直低,那不矛盾么,到底是异步还是同步?
